Which variables determine the exact output of this condensing device?
The discussion revolves around the efficiency and design variables of an Atmospheric Water Harvester (AWH) device. Participants explore the mechanisms of condensing water from humid air using temperature differences created by heating and cooling air streams. The conversation includes theoretical considerations, practical challenges, and the implications of various design choices.
  • One participant suggests that running hot humid air over cool air is an efficient mechanism for water harvesting, questioning the main variables affecting output.
  • Another participant argues that heating humid air does not increase water mass and emphasizes the need to cool the air below its original temperature to achieve condensation.
  • A clarification is made regarding the system design, stating that hot air is generated through a solar collector and cool air is produced by a fan, with both air streams intended to create condensate.
  • Concerns are raised about the effectiveness of heating air without a source of moisture, with some participants questioning the logic behind this approach.
  • One participant expresses confusion about the factors dictating condensate output, suggesting that mass flow rates of air streams are critical and seeks a proportionality equation relating these variables to output.
  • Several participants challenge the assumption that heating air will aid in condensation, emphasizing the importance of cooling the humid air to below the dew point temperature.
  • Disagreements arise regarding the potential for condensation from the described system, with some participants asserting that the design may be fundamentally flawed without a reliable source of cold air.
  • Participants discuss the implications of using a fan to create cooler air, with some arguing that it does not effectively lower the air temperature sufficiently for condensation to occur.
  • One participant suggests exploring pressure reduction as a method to condense water, indicating alternative approaches to the problem.
Participants express multiple competing views regarding the effectiveness of the proposed AWH design. There is no consensus on the best approach to achieve condensation, with ongoing debate about the roles of heating and cooling air streams.
Participants highlight limitations in the current design, including the need for a reliable source of cold air and the potential misunderstanding of how temperature differences affect condensation. The discussion reflects various assumptions about the mechanisms involved in atmospheric water harvesting.
anikad
TL;DR
I'm looking to discuss the main variables that define the output/yield of a Atmospheric water generator device.
Good day all:smile:!
I've been researching on 'Atmospheric water harvester' (AWH) devices.
As I researched many functioning mechanisms on such devices, the most workable mechanism to me seems to be the one illustrated in the picture attached to this thread. (i.e running hot humid air over cool air using renewable energy source & collect the condensing water output.)
So my questions are twofold:
1) Am I right in thinking that this mechanism could be the most efficient to harvest water with no outside interference?
2) And what are the main variables that would affect the condensing water output we can get ..
In my mind, I suppose: the more mass volume of both hot & cold air we can get in contact per unit time, the better the condensing output?
Thanks a lot in advance for your input!
P.S: I'm new to the forum, but I intend to stick around & be an active participant here!
Welcome to PF.
You do not show where or how the humid air enters the system.
You do not show where the cool dry air is released.
Heating saturated air will not increase the water mass contained. You must cool moist air below the original cool entry temperature to get condensate out.
Heating air will reduce the Relative Humidity, but I see no liquid water supply available to saturate the heated air.
Thank you for your reply! Let me clarify the system.
The air is first made hot through solar collector on top part of the system.
The fan on the lower side of system sucks in ambient air & produces the cool air.
Both the hot humid air & cool air are made to get into contact, thereby generating the liquid condensate that is collected on the bottom.
Am I right to think that if I manage to create a system that generates more hot humid air from the top part per unit time, & simultaneously generate more cool air per unit time, I can keep increasing the condensate quantity?
If so, what would be the key constraints & other variables that affect the output.
Thanks again for your help. :smile:
Why heat the air coming in ?
You will only have to cool it down again below the input temperature, to reach 100% RH and so condense out some of the water as liquid.
The air is heated because as you mentioned earlier, the heated air has low RH. So the hot air (with the help of strong adsorbent material) sucks in moisture from ambient air outside in order to generate a flow of hot & humid air.
Am I still missing something?
Unless you are passing the heated air over a source of water (like heated sea water) it makes no sense to heat it. It will not "suck moisture" from the ambient air in a meaningful way.
The thing that's confusing me is what's exactly dictating the condensate output of this simple system.
My intuition tells me its the mass flow rate of both the hot, humid stream of air into the cool air stream in the heat exchanger.
I'd appreciate if you could confirm that or otherwise, & perhaps give a crude proportionality equation relating variables of this system & the condensate output.:smile:
Thanks for your input!
The idea was since this system would work under sunlight, we need to heat the air at one end & cool it at the other to create the temperature difference for condensate.
Since, the heated air will contain less water, the adsorbent material will suck some moisture from ambient air to compensate for us reducing moisture by heating the air.
In your suggestion- just increasing the ambient air mass flow rate (without heating it) in the heat exchanger would do the trick in increasing the condensate output?
You need to cool the humid air. If you cool it more (to a lower T) or cool more of it you will obtain more water. Heating it will not help.
The question is: what is your source of "cool"?
A simple fan at the bottom part of the system produces a cooler stream of air.
That's why I thought heating the air will create a greater temperature difference to increase water output. ( When you say cool it more, I suppose you're talking about a temperature difference too ?)
If you could share a simple physics equation that combines all those factors, that would solve the system design issue in a heartbeat.:smile:
A fan makes moving air but not cooler air. It feels cooler to use because it carries away our body heat via convection at skin and evaporation of sweat.
I fear this design is fundamentally flawed unless you have a ready source of cold air. Sorry.
The fan produces 'cooler air' because it's protected from the top part of the system that is directly exposed to sunlight.
I understand it will create a temperature difference just fine?
The cool air must have a temperature below the dew point temperature (look it up! ). The ambient temperature will necessarilly not get you that cold or you would have fog everywhere. This will not work as you envisage it.
Thank you for your input.
I disagree respectfully:smile:, because if I understood the laws of physics correctly, a hot stream of air combined with ambient fan should create condensation.
Can any other fellow member who's well versed in the topic please prove or disprove my point?
PPMs are not allowed on this forum; you are perilously close to suggesting "something for nothing." See evaporative cooling, phase changes, latent heat,...
I don't mind a disagreement, and you are free to waste as much of your own time as you wish.
Please let me know how this works out.
What's the source of the diagram ?
[edit: it doesn't show the flow of the ambient air, only "recirculating air" ; can't find it on the web, either]
I cannot see how you could get any water condensate from the device as it is designed.
Has it yet produced a single drop? That would be a zillion times more efficient than zero.
I would look at using a pressure reduction to condense water, then pump the pool of liquid water from the low pressure chamber, before allowing the pressure to rise again.
Hi, thanks for your input.
The device design is from Google (Alphabet) which they open-sourced recently.
For the hot air input, the ambient air is just sucked in from outside the device.
For the cool air input, the ambient air is again sucked in via a fan at the bottom.
Quite interesting! Can you explain a quick physics mechanism as to how pressure reduction condense water or share a suitable link on the web?
& is it a more (or less) efficient mechanism to condense water than the temperature drop / temperature difference method we're discussing from the device above?
A variation comes to mind than MIGHT be an enhancement.
Having the Hot air flowing over the Absorbent bed may improve the moisture extraction. But then again, you are heating the incoming cool moist air, which makes it less likely to give up its moisture.
It looks like you will just have to build the thing and try it, rather than have it play mind games with you!
And please let us know what you find, it could turn out to be useful.
Cheers,
Tom
p.s. Maybe it needs to be a batch process rather than continuous. Run the incoming ambient over the absorbent to saturate it, then run heated air over the absorbent to extract the moisture for the cold plate.
ffffs. The lengths people will go not to worry the pretty little heads with such inconveniences as "science" is unbelievable.
Yeah, and thanks loads for making me have to google for the original link.
Garbage article from google/x-company ; it does contain a larger resolution diagram of the device where - given an existing (but shallow) knowledge of the existence of desiccation dehumidifiers - it's easier to figure out what's actually happening
A directly related article/paper in Nature which looks possibly interesting and I might read tomorrow if the headache from looking at the crap article subsides.
It's a desiccant dehumidifier : they exist ; I think the "new" thing is the man-portable paradigm.
The inside air and the outside air do not mix.
There's a turntable (close to the B mark on the diagram) which contains a desiccant.
As it turns, outside air is blown across the surface, which sucks out some moisture because that's what desiccants do. (The outside air then leaves the device, never to be seen from, again).
It continues to turn, the slightly soggy surface passing through the curtain to the inside, where hot(ter) internal air is blown across it, evaporating some of the water. The particular patch of turntable we're looking at then returns to the outside as fresh, shiny and dry.
Meanwhile the inside air goes and does the heat exchange thing, which cools it and causes some of the water vapour to condense. It then returns (through the other side of the heat-exchange) to the turntable.
Yes, it works. The article says so, and even says the prototype does "150ml/h/m^2", though it mentions neither what the m^2 refers to (presumably one of either heating or desiccant surfaces), nor the environmental conditions under which the measurement/calculation took place.
Efficient ? compared to what ?
It doesn't look like a prototype so much as a proof of concept. In my pretty much totally uneducated-on-the-subject-matter opinion it could be done without the fans, though : probably less efficient, but niftier IMHO. On the other hand, you could use the (presumed) solar panels which run the thing to charge a cellphone to call for a pizza. That bit's efficient in respect that the waste heat from electricity generation is actually being used (to heat the internal air).
Not to denigrate the people who designed and put it together; I'm not going to pretend I could do it.
  • Love
Cheers,
Tom
Hi Tom,
Yes, that's my exact goal to build this system.
I am just hoping to get key physical relations behind the heat exchanger mechanism of the device that's in accordance with the laws of physics. (so that I know what to focus on to increase the yield of condensate output)
But no luck so far- some members above even claim I'm trying to build a PPM, which obviously it isn't by any stretch.
hmmm27 said:
ffffs. The lengths people will go not to worry the pretty little heads with such inconveniences as "science" is unbelievable.Yeah, and thanks loads for making me have to google for the original link.
Thanks for the details.
If I'm correct, the following dependencies hold true as relating to condensate output:
1) The hotter the inside air blowing- the more it can extract moisture & the more the yield.
2) The more rounds of heat exchange process takes place per unit time, the more the yield.
3) The lower I can get the temperature of the ambient air on the bottom, the more the yield.
Is that true? If there's some physics wizard in here, an exact equation relating all those variables in the system would help massively!
Tom.G said:
I recall there was a much older thread here that referenced the turntable dehumidifier, but I can't find it now.
Here are a couple slightly related threads that you might find interesting:
https://www.physicsforums.com/posts/6264085/
https://www.physicsforums.com/posts/6194175/
Cheers,
Tom
Thanks for sharing that!
If I understand correctly, these devices will not produce condensate at night , since there's no solar power to heat the turntable dessicant (and thus no temperature difference) ?
  • · Replies 16 ·
  • · Replies 19 ·
10K
  • · Replies 152 ·
12K
