- 19,920
- 10,968
Borek said:LOL, that would mean old problems with preview are still here![]()
hmmm I can't reproduce this problem on FF 4.0.1
The discussion revolves around issues related to the implementation and functionality of MathJax for rendering LaTeX on a webpage. Participants explore the display of mathematical expressions, the transition from image-based rendering to MathJax, and the implications for users and server load. The scope includes technical troubleshooting, user experience, and the rendering of various LaTeX environments.
Participants express a variety of opinions regarding the functionality and appearance of MathJax. There is no consensus on whether the changes are beneficial or detrimental, and multiple competing views remain regarding the effectiveness of MathJax compared to previous methods.
Some participants note that certain LaTeX environments and features may not be supported, and there are unresolved issues regarding the rendering of specific mathematical expressions. The discussion reflects a range of user experiences and expectations regarding the transition to MathJax.
This discussion may be useful for web developers, educators, and users who rely on LaTeX for mathematical expressions in online platforms, particularly those interested in the technical aspects of rendering and user experience with MathJax.
Greg Bernhardt said:hmmm I can't reproduce this problem on FF 4.0.1
vela said:Do you have an add-on installed that might be causing the problem?
I see the same behavior with Safari. MathJax runs when the browser says it's done processing the page. Apparently, saving the edited post doesn't cause the browser to send this signal, which makes sense since if you have a script that runs when the page finishes loading, you probably don't want it to run again if you modify just a small piece of the page. So the text of the edited post doesn't get processed.micromass said:The weird thing is that the same problem also occurs on IE. So I don't think add-ons will be the problem.
Also, if I edit the post, then only the LaTeX of the edited post doesn't work. All other LaTeX formulas work fine...
vela said:I see the same behavior with Safari. MathJax runs when the browser says it's done processing the page. Apparently, saving the edited post doesn't cause the browser to send this signal, which makes sense since if you have a script that runs when the page finishes loading, you probably don't want it to run again if you modify just a small piece of the page. So the text of the edited post doesn't get processed.
EDIT: Firefox on the Mac acts the same way as well.
Borek said:Yes, that's the thing - refreshing works, quick edit doesn't.
So when it comes to preview we are back at square one.
I don't follow your logic. In fact, testing preview directly contradicts your conclusion.Borek said:LOL, that would mean old problems with preview are still here![]()
Greg Bernhardt said:There has never been preview for quick edit.
Fredrik said:I've had the same problem as Micromass since we made the move to MathJax. Every time I save an edit, I only see the source code. (Previews work fine. The problem is that when I view the post after saving the changes, I only see source code). A refresh solves the problem.
This isn't nearly as annoying or confusing as the old preview problem, which required a refresh after each preview. It also required me to explain it to someone else once a week.
OK, I just did some testing, and I don't have this problem at all. I guess I just remembered it wrong when I wrote the above. There is no problem if I preview before I save the changes. The only time I see the source code instead of an image is when I just click edit, change something, and then click save. Both FF4 and IE9 behave the same way.Fredrik said:Every time I save an edit, I only see the source code. (Previews work fine. The problem is that when I view the post after saving the changes, I only see source code). A refresh solves the problem.
I think it would be awesome if something like that could be implemented.vela said:Any thoughts on adding new delimiters for TeX code? MathJax supports multiple delimiters, so it won't break existing posts. Plus, it's faster typing something like $$ than the current tex and itex tags.
Daiquiri said:I can't see the "Sigma" icon for creating LaTex code, even in advanced text mode...
I am open to suggestions for additional delimiters.AlephZero said:The think that really bugs my typing is the foward slash in the closing tags and the backwards slash in LaTeX. [ \ tex ] (without the spaces!) as an alternative end tag would be nice.
Redbelly98 said:Hey, I'm glad to see that equations are automatically indented under the new implementation -- I'm pretty sure this was not the case before.
Fredrik said:I suggest
$f$ as an alternative to [itεx]f[/itεx]
$$f$$ as an alternative to [tεx]f[/tεx]
(I couldn't figure out how Borek did his magic so I just wrote ε instead of e to let you see what I wrote).
That first one might break a few old posts, but it still think it's the best option, since it's easy to type, and also what you actually type in a LaTeX document.
It not only breaks existing posts, but, as AlephZero noted, it makes it difficult to type a dollar sign when you want a dollar sign. Something like $$ and @@ would be better, or $$ and $$$.Fredrik said:That first one might break a few old posts, but it still think it's the best option, since it's easy to type, and also what you actually type in a LaTeX document.
Fredrik said:Yes, but this is a physics and math forum, not a forum for American accountants.I'm assuming that they can write something like \$3.50 instead of $3.50, and if that doesn't work, they can always write 3.50 USD.
(I'm not saying that I would find other options intolerable, only that I still like my suggestion best).
