When is the work on a spring negative and when is it positive?
The discussion clarifies the conditions under which the work done by a spring is considered negative or positive, particularly in relation to a glider attached to a spring. When the glider moves away from the spring, the work done by the spring on the glider is negative due to the opposing directions of force and displacement. Conversely, if the glider moves towards the spring, the work done is positive, as both the force and displacement align. The work-energy theorem is applied using the equation W = (1/2)mv22 - (1/2)mv12, emphasizing the importance of understanding the direction of forces involved.
  • Understanding of Newton's Third Law of Motion
  • Familiarity with the work-energy theorem
  • Basic knowledge of spring mechanics and Hooke's Law
  • Ability to interpret equations involving kinetic energy
  • Study the implications of Hooke's Law in various spring scenarios
  • Learn about the conservation of energy in mechanical systems
  • Explore examples of work done by different forces in physics
  • Investigate the relationship between force, displacement, and work in greater detail
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of work and energy in spring systems.
PhyIsOhSoHard
I have a problem understanding whether a sign should be positive or negative when it comes to a spring.
In my book, there is an example with a glider attached to a spring, and the glider is moving away from the spring so it expands.
It says that in order to use the work-energy theorem, it has to be the work done by the spring on the glider, which is the negative of the following equation:
W=\frac{1}{2}mv_2^2-\frac{1}{2}mv_1^2
Can somebody explain the "work done by the spring" and "work done on the spring"? How do I know which situation I have?
Why is the work negative in this situation?
And if the glider went the opposite direction, towards the spring, would that mean the work-energy theorem is positive?
Direction of spring force is always against its extension . Since F = - kx if the this is opposite to instantaneous displacement of body then negative work is done or if it is along the displacement positive work is done
you are not alone.
Yes, but that is confusing, isn't it?
By Newton's 3rd law, you always have both situations, but usually you are looking at work done on the object by the spring.
Work done on an object by a spring is negative when the displacement and force on the object are in opposite directions. When the glider is moving away from the spring, it is pulling on the spring, so by Newton 3, the the spring is pulling back on the glider. Since the force on the glider is back, but the displacement of the glider is forward, work done by the spring on the glider is negative.
Yes, the direction of the spring force on the object is back (it is pulling it back), and the glider is moving back, same direction, work is plus. It is often better to use conservation of energy equation rather than work-energy, since the plus/minus signs can be handled easier. But nonetheless, it is a good exercise using work-energy.
Likes 1 person
  • · Replies 58 ·
  • · Replies 17 ·
