Why can't hexane or toluene solutions dissolve in aqueous bromine?
  • Thread starter Thread starter redpower
    Aqueous Dissolve
Hexane and toluene do not dissolve in aqueous bromine due to their non-polar nature, which prevents them from mixing with the polar aqueous solution. During the experiment, hexane and bromine formed distinct layers, indicating immiscibility. Although both hexane and bromine are non-polar, the presence of bromine in an aqueous solution alters its behavior, making it less compatible with non-polar solvents. The bromine's ionic state in the aqueous solution contributes to this lack of solubility. Understanding the interactions between polar and non-polar substances is crucial for interpreting these results.
redpower
I have just carried out a lab experiment today and desperately need some help!
1. The Experiment:
In my experiement I attempted to mix a solution of hexane with aqueous bromine. I started off by adding 15 drops of bromine into a test tube and then added 7 drops of hexane ontop of that. Prior to shaking, I could see two distinct colours in the test tube separated by a meniscous: the yellow bromine liquid lied at the bottom and the clear + colourless hexane solution lied on top of the bromine. After shaking, something odd happened. The two layers switched places => bromine ended up on top and hexane resided at the bottom of the test tube. The two colours were still distinct and separated by a meniscous. (The same thing happened when I tried to mix toluene with bromine)
2. What I discovered
Seeing that these two solutions would not dissolve each other, I concluded that one of them must be polar and the other must be non-polar. (We have previously learned that only "like dissolves like") HOWEVER, after analysing the substances, I realized that hexane (a hydrocarbon) and bromine are BOTH NON-POLAR SUBSTANCES. If that is the case, they should have dissolved each other - but they didn't! Thus, I am in a dilemma right now and have no idea how to approach this lab.
Any help would be greatly appreciated! Thank you in advance!
Aqueous bromine is bromine dissolved in a water based solution. Usually HBr and H20. Your bromine preparation did not mix with either hexane or toluene because of their non-polar nature. They are non-miscible with water. Gaseous bromine, either Br2(g) or HBr(g), would dissolve however.
HBr in bromine solution? Some amount being produced in disproportionation - for sure, but this is not the main form of Br2 present.
I don't think that is right. If it were, the Br2 would have dissolved into the hexane or toluene. The Br was in an ionic state in the aqueous solution and that is why it didn't dissolve.
If it was ionic, how come solution was red?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
