Which primes p satisfy p^2|5^p^2+1?
  • Thread starter Thread starter DianaSagita
    Primes
The discussion centers on determining which prime numbers p satisfy the condition p^2 divides 5^(p^2) + 1. Participants identify p = 3 as a solution, while also considering p = 2. Using Fermat's Little Theorem, they derive that if 5^p + 1 is divisible by p, then p must divide 6, leading to the conclusion that the only primes are 2 and 3. However, further verification reveals that p = 2 does not satisfy the original condition, confirming that p = 3 is the unique solution. The conversation highlights the importance of careful verification in number theory problems.
DianaSagita
First of all, hi everyone!
I'm quite new in number theory, and need help on this one badly...
Determine all prime numbers p so p2 divides 5p2+1.
Euler's theorem: If a and m are coprimes then a^{\varphi(m)}\equiv 1 (mod\ m)
where \varphi(m) (Euler's function) denotes number of positive integers which are coprime with m and not greater than given int m.
Special: Fermat's little theorem... if p is prime, p and a coprimes, then a^{p-1}\equiv 1 (mod\ p)
...and... \varphi(p^{2})=p^{2}-p
Know one solution p=3, but I got it by assumption. :((
Thanks in advance!
Thanks in advance!
Hi there (=
I'm also new to number theory.
May i check with you if the primes that satisfy the above condition is 2 and 3?
I am writing my full proof as i am living in(asia) different GMT from yours.
<Question : Determine all prime numbers p so p2 divides 5p2+1.>
By Fermat's Little Theorem,
5^p is congruent to 5 (mod p) (1)
Which suggest that 5^{p.p} = 5^{p}^{2} is congruent to 5 (mod p) as stated in (1).
Since 5^{p}^{2}+1is divisible to p^{2} ;
Therefore, 5^{p}^{2}+1 is divisible to p ;
5+1 (mod p) is congruent to 0 (mod p)
Thus, 6 is a multiple of p .
pk = 6=2*3 with k is an element of integer.
By Euclid's Lemma,
Therefore , p can be either 2 or 3.
Well, thanks a lot, it seems correct!
Meanwhile, I did it too...
According to Euler's Theorem:
5^{p^{2}-p}\equiv 1(mod\ p^{2})
5^{p^{2}}\equiv 5^{p}(mod\ p^{2})
5^{p^{2}}-5^{p}\equiv 0(mod\ p^{2})
5^{p^{2}}+1-(5^{p}+1)\equiv 0(mod\ p^{2})
So, if 5^{p^{2}}+1 is divisible by p2, then 5^{p}+1 must be, too.
Now, using Little Fermat's Theorem:
5^{p-1}\equiv 1(mod\ p)
5^{p}\equiv 5(mod\ p)
5^{p}-5\equiv 0(mod\ p)
5^{p}+1-6\equiv 0(mod\ p)
If 5^{p}+1 is divisible by p, then 6 must be divisible by p. The only prime numbers which satisfy this are, as you proved, p=2 and p=3. But, if we check it with 1st statement, we'll see that p=3 is unique solution in N field.
Thank you once again, cheers! :))
For p=2,
p^2|5^p^2+1
is 156.5
Now, I haven't studied number theory, but isn't the definition of "divides" that the solution be a whole number? Which, as you can see for p=2 it is not.
Mentallic said:
For p=2,
p^2|5^p^2+1
is 156.5
yes you are right I've forgotten to check with the first statement (=
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
