B Where Did I Go Wrong in Calculating the Kinetic Energy of an Asteroid Impact?
  • B
  • Thread starter Thread starter newjerseyrunner
    Bug
The discussion revolves around calculating the speed at which a space shuttle would need to impact Earth to release the same kinetic energy as the asteroid that caused the dinosaur extinction, estimated at 4.2e25J. The initial calculations incorrectly set the speed of light (c) to 1, leading to erroneous results, and participants highlighted the importance of maintaining proper units throughout the equations. A key correction involved recognizing that the kinetic energy formula must account for relativistic effects, and the correct approach involves using the actual speed of light rather than simplifying it to 1. The conversation also touched on the practical implications of such an impact, noting that even at lower velocities, a shuttle would face significant challenges during re-entry, including potential evaporation in the atmosphere. Ultimately, the discussion serves as a thought experiment on the immense energy involved in such a scenario.
newjerseyrunner
I want to know how fast the space shuttle would have to hit the Earth to unleash the same kinetic energy as the asteroid that killed the dinosaurs. I've already determined that it's relativistic, by showing that Newtonian physics gives a v greater than c
4.2e25J = (2e6 * v ^ 2 ) / 2.
8.4e25J = 2e6 * v ^ 2
v = sqrt(8.4e25J / 2e6)
v = 6,480,740,698 m/s
But once I plug in the equations, I get a wrong result.
KE = (m * c ^ 2) / sqrt(1 - (v ^ 2 / c ^ 2))
KE / (m * c ^ 2) = sqrt(1 - (v ^ 2 / c ^ 2))
((KE / (m * c ^ 2)) ^ 2) - 1 = -(v ^ 2 / c ^ 2)
v = -sqrt((((KE / (m * c ^ 2)) ^ 2) - 1) * c ^ 2)
KE = 4.2e25J
c = 1
m = 2e6kg
v = -sqrt((((4.2e25 / (2e6)) ^ 2) - 1) * 1)
v = -2.1e+19
I'm expecting an answer between 0 and 1, where did I go wrong?
Mathematics news on Phys.org
In the first step.
KE = 4.2e25J
c = 1
m = 2e6kg
v = -2.1e+19
You mixed nominator and denominator of the quotient on the RHS of your second line.
and with setting c = 1
Where? I divided both sides of the equation by the term m * c ^ 2? It was in the numerator of the RHS in the 1st line and in the denominator of the LHS on the second line. I'm sure this is going to be one of those things that's stupidly obvious once I see it, but I'm still missing it.
I did? Isn't that the value I'm supposed to use? If I want v as a percentage of c, shouldn't c be 1 exactly?
You have ##a = b/c## and proceed with ##a/b = c##
No: c is 3 x 108 in your system of units.
v/c is usually called ##\beta##. Your numerical value for KE/m has a factor c2 that you can't simply set to 1.
Likes newjerseyrunner
... instead of ##a/b = 1/c##
Oh, see, there's the stupid mistake. I need caffeine. I still would have gotten the wrong answer though so thanks pointing out my unit mistake too. :)
There's a few other problems to deal with in this scenario: they had big problems with re-entry even at very low velocities. Like most meteorites, your speeding shuttle would evaporate in the first few km of atmosphere -- fortunately.
I get ##\beta = {465\over 466}## and worry about fuel prices (but only for a short time).
[edit] Missed ! see #14 below
Likes fresh_42
I'm still getting something very wrong.
Relativistic Kinetic Energy
Divide both sides by m * c ^ 2
(m * c ^ 2) / KE = sqrt(1 - (v ^ 2 / c ^ 2))
Square both sides
((m * c ^ 2) / KE)^2 = 1 - (v ^ 2 / c ^ 2)
Replace the subtraction by addition of a negative
((m * c ^ 2) / KE)^2 = 1 + -(v ^ 2 / c ^ 2)
Subtract 1 from both sides
((m * c ^ 2) / KE)^2 - 1 = -(v ^ 2 / c ^ 2)
Simplify the negative
((m * c ^ 2) / KE)^2 - 1 = -v ^ 2 / c ^ 2
Multiply both sides by c ^ 2
(((m * c ^ 2) / KE)^2 - 1) * c ^ 2 = -v ^ 2
Take the square root of both sides
sqrt((((m * c ^ 2) / KE)^2 - 1) * c ^ 2) = -v
Multiple both sides by -1
v = -sqrt((((m * c ^ 2) / KE)^2 - 1) * c ^ 2)
Input known values
v = -sqrt((((2e6 * 3e5 ^ 2) / 4.2e25)^2 - 1) * 3e5 ^ 2)
Solve
v = -300000 i
Agreed, this is purely theoretical assuming perfect conditions. No atmosphere.
I think you still have a sign error which gives you the imaginary solution. ##\sqrt{-v^2} = vi \neq -v##.
Yes, and this is a not-so-smart way to find something close to 300000.
You have ##\displaystyle {\rm{E} \over \ mc^2} = 233 = \gamma = {1\over \sqrt{1-\beta^2}} \ ##, so clearly ##\beta\approx 1## and you can write
##1-\beta^2 = (1+\beta) (1-\beta) = 2(1-\beta)##
and now I have to correct meself (post #10):$$
1-\beta ={\textstyle {1\over 2} } {1\over 233^2} \ \Rightarrow \ \beta = 1 - {1\over 108889} = {108888\over 108889} \ \Rightarrow v = 0.999991\ {\rm c} $$
##v \approx c##, and ##c \approx 3 \times 10^8 m/s##, so if the atmosphere is 100km thick, the shuttle will take approximately 0.3 milliseconds to traverse it. Will the spaceship evaporate in that period? Does it matter? You're still depositing a mole of joules into the system.
Edit: Of some relevance.
Likes BvU
Awesome, that's the exact same answer I got when I put in 299792458 instead of 3e5, just with an i in it. I'm sure I'd find the mistake if I looked, but I don't really care if my mistake only changes the imaginary factor. Thanks for the simplification too.
I was thinking that too. I doesn't really make a difference, you're still adding the amount of energy that killed the dinosaurs into the system. It'd go off like a bomb and obliterate the biosphere no matter where something with that much power exploded.
Granted. I got stuck in the immediate vicinity of the actual speeds of descent and forget to 'think' relativistically.
Does it matter ? No. There's no way you can get this kind of energy in a 2000 metric ton vehicle. Think of it: the energy equivalent of 470 kilotonne of matter ...
But it sure is fun as a thought experiment... and to bicker about :smile:
