Where is the Electric Field Equal to Zero?
40 replies · 21K views · last reply
mrlucky0
Two tiny objects with equal charge of 85.0 µC are placed at two corners of a square with sides of 0.295 m, as shown. How far above and to the left of the corner of the square labeled A would you place a third small object with the same charge so that the electric field is zero at A?
Here is a drawing:
http://img177.imageshack.us/my.php?image=newbitmapimageqn1.png
Coulomb's Law: F = (k * q1 * q2 ) / r^2
Electric Field: = k*q / r^2
One of the force vectors (call it F1) is pure y. I decomposed the other force vector (call it F2) into it's x and y components.
Vector F1 = < 0, F1 >
Vector F2 = < F2*cos(a), F2*sin(a) >
so you know now, the net force acting due to F1 and F2
but the system is in equilibrium so find F3
Thanks for the response.
I can find F3:
F3 = F1 + F3
= < F2 cos (a) + F1, sin (a) >
Now, I know can find F1 and F2 using Coulomb's law:
F2 = ( k * 85 uC ) / r2^2
F1 = ( k * 85 uC ) / r1^2
And I also know that the F3 = <0, 0 >
I'm stuck here because I'm not sure what the setup should be.
I can find F3:
F3 = F1 + F3
no, you don't know that! It's the net force that =0
F3 != <0,0>
and as k and 85 uC would cancel out, you can find x and y distance of F3
I know:
F3 = F1 + F3
and
so for x component:
F2 * cos(a) + F1 = ( k * 85 uC ) / r2^2
y component:
F1 * sin(a) = ( k * 85 uC ) / r1^2
Is this reasonable? Where do I go from here?
yea, that's reasonable enough.
you know r1 and r2
and you also know sin(a) and cos(a)
amd so
F3x=that total x-comp
F3y = that total y-comp
and you know it's charge
so you would left with r3x and r3y
you know r1 and r2
amd so
I'm not following you entirely:
r1, r2, and the angle a is unknown to me. If I am not mistaken, don't these 3 values depend on the position of where I place A? Ultimately I want to the electric field to zero wherever I place A.
"are placed at two corners of a square with sides of 0.295 m, as shown. "
A is at one corner of the square.
And reread the question: I think it's like E should be zero at A. So, you are calculating the force acting at point A due to other three charges
so, A is fixed and you cannot move it
Oh you're absolutely right. So I'll just determine vector F3 by summing vector F1 and F2:
I have all the ingredients.
r1 = .295
r2 = .42
angle a = 45 degrees
Am I doing the following correctly:
Force F2 = ( 85E-6 C * K ) / ( .42 m)^2
Force F1 = ( 85E-6 C * K ) / ( .295 m)^2
so the vectors:
F2 = < F2 cos(45), F2 sin(45) >
F1 = < 0, F1 >
r1 = .295
r2 = .42
so the vectors:
F1 = < 0, F1 >
yep seems correct, now find f3-x and f3-y
Here's what I'm doing. Using Coulomb's law:
Force F2 = ( 85E-6^2 C * K ) / ( .42 m)^2
= 369 Newtons
Force F1 = ( 85E-6^2 C * K ) / ( .295 m)^2
= 474 Newtons
F1 = < 0, 474 >
F2 = < cos(45)*F2, sin(45)*F2 > = < 261, 261 >
F3 = <261, 735>
These figures don't seem right.
You're mixing up electric field, and electrical force... For this problem, you need to use electric field...
Electric field strength= kq/r^2
Electric force between to charges = kq1q2/r^2
mrlucky0 said:
F3 = <261, 735>
If you have added correctly, and all that, here's what you should do now.
F3[x] = ( 85E-6^2 C * K ) / x^2
F3[y] = ( 85E-6^2 C * K ) / y^2
so find x and y, and it would be the answer.
P.S. you have used the wrong method but nevertheless, you can use it to get the answer
"Force F2 = ( 85E-6 C * K ) / ( .42 m)^2
Force F1 = ( 85E-6 C * K ) / ( .295 m)^2"
why did you squared it[85E-6 C * K] in the post after this one?:eek:
oops.. I just ignored what you were using, but rather was looking at the way..
It should have been E2 and E1 instead of F1 and F2
sorry,
my mistake :redface:
I solved those equations and here's what I got:
x = +/- 5
y= +/- 3
The problem states that A is in the top left region relative to the square should I use <-5, 3> ?
I think a lot of careless mistakes are propping up... first find the field due to those first two charges at A... not the force...
Then the field due to the third charge must cancel the field due to the first two charges... ie: it's the negative of the above field...
Using the magnitude of this field, you can find the distance the third charge is from A... using the direction of the field, you can find the angle from the third charge to A...
then using this angle you can get the x value (distance to the left of A) and y value(distance above A).
This isn't right... the x component and y component don't work out like that...
so F3 = <261, 735>
and thus ( 85E-6^2 C * K ) / x^2 = 261
hence x= 0.4991
and ( 85E-6^2 C * K ) / y^2 = 753
y=0.2938
and I used other method, and got the same answer!
so don't they work?
The vector that cancels the first two charges I found to be <-1.3E6, 3.9E6>
The magnitude is 3.7E6.
How do I this is to find the distance the third charge is from A?
rootX said:
so F3 = <261, 735>
hence x= 0.4991
y=0.2938
so don't they work?
For the answer, I do think that the x component is negative and the y component is positive since the third large is located somewhere to the left and to the top relative to A. Does that make sense?
again use Ex=kq/x^2
Ey=kq/y^2
and thus solve for x and y.
If a charge q is at some point (x, y)... then the magnitude of the field at the (0,0) is:
[tex]\frac{kq}{x^2+y^2}[/tex]
The x-component of the field is [tex]\frac{kq}{x^2+y^2} * cos(\theta) = \frac{kq}{(x^2+y^2)}\frac{-x}{\sqrt{x^2+y^2}}=\frac{-kq * x}{(x^2+y^2)^{\frac{3}{2}}[/tex]
ie: the x-component is NOT [tex]-\frac{kq}{x^2}[/tex]
oops, sorry again, I would try them tomorrow morning.
P.S. need a sleep.yea, I got it now! :D
I think I had been thinking wrong through out my last year physics course ><
P.S. somehow I got more than 100% on my static electricity unit test lol
P.S. need a sleep.
:wink: :smile:
yea, though I can't think any good know, but I guess
it's located "a" distance left,
and less than "a" distance above A.
just don't care about signs much, that makes the job a lot easier. And always try using symmetries and other geometrical tools while solving these problems
P.S. don't sub in values right away, chances of getting a wrong answer become high.
Oops... sorry, I didn't notice this till now. Just use kq/r^2 = 3.7E6 to calculate r. Draw a picture...
Are you sure your vector is right? I'm getting this for the field due to the first two charges:
For the first charge
<0, 8.8E6>
this comes from (9E9)(85E-6)/(0.295^2)
For the second charge
<-3.1E6,3.1E6>
this comes from (9E9)(85E-6)/(0.295^2 + 0.295^2)cos(45)
So the total I'm getting is:
<-3.1E6, 11.9E6> so with a magnitude of 12.3E6
<0, 8.8E6>
<-3.1E6,3.1E6>
This is how I proceeded. I decompose E2. The .42 ( the r from the second charge to A) is just the hypotenuse of a right triangle: sqrt(.295^2 + .295^2) = .42
I am saying that the angle 135 degrees is the angle of E2 relative to the positive x-axis.
E1 = <0, 8.8E6 >
(same thing you did)
E2 = (9E9)(85E-6)/.42^2 * <cos(135), sin(135) >
= 4.3E7 * < cos(135), sin (135) >
= < -3E7, 3E7 >
Enet = E1 + E2 = < -3E7, 3.9E7 >
||Enet|| = 4.7E7
So it seems our only disagreement is E2. Where am I going wrong?
Check your exponent when you calculate E2... I think it should be 4.3E6.
Whoops. Ok:
E1 = <0, 8.8E6 >
= 4.3E6 * < cos(135), sin (135) >
= < -3E6, 3E6 >
Enet = E1 + E2 = < -3E6, 1.2E7 >
||Enet|| = 1.2E7
Looks good now right? Could you explain where I go from here?
mrlucky0 said:
Whoops. Ok:
E1 = <0, 8.8E6 >
= < -3E6, 3E6 >
||Enet|| = 4.7E7
You should fix Enet.
