Where is the mercury contained in a CFL
  • Thread starter Thread starter jrs_73
    Mercury
CFLs contain approximately 3-5 mg of mercury, which is generally not a cause for alarm according to poison control. The mercury is contained as elemental vapor within the gas throughout the bulb, rather than being concentrated near the ballast. Breaking a CFL may not release mercury if the break occurs away from the ballast end. The risk from mercury exposure is considered chronic, meaning it poses a problem primarily with frequent bulb breakage. Understanding the design and function of CFLs can help mitigate concerns about mercury exposure.
jrs_73
Hello all,
This evening, I broke a hole near the tip of a spiral CFL similar to this one while screwing on a glass cover over a ceiling light fixture in what will become a new baby's room:
http://upload.wikimedia.org/wikipedia/en/thumb/0/0b/Compact-Flourescent-Bulb.jpg/180px-Compact-Flourescent-Bulb.jpg" .
I spoke to poison control and was told that the amount of mercury contained in a CFL (3-5mg) is nothing to be alarmed about.
The poison control rep also told me that I may not have even released the mercury at all because I broke the bulb at the end furthest away from the ballast. She stated that the mercury is actually contained in an enclosed area on the ballast end...is that true?
Thanks :smile:
http://en.wikipedia.org/wiki/Compact_fluorescent_lamp
I would assume that the mecuy vapour is present within an enclosed space close to the ballast, so that the eletric current can be fed through it easily, but I guess it would depend on manufacturer and design.
They reckon that the amount in a tube is only a chronic hazard, so it should only present a problem if you break a bulb every day.
The mercury is actually contained as elemental vapor in the gas, not condentrated near the ballast. The plasma discharge excites a UV level (I think around 3800 Angstroms) in mercury, which is not visible. The white coating on the inside of the glass absorbs this radiation and reemits visible (longer wavelength) light.
Bob S
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
