JR Sauerland said:
In the question, it actually did not even state that BC is the same length as BC or AD. The only time it actually stated that was after I opted to show the answer and solution... and I also don't fold papers in half or diagonally on my spare time so I wouldn't know that.
I don't either, but it makes sense that if you fold the corner B over to B' and crease the paper along the line stated, then clearly BC = B'C because you've just folded BC over to B'C.
JR Sauerland said:
But to answer your question, I had thought I was supposed to create an equation of opposite over adjacent, and take tangent of the angle to get B'D, and then from there I was lost.
That's also a valid method of solving for B'D, but it doesn't help with finding B'C (which we are doing so that we can find the dimensions of the paper since B'C = BC). The solution also opted to use the Pythagorean theorem to find B'D as opposed to using tan as you would have done, likely just to remind you that you can use it as it often goes hand-in-hand with trigonometry.
JR Sauerland said:
Additionally, instead of just randomly flipping the equation with no explanation, why couldn't they just phrase it a little differently? 1/COS(x) is the secant. If they would've literally just said to take the secant, which is hypotenuse over adjacent... Idk. I'm just not used to this type of problem I guess.
It's not randomly flipping. It's called taking the reciprocal and it's a valid operation.
If [itex]x=y[/itex] then I'm sure you'll agree that [itex]\frac{1}{x}=\frac{1}{y}[/itex]
Also,
[tex]\frac{1}{\left(\frac{a}{b}\right)}=\frac{b}{a}[/tex]
so the reciprocal is essentially flipping the fraction. Hence, if you have
[tex]\frac{a}{b}=\frac{c}{d}[/tex]
then we can take the reciprocal of both sides to get
[tex]\frac{1}{\left(\frac{a}{b}\right)}=\frac{1}{\left(\frac{c}{d}\right)}[/tex]
[tex]\frac{b}{a}=\frac{d}{c}[/tex]
But also multiplying both sides by the lowest common denominator which in this case is bd would also be a way of solving for a value that's found in the denominator. Cross multiplying is the quick way to think about this operation, just as how flipping the fraction is the quick way of thinking about taking the reciprocal.
Going from
[tex]\sec{x}=\frac{a}{b}[/tex]
straight to
[tex]\cos{x}=\frac{b}{a}[/tex]
would've likely caused confusion for other students too.
