When calculating the amount of work done, using the force applied and
5 replies · 2K views · last reply
Jadaav
When calculating the amount of work done, using the force applied and the displacement, does the weight of the object do anything ?
It depends - work is force * distance.
If you are lifting an object then the force is the weight.
If the object is moving on a real surface then the friction force you need to overcome will depend on it's weight.
Thanks both of you two:)
For now, I'm learning of work done without friction force.
Can I have a website where you can learn work done involving 'friction' please ?
Try this one: http://hyperphysics.phy-astr.gsu.edu/hbase/fricon.html"
Thanks, it sounds like an interesting site with a brainstorming in front.:)
