Why do Fresnel rings appear in laser beam experiments?
  • Context: Undergrad
  • Thread starter Thread starter ppoonamk
    Fresnel Laser Rings
The discussion revolves around the appearance of Fresnel rings in laser beam experiments, specifically in setups involving a HeNe laser, spatial filters, irises, and lenses. Participants explore the causes of these rings and seek methods to achieve uniform illumination and a Gaussian beam profile.
  • One participant observes Fresnel rings in their setup and questions the influence of the iris size and distance on the number of rings.
  • Another participant suggests that the rings may be Airy rings resulting from imaging light through a small circular aperture, hypothesizing that fewer and wider rings could occur with a smaller iris.
  • A participant confirms that the rings appear due to the iris and notes that reducing the iris diameter results in smaller rings, while seeking alternative arrangements to the spatial filter and iris setup.
  • One suggestion involves using a single mode optical fiber to achieve a Gaussian beam profile, noting that this method may only transmit a fraction of the light depending on the incoming beam quality.
  • Another participant emphasizes that if the beam is already well-behaved after the spatial filter, lenses alone could be used for collimation and size adjustment, rather than relying on the iris.
  • A participant mentions that their beam is not Gaussian after the spatial filter and that they are only allowing a bright order through, indicating that the spatial filter does not fully clean the beam.
  • One participant raises the possibility that alignment issues or the positioning of components may contribute to the observed problem, particularly with a small aperture size.
Participants express varying opinions on the causes of the Fresnel rings and the effectiveness of different methods to achieve a Gaussian beam profile. There is no consensus on a single solution, and multiple competing views remain regarding the best approach to address the issue.
Participants mention specific equipment configurations and parameters, such as the objective's numerical aperture and aperture size, which may influence the discussion but are not fully resolved. The discussion reflects uncertainty about the effectiveness of various methods and the conditions under which the observations are made.
ppoonamk
Hi,
I have a very simple test bench set up with a HeNe laser, followed by a spatial filter, then an Iris and then a couple of lenses. I can observe many fresnel rings on my image plane. Changing the size of the iris, and its distance changes the number of of rings. I would like to know why this happens. Is there any way I can get uniform illumination from my laser? Is it because the spatial filter pinhole diameter is too big? It has a 40X, 0.25NA objective.
Science news on Phys.org
When you say Fresnel rings, do you mean the Airy rings you'll see when you image the light going through a small circular aperture? If I had to guess, I would assume these rings get fewer and wider the smaller the iris is?
Hi,
You are right! So I am quite sure these rings appear due to the iris I have in my setup. The rings get smaller as the diameter of the iris is reduced. Is there an alternative arrangement to the spatial filter + iris setup?
If you're looking to get a nice Gaussian laser beam profile, ring-free, I would try (if you have the equipment) to focus the light into a single mode optical fiber. You won't get more than like a third of the light through, depending on the quality of the beam coming in, The light coming out the other end will be ring-free, and already spatially filtered. After that, you can recollimate the beam by placing a lens a focal distance away from the output, and then you'll have a well-behaved Gaussian laser beam. (all this is easier said than done, of course).
If your beam is well-behaved and ring-free already after the spatial filter (but before the iris), you need only lenses to collimate and adjust the size of the beam.
This is all assuming that you're trying to adjust the size of a laser beam with irises. I would do it with lenses to collimate and magnify.
HI,
Thank you for your suggestion. I don't have a single mode optical fiber. Seems like a very good way to get a Gaussian. Are there other ways to do it?
If you see rings after the iris, but not after the spatial filter, I would just forget the iris and collimate with lenses.
Yes! I see rings only after the iris. But my beam after the spatial filter isn't a gaussian. There are other orders along with it. I clip the pattern to allow only the bright order through. The spatial filter setup alone does not clean the beam. I am using a 40X, .6 NA objective with a 10 um aperture iris.
At this point, I don't think I know enough about the light source coming into exactly solve your problem.
Maybe it's a matter of alignment; perhaps the distance between the spatial filter and your focusing lens isn't quite perfect, or the positioning is off slightly. With a 10 micron diameter, the translation in z where you're maximally focused is similarly small.
  • · Replies 58 ·
9K
  • · Replies 30 ·
