When to use negative sign ? [3 equations of motion]
This discussion clarifies the use of positive and negative signs in the equations of motion, specifically in the context of vertical motion. In Example 3.13, the initial velocity is set as u = +12 m/s, indicating upward motion, while in Example 3.1, u = -2 m/s reflects downward motion. The displacement in Example 3.13 is -65 m because it measures the distance below the chosen origin point. The forum participants emphasize the importance of consistently applying sign conventions to avoid confusion.
  • Understanding of the equations of motion: v = u + at, S = ut + 1/2at², v² - u² = 2aS
  • Familiarity with vector direction and sign conventions in physics
  • Basic knowledge of kinematics and free fall
  • Ability to interpret displacement in relation to a defined coordinate system
  • Research the implications of different sign conventions in kinematics
  • Learn how to apply the equations of motion in various scenarios, including free fall
  • Explore the concept of reference points and their impact on displacement calculations
  • Study examples of vertical motion problems to practice identifying initial velocities and displacements
Students studying physics, particularly those focusing on kinematics and motion, as well as educators seeking to clarify the concept of sign conventions in equations of motion.
gaganspidey
Example 3.13 :
Example 3.1
v=u+at
S=ut+1/2at2
v2-u2=2aS
I know the solution is in front of me, that's ok but I have a confusion regarding negative & positive signs. In both the examples something is moving vertically upwards & in both cases something is released below to the ground, then why in Example 3.13 initial velocity of the stone is taken as u = +12m/s whereas in Example 3.1 u = -2m/s ?
Also in Example 3.13, displacement = -65 m, why ?
Please clear these doubts of mine in as much detail as possible so that I know which sign to use in which case.
It does not matter which direction you put the + y axis. Usually, one uses up as + and down as -. Just choose a direction as + and the opposite direction will be -.
AM
They just used different sign conventions. In 3.13 they used up as the positive direction; in 3.1 they used down as positive.
They are measuring the displacement from the starting point, which they call y = 0. (Where you set the origin of your coordinate system is arbitrary. You could also set the ground level to be y = 0, making your initial position y = 65 m.) So the final displacement is below that, thus -65 m.
I recommend that until you are comfortable with arbitrary sign conventions you stick with a standard one: Let up be positive and down be negative. Why not solve 3.1 using that sign convention and see if you get the right answer?
@Doc Al
Oh I see ! Yes I get the same answer by taking upward as positive & downward as negative. Just that in this case we take u=-12m/s, s=65 & g=+9.8m/s2
Then why do they confuse us by using different sign conventions when sticking to a standard one does the job.
Thanks for your help too Andrew Mason !
One more thing, they say when a body is released from another body moving upwards, u will be negative [Taking upward as (-ve) & downward as (+ve)] because first it reaches the highest point, i.e, it slightly moves up & then proceeds falling downward. So in this case, we'll take u=(-ve), g =+9.8m/s2 & s = (+ve).
Am I right here ?
[hope its not a silly question :redface: ]
Am I right here ?
Sounds good to me. The first two--the acceleration and initial velocity--are unambiguous. The sign of the displacement depends on whether it ends up above or below the starting point. If it ends up below (like if it falls to the ground), then s will be positive.
^ Got it ! Thanks !
