Who can find the largest prime number with their own programmed code?
  • Context: Python
  • Thread starter Thread starter Kekkuli
    Prime numbers
The thread discusses a playful competition to find the largest prime number using programmed code. Participants share their findings, algorithms, and methods for identifying prime numbers, including the use of the Sieve of Eratosthenes and Mersenne primes. The discussion encompasses both theoretical and practical aspects of prime number discovery.
  • One participant found the prime number 2249999999999999981 using a Python implementation of the Sieve of Eratosthenes.
  • Another participant referenced the largest known prime number, 2^(82,589,933) - 1, obtained through a shell script.
  • Multiple participants reported finding the number 18446744073709551557, with one noting an overflow issue with 64-bit integers.
  • There is a discussion about the nature of factorials, with participants correcting each other on the properties of numbers related to factorials and their primality.
  • One participant suggested that the Lucas-Lehmer test is the best-known method for finding large Mersenne primes, detailing its implementation and performance considerations.
  • Another participant shared a link to their algorithm that computes primes up to 2^64-1, reiterating the previously mentioned largest prime found.
  • There is a debate about whether 2^18446744073709551557 - 1 is prime, with participants clarifying the conditions under which Mersenne primes exist.
  • One participant humorously noted the competitive nature of finding large primes, suggesting that computational power is a significant factor in this pursuit.
Participants express a variety of viewpoints regarding the methods and results of finding large prime numbers. There is no consensus on the largest prime number found, and discussions about the properties of factorials and Mersenne primes reveal differing understandings and assumptions.
Some discussions involve assumptions about the nature of prime numbers and the effectiveness of various algorithms. The complexity of finding large primes and the limitations of computational resources are also acknowledged.
This discussion may be of interest to programmers, mathematicians, and enthusiasts in number theory, particularly those focused on prime number discovery and computational methods in mathematics.
Kekkuli
I announce a playful competition :smile: Who can find the largest prime number with the programmed code? I found the number 2249999999999999981 with the Python code. I first tabulated the truth value of the prime numerosity of numbers smaller than 1.5 billion using Erasthonene's sieve, and then I started to study numbers from 1.5*1.5 billion downwards.
[CODE lang="python" title="Big Prime number"]import math
maxind = 1500000000 # let's calculate prime numbers smaller than 1.5 billion
primesarray = [True] * (maxind + 1)
amount = maxind
number = 0
ind = 0
squareroot = 0.0
candinate = 0
helper = 0def is_prime_number(num):
if num % 2 == 0:
return False
else:
index = 3
itis = True
while index <= math.isqrt(num) and itis:
if primesarray[index]:
if num % index == 0:
itis = False
print(index)
index += 2
return itisamount = maxind
squareroot = math.isqrt(amount)
for ind in range(2, maxind + 1):
primesarray[ind] = True # let's suppose all are primes
primesarray[1] = False
number = 2
ind = number
while ind <= amount:
primesarray[ind] = False # remove 2's multiplies
ind += 2
while number < squareroot:
while primesarray[number] is False and number < squareroot:
number += 1 # let's find next prime number
ind = number + number
while ind < amount: # remove its multiplies
ind += number
number += 1
primesarray[2] = True
# Prime numbers smaller than a billion have now been tabulated.
# Let's print a hundred smaller ones as a test.
for ind in range(1, 101):
if primesarray[ind]:
print(ind)
# let's examine candidate number
helper = 1
while helper < 20:
candinate = maxind * maxind - helper
if is_prime_number(candinate):
print(candinate, ' is a prime number.')
else:
print(candinate, ' is not a prime number.')
helper += 2
[/CODE]
Technology news on Phys.org
Bash:
#!/bin/bash
wget -q -O - 'https://html.duckduckgo.com/html?q=the%20largest%20known%20prime%20number' | sed 's|<[^>]*>||g' | sed 's|\s+| |g' | grep -P 'the largest known prime number is [^a-z]+' | sed -E 's|.+(the largest known prime number is [^a-zA-Z]+).+|\1|'
Result: the largest known prime number is 2^ (82,589,933) - 1.
What do I win? :smile:
  • Haha
I found 18446744073709551557 before I overflowed 64 bits.
Thanks! That is just what I needed when I was looking for the prime factors of 340282366920938461286658806734041124249! . ;-)
CORRECTION: The '!' was meant to be an exclamation mark, not a factorial.
FactChecker said:
... I was looking for the prime factors of 340282366920938461286658806734041124249!
Like all factorials, that must be composite.
Sorry. Not a factorial. I should have ended it with a period.
We must watch these things.
An exclamation needs to be a short and immediate reaction.
Assuming a number is a square, s = n2.
The factor n will occur exactly twice in s.
But how many times will the factor n occur in s! (yes, the actual factorial) ?
##n+1## times?
It depends whether ##n## is prime. Otherwise, you could get a factor of 10, say, from 2 times 5.
PeroK said:
It depends whether n is prime. Otherwise, you could get a factor of 10, say, from 2 times 5.
So the count would increase.
Does it get any easier if you reduce s! to its prime factors ?
If n was prime, there would be n+1 occurrences.
If n was composite, there would be zero occurrences.
If ##n## is composite, it gets complicated!
PeroK said:
If n is composite, it gets complicated!
What is the factorial of complicated ?
Another related mental exercise.
Under what conditions can a factorial also be a perfect square ?
Never, except the trivial case of 1. This is because you would need even powers of every prime factor, but you always have an odd power of the last prime in the factorial.
Or zero.
Vanadium 50 said:
Or zero.
##0! =1##
  • Wow
A full proof based on this observation requires Bertrand's postulate:
https://en.m.wikipedia.org/wiki/Bertrand's_postulate
PeroK said:
0! =1
Yes, and 0! is exactly as much of a perfect square as 1!, no?
My reaction is, who cares? It's going to depend on how powerful a computer you can run it on, as much as the algorithm (as @Baluncore showed in post #3) and someone is always going to have a bigger and faster computer.
  • Sad
They are the same perfect square.
Why yes. Yes they are.
phinds said:
... and someone is always going to have a bigger and faster computer.
With only one exception, the one with the biggest computer.
Until it isn't any more
The best known way to find large primes is the lucas-lehmer test for mersenne primes (primes of the form 2^p-1 where p is a prime).
This is actually quite simple to do
Python:
# returns True if  2**p -1 is a mersenne prime, false otherwise
# assumes p is prime
def is_mersenneprime(p):
    if p==2:
        return True
    mp = 2**p -1
    m = 4
    for _ in range(p-2):
        m = (m*m-2) % mp
    return (m==0)
python has unlimited integers and I believe uses Karatsuba multiplication, so this should run in O(p^3.58)
running this for p<1000 <1 second
running this for p<10000 14 minutes
running this for p<10^8 10^9 years.
you should really install mpz at this point, to use FFT multiplication and O(p^3) time
Of course the GIMPS project has been at this since 1996 with ~10^5 cpu cores, so it's rather hard to get ahead of this.
https://www.mersenne.org/
So wouldn’t 2^18446744073709551557 -1 also be prime?
Why do you think that?
Misremembering Mersenne primes, somehow thought 2^prime -1 was also prime
With Mersenne primes 2^p-1, p is indeed always prime, but the opposite does not necessarily hold true. Large Mersenne primes occur rather sparsely, the biggest tested so far is 2^82589933 - 1. So, some way to go until we know. :smile:
Still waiting on my code to finish running, but sure its going to be a winner
for i=82,589,933:1,000,000,000
X(i)=[(2^i)-1*isprime(2^i)-1]
end
max(X)
  • · Replies 36 ·
  • · Replies 34 ·
  • · Replies 97 ·
10K
  • · Replies 16 ·
