Which 3D printer would be best for this printing job?
  • Context: Wood/Glass/Metal
  • Thread starter Thread starter tirelessphoenix
The discussion revolves around selecting a suitable and cost-effective 3D printer for a specific printing job, with a focus on using PETG-CF material for strength. Participants explore various options and considerations related to the printing process and material properties.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests the Creality Ender 3 V3 KE 3D printer as a potential option for the job, citing its capability to use PETG-CF material.
  • Another participant questions the size of the object to be printed, indicating that dimensions are important for selecting the right printer.
  • A different perspective is offered, proposing that fabricating the object from steel might be more efficient than 3D printing, especially considering the potential slow speed of 3D printing.
  • Some participants express uncertainty about the terminology used in the discussion, seeking clarification on what constitutes an appropriate and affordable 3D printer.
  • One participant inquires about the application and the forces the printed object will be subjected to, highlighting the importance of understanding the functional requirements of the piece.
  • Concerns are raised about the suitability of using plastic or carbon fiber for the application, with a suggestion that metal might be a better alternative.
  • Another participant reiterates the desire to use carbon fiber and seeks specific recommendations for a 3D printer that can handle that material.
Participants have not reached a consensus on the best 3D printer for the job, with multiple competing views regarding the suitability of different materials and methods for fabrication.
There are unresolved questions regarding the specific dimensions of the object and the forces it will encounter, which may influence the choice of printer and material.
Individuals interested in 3D printing, particularly those looking for cost-effective solutions and material considerations for strength in their projects.
tirelessphoenix
TL;DR
which is best 3d printer for doing this piece?
Hi, anyone with 3D printing experience, which cost-effective 3D printer would be best to do this job seen in the picture?
I read Creality Ender 3 V3 KE 3d Printer can do a good job but I am not sure. I looked into using PETG-CF material since I need it a little strong material and I read the Ender 3 V3 can use it.
Any advice?
Thank you
tirelessphoenix said:
Any advice?
Any idea what size it is?
yes. picture in inches
3D printing will be slow.
I would fabricate it from 7/8" square steel tube, RHS.
I would use a small MIG welder to make the joint.
With a slight design change, it could be cut and folded from one piece of RHS without welding.
it is ok if it prints slow.
sorry, I also don't understand your terminology.
which 3D printer would be appropriate and affordable?
TL;DR: which is best 3d printer for doing this piece?
I'm probably of no help on choosing a good 3D printer for this, but can you say what the application is? What kind of forces will this widget be subjected to?
not that much weight. 10-20kilos max.
20kilos max.
So 40 pounds through a 3 inch lever arm? Are you sure you want to use plastic (or carbon fiber?) or would metal as suggested by @Baluncore maybe be better?
I want to use carbon fiber (material listed). I would just need to know which 3D printer might be best to just print that with the material I listed. thank you
  • · Replies 20 ·
  • Sticky
  • · Replies 19 ·
13K
