Why are 4 different thermodynamical potential?
  • Thread starter Thread starter kompabt
    Potential
The discussion centers on the existence of four thermodynamic potentials—internal energy, enthalpy, Helmholtz free energy, and Gibbs free energy—each serving different applications based on the variables involved. These potentials are Legendre transforms of one another, allowing for flexibility in problem-solving depending on controlled variables like pressure and temperature. The conversation highlights the importance of understanding which potential to use in specific scenarios, particularly in chemical engineering where enthalpy and Gibbs free energy are most relevant. There is debate over the necessity of Legendre transforms in defining these potentials, with references to various textbooks and sources that either support or refute this concept. Ultimately, the choice of thermodynamic potential is determined by the specific conditions and variables of the problem at hand.
kompabt
What is the reason that there are 4 different thermodynamical potential?
How can I know, which of them should I use?
the 4 functions are Legendre differential transforms of each other,and are functions of different sets of variables
Use will be according to the problem.
For eg, H=H(S,P),ie Enthalpy is a function Of pressure,and can be used in problems where pressure is a controlled variable/independent variable.
Simmilarly the Gibbs function,G=G(P,T) can be used for processes where temperature and pressure are independent variables
for a good summary,refer to the thermodynamics text by Zemansky and Dittman,or the Mathematical Methods text by Margenau and Murphy
the Legendre transform in thermodynamics is Science Fiction. see
https://www.physicsforums.com/showthread.php?t=313535&referrerid=219693
pabloenigma said:
Use will be according to the problem. For eg, H=H(S,P),ie Enthalpy is a function Of pressure,and can be used in problems where pressure is a controlled variable/independent variable. Simmilarly the Gibbs function,G=G(P,T) can be used for processes where temperature and pressure are independent variables.
Enthalpy H (note: look for H(S,p) written as an explicit function of S and p: nowhere to be found) is a function of the external pressure: this can be considered an independent variable, but is best considered as a (commonly constant) parameter. Similar for G where p and T are the parameters.
compare this to this discussion:
https://www.physicsforums.com/showthread.php?t=456648&referrerid=219693
Zemansky & Dittman (1981) say nothing about a Legendre Transform.
Leave Margenau & Murphy to the mathematicians.
See for instance, Claude Garrod, Statistical Mechanics and Thermodynamics pp. 148 or F. Schawbl, Statistical Mechanics pp. 77. Both books write down H(S,p).
Sir,i will read your link later,and reply.But even Callen,and the Mechanics text of Herbert-Goldstein,affirms the use of Legendre transforms in definition of these functions.and even if there is reason enough to think,LT is not needed in definition of these potential functions,I gez its best not to confuse the person who asked this question,coz it does seem he is a beginner
And The 7th edition of Zemansky Dittman,which I own,does say about Legendre transforms.And as far as I know,Margenau and Murphy is not so much a text for mathematicians,its a Mathematical Methods text for Physicists.But then,I'm just a college Junior.
Both Zemansky-Dittman(7th edition) and Herbert Goldstein write down H(S,P).
where dH is given by TdS + VdP
if dH=TdS+Vdp then it seems to me that H=H(T,S,V,p) ie a function of 4 variables: according to the prevailing theory only two variables are independent though.
Since H is commonly applied in conditions of constant pressure, it might be admissable to eliminated p from the list: now you are left with H(T,V,S).
Zemansky-Dittman (1981) gives the same equation but without reference to a Legendre transform.
the book of Goldstein (1950) is not about thermodynamics but about classical mechanics and I do not believe Goldstein can claim any authority in the field of thermodynamics.
He does not provide any proof that H or G are Legendre transforms either: its a suggestion at best.
espen180 said:
Please see the following Wikipedia articles to see how the Gibbs free energy and the Helmholtz free energy are obtained from the internal energy via Legendre transforms.
http://en.wikipedia.org/wiki/Gibbs_free_energy#Derivation
http://en.wikipedia.org/wiki/Helmholtz_free_energy#Definition
http://en.wikipedia.org/wiki/Legendre_transformation#Thermodynamics
the wiki about enthalpy does NOT refer to the Legendre transform at all.
The wiki on Gibbs free energy does in the derivation, but all textbooks published before 1960 and most textbooks published after 1960 (eg Smith & VanNess) do not need the Legendre transform but are still able to derive the same equations.
This seems to be a valid question, and not only for beginners.
By calling U,H,G and F thermodynamic potentials and/or calling them Legendre transforms it seems that they are more or less equivalent to each other. This is not the case.
Internal energy and enthalpy are forms of energy that show up in the energy balances of systems. However, the energy (U,H) of these systems is not equal to the capacity to do (usefull) work: this quantity is given by G, assuming a given T and p of the environment. (For systems at constant V, F is used, but this function is used very little.)
In chemical engineering only H and G are used, for all practical purposes.
T and V are equivalent to (\partial H/\partial S)_P and (\partial H/\partial P)_S, respectively. There are only two independent variables.
No one here has claimed that the thermodynamic potentials are "more or less equivalent to each other."
Zemansky-Dittman(7th edition) makes an EXPLICIT reference to Legendre Transforms.
Zemansky died in 1981, so the 1981 edition is the last one he aproved of: others have tampered with is legacy, and if he knew he would have turned in his grave. The first part is a fact, the second part is an opinion ofcourse.
yes,Mark Zemansky died.But Richard H Dittman is alive,and he updated this edition.He mentions the use of Legendre transforms among the valuable additions to this edition.
Sorry,if I sound rude,but the thing is,it does seem,you understand Zemansky more than Dittman...
