- #36
enigma
Staff Emeritus
- 17
Vinni said:Again I ask why was GM given the task of making the robots for NASA?
Look at what others are doing:
http://www.youtube.com/watch?v=TJmQqC1nHTU&feature=related
http://www.youtube.com/watch?v=cfBpqsqnf80&feature=related
http://www.youtube.com/watch?v=2kp7V8qNbxQ&feature=related
http://www.youtube.com/watch?v=40l2mrCJZiU&feature=related
Compared to Robonaunt 2's capabilities:
http://www.wired.com/autopia/2010/02/gm-nasa-robonaut-2/
Just the use of motion capture technology for robotics is leaps and bounds ahead of anything NASA is doing.
Ground based robots do not work in space. The environment is so foreign and counter-intuitive to "common sense" that I, as someone who has worked developing tools for use in space who knows what needs to go into the construction, cannot watch sci-fi anymore.
Bring a ground robot into space, the lubricants would boil off due to outgassing, the gimbals would overheat due to not having appropriate thermal control systems, the control systems would not know how to properly orient itself due to the constantly changing reference frames and full 6 degree of freedom motion that is needed, the power systems (notice most of those robots were plugged in) would draw so much energy they'd need a football field sized solar array, and the body itself would be so much heavier than a specially designed robot that it would cost too much fuel to move it around.
As to the human motion readers to control the robot - If you want to control it from in space, you don't want to use a human motion reader because the human is floating. If you turn your arm to move the robot's arm, guess what? You are now looking away from the viewscreen. Furthermore, relative motion in space is very tricky. If you are behind an object in orbit, you need to decelerate to get closer, accelerate to get farther away. Doing so will also cause you go move "up" and "down" relative to your target as well. All of that can be easily compensated into the transfer functions of a fly-by-wire system, but it doesn't work very well if you are tied to a human being making a set motion. There is a reason it takes hours to link up with the ISS, and that reason isn't because astronauts and NASA scientists are stupid.
