Where is the electric field zero
The electric field is zero at two points in the scenario involving a -10.0 nC point charge and a +20.0 nC point charge separated by 15.0 cm. The calculations using Coulomb's law, specifically the equation 0 = k*q1/x^2 + k*q2/(r-x)^2, yield potential solutions at x = -0.36 m and x = 0.062 m. However, the correct approach requires recognizing that the electric field cannot be zero between the two charges. The revised equation for determining the electric potential zero point is 0 = k*q1/x^2 + k*q2/(r+x)^2.
  • Understanding of Coulomb's law and electric fields
  • Knowledge of electric potential and its relationship to electric fields
  • Familiarity with basic algebra and solving quadratic equations
  • Concept of point charges and their interactions
  • Study the derivation of electric field equations for point charges
  • Learn about the concept of electric potential and its calculation
  • Explore the implications of charge placement on electric field strength
  • Investigate the graphical representation of electric fields and potentials
Students in physics, particularly those studying electromagnetism, educators teaching electric fields and potentials, and anyone solving problems related to point charges and their interactions.
fallenshadow95
A -10.0 nC point charge and a +20.0 nC point charge are 15.0 cm apart on the x-axis.
a. What is the electric potential at the point on the x-axis where the electric field is zero?
b. What is the magnitude of the electric field at the point on the x-axis, between the charges, where the electric potential is zero?
E = kQ/r^2
V = Ed
U = kQq/r
Let x be the distance from the -10nC point where the field is zero in cm
r = .15m
k = Coulomb's constant (8.99*10^9)
q1 = -10nC
q2 = 20nC
I tried solving for where the electric field would be zero by first doing:
0 = \frac{k*q_1}{(x)^2} + \frac{k*q_2}{(r-x)^2}
Solving for x, I got x = -0.36m and 0.062m
I'm not really sure how to proceed from here since I have two points where it seems that the field is zero.
You have a positive charge say at (a,0) and a negetive charge at (b,0). Obviously the electric field is non zero in between the charges. Your equation is incorrect because you assumed the required point to be in between a and b.(you took r to be the distance between the charges and x to be the distance from q1 to the required point, and the other is r-x).
So change it to:
$$0=\frac{kq_1}{x^2} + \frac{kq_2}{(r+x)^2}$$
Same method is used for electric potential as well. Try to derive the expression for the point where the potential is zero. Then again find x.
  • · Replies 16 ·
