Why Do People Say That 1 and .999 Are Equal? - Comments
  • Context: Insights
  • Thread starter Thread starter Multiple_Authors
The discussion centers around the question of whether the repeating decimal 0.999... is equal to the integer 1. Participants explore various arguments, proofs, and counterarguments related to this mathematical concept, touching on topics such as geometric series, assumptions in proofs, and the implications of different number systems.
  • Some participants argue that many proofs claiming 0.999... equals 1 rely on unstated assumptions and are therefore non-rigorous.
  • One participant suggests that a rigorous proof can be constructed using geometric series, asserting that the sum of the series representing 0.999... converges to 1.
  • Others challenge the validity of accepting that 0.333... equals 1/3 in the context of the debate, questioning the consistency of such assumptions.
  • Several participants express skepticism about the proofs that conclude 0.999... equals 1, suggesting that they may be flawed or based on incorrect assumptions, particularly regarding surreal numbers.
  • There is a repeated inquiry about how different 0.999... and 1 might be, with some arguing that as more nines are added, the difference approaches zero.
  • One participant emphasizes the need to be cautious about labeling other proofs as incorrect without fully understanding their arguments.
  • Some participants assert that if a proof can be applied to surreal numbers and still concludes that 0.999... equals 1, it must be incorrect.
Participants generally disagree on the equality of 0.999... and 1, with multiple competing views presented. Some argue for their equality based on mathematical reasoning, while others firmly believe they are not equal, citing various assumptions and interpretations.
The discussion highlights limitations in the proofs presented, including reliance on specific definitions and assumptions that may not be universally accepted. There is also an ongoing debate about the implications of different number systems, such as surreal numbers, on the validity of the proofs.
Multiple_Authors
Multiple_Authors submitted a new PF Insights post
Why Do People Say That 1 And .999 Are Equal?
Continue reading the Original PF Insights Post.
Mathematics news on Phys.org
While there are several arguments here that people might accept as proofs, they all, as stated, are non-rigorous, involving some basic, unstated assumptions. For example, in argument two, it is assumed that multiplying x= 0.999... by 10 gives 10x= 9.999... and then that subtracting x give 9x= 0.999... again. Both of those assume the usual arithmetic properties are true for 0.999... That is true but exactly the sort of thing people who object to "0.999...= 1" would object to anyway. In argument four, it is accepted that 0.333...= 1/3. Why would a person who objects to "0.999...= 1" accept that?
It is not too difficult to give a rigorous proof using "geometric series". It is easily shown that the sum \sum_{i= 0}^n ar^i is \frac{a(1- r^n)}{1- r}. To do that, let S_n= \sum_{i= 0}^n ar^i= a+ ar+ ar^2+ \cdot\cdot\cdot+ ar^n). Since that is a finite sum, the usual properties of arithmetic hold and we can write S_n- a= ar+ ar^2+ \cdot\cdot\cdot+ ar^n= r(a+ ar+ \cdot\cdot\cdot+ ar^{n-1}). The quantity in the last parentheses is almost S_n itself. It is only missing the last term, ar^n. Restore that by adding ar^{n+1} to both sides: S_n- a+ ar^n= r(a+ ar+ \cdot\cdot\cdot+ ar^{n-1})+ ar^{n+ 1}. Taking that last term inside the parentheses we have S_n- a+ ar^n= r(a+ ar+ \cdot\cdot\cdot+ ar^{n-1}+ ar^n)= rS_n. We can write that as rS_n- S_n= (r- 1)S)_n= ar^n- a= a(r^n- 1) and dividing both sides by r- 1, S_n= \frac{a(r^n- 1)}{r- 1} which, for r< 1 can be written more as S_n= \frac{a(1- r^n)}{1- r}
The geometric series, \sum_{i= 0}^\infty ar^i, is, by definition, the limit of the "partial sums", S_n= \sum_{i= 0}^n ar^i, as n goes to infinity. As long as |r|&lt; 1, \lim_{n\to\infty} r^n= 0 so that limit is easily calculated as \sum_{i= 0}^\infty ar^i= \frac{a}{1- r}.
Now, turning to the problem at hand. 0.999... is, by definition of the decimal numeration system, 0.9+ 0.09+ 0.009+ \cdot\cdot\cdot= 0.9+ 0.9(0.1)+ 0.9(0.01)+ \cdot\cdot\cdot= 0.9+ 0.9(.1)+ 0.9(.1^2)+ \cdot\cdot\cdot, precisely a geometric series with a= 0.9 and r= 0.1. So the sum, and the value of 0.9999..., is \frac{0.9}{1- 0.1}= \frac{0.9}{0.9}= 1.
Proofs #2 & #3 are what convinced me that 1 and .999... are NOT equal. It's just insulting to assume that .333... = 1/3 in this context. And why assume that .999... and 9.999... have different numbers of nines when this would never happen for any finite number?
I alread covered this in blog a while ago, though it's in spanish: https://preguntaspococientificas.wordpress.com
If they are different, how different are they? Suppose you say that they are different by more than 0.0001. Then 1 - 0.99999 is closer and the more 9's you add, the closer it gets. So you can not say there is any difference.
I'm not an expert on these things, but you can easily tell that a proof is wrong when it proves 0.9999...=1 on surreal numbers. Which most of the above do.
I'm not entirely sure about HallsofIvy's proof, it might be OK, even if I think it's swapping ##\infty## with ##\omega## somewhere along the way.
You can easily prove it by contradiction, as I indicated. Once that is done, you know that they are equal. Then I would to be careful about saying that other proofs are wrong unless I completely understood the other proofs and can pinpoint the error.
How is this assumption insulting. Just by ordinary division you can show that the 3 digit keeps repeating.
To the right of the decimal point, both have the same number of 9 digits. Also I don't understand what you are saying about "finite numbers". Both .999... and 9.999... are finite numbers; i.e., strictly less than infinity.
I did a quick scan of all of the proofs. None of them mentioned surreal numbers. If you can point out where I might have missed this, I would appreciate it.
Please show me where.
My idea was: if the proof, applied over surreal numbers, proves that 0.9999...=1, then the proof is not correct. There must be some implicit assumption.
HallsofIvy said:
Now, turning to the problem at hand. 0.999... is, by definition of the decimal numeration system, ##0.9+ 0.09+ 0.009+ \cdot\cdot\cdot## = ##0.9+ 0.9(0.1)+ 0.9(0.01)+ \cdot\cdot\cdot## = ##0.9+ 0.9(.1)+ 0.9(.1^2)+ \cdot\cdot\cdot##, precisely a geometric series with a= 0.9 and r= 0.1. So the sum, and the value of 0.9999..., is \frac{0.9}{1- 0.1}= \frac{0.9}{0.9}= 1.
I would say that, by definition of the decimal numeration system, 0.9999...=##\sum_{n=1}^\omega{}9\ 0.1^n## rather than ##\sum_{n=1}^\infty{}9\ 0.1^n##. The difference is, obviously, 0 in real numbers.
Why would the proof need to invoke surreal numbers? The proofs are all concerned with two representations of the same real number.
And that's the set we're concerned with here.
If the proof can be used to prove a false statement, then the proof must be wrong.
0.9999...##\neq##1 in surreal numbers, so if the proof works with them too, then it's wrong.
I dare say that all of the "informal proofs" from the article immediately work with surreal numbers, so they must be wrong.
This quote from the original article,
Can we define number systems such that 1=0.999… does not hold? Of course!
seems to be the answer that people are looking for, together with "Real numbers are defined in such a way that 0.999...=1".
So does this mean that .99999... = .99999...8 ?
No, because the right hand side is nonsense. You can't have a non-terminating run of nines and then terminate it.
Okay... but it seems like to make .999 = 1 you also have to terminate the run of nines. Anyway I know this has been discussed several times so I'll read up some more.
As already mentioned, the right side is meaningless for two reasons. On the left side the ellipsis (...) means that the pattern you see repeats endlessly. On the right side, it is not known how many 9s there are in front of the final 8 digit.
Don't confuse .999 with .999... They mean two very different things. The first is identical to 999/1000 which is smaller than 1, and the second is equal to 1.
SlowThinker said:
I'm not entirely sure about HallsofIvy's proof, it might be OK, even if I think it's swapping ##infty## with ##omega## somewhere along the way.
*Both .999… and 9.999… are finite numbers; i.e., strictly less than infinity.*
How can you call 0.999... or 9.999... as finite?
If these are finite then infinity can also be considered finite!
Please look up the definition of a finite number. There is a difference between an infinite _decimal expansion_ and an infinite number.
WWGD is correct. Finite numbers are bounded; infinite numbers are unbounded.
They are clearly different but if you're approximating, they're almost equal.
Who are "they"? Are you referring to .999 and .999... ?
Clearly these two numbers are close, but that's not the point. What we're saying is that .999... is identically equal to 1, and .999 is smaller than 1 by .001.
I have no way to say this is true for sure, but it appears to me as though proof #3 is based off an incorrect assumption. Wouldn't the difference between .999... and 1 be infinitesimal, not 0. Isn't this one of the reasons we have the concept of infinity, and in this case an infinitesimal value. If something infinitesimal is just considered 0, wouldn't a Riemann sum not mater at all, and just be equal to zero? Wouldn't that make anything using dx, dy, etc. represent a change of zero, as they are defined as an infinitesimaly small change in their respective variable? This is just my thinking, I am not being ignorent, I just want to understand.
Both are true. The important part is that real numbers are not precise enough to distinguish an infinitesimal difference - which is, in fact, the reason why we can use infinitesimals to integrate and derive expressions containing real numbers.
I would think this whole theme is answered by:
The definition of real numbers says that $$0.999..._{\text{as real number}} \ =_{\text{acting on real numbers}} \ 1_{\text{as real number}}$$
If you don't like it, use other numbers.
I think equivalence is more intuitive if you simply state that the limit of 0.999... as we keep adding more decimal places is 1. I think this is also a closer translation of the mathematical statement into plain english.
I think that is exactly my point. If we call limits being equal to, in the equation for derivatives, lim Δx→0 (f(x+Δx)-f(x))/Δx (I know I may not have written it right), the answer would be undefined.
No, they are not different as Real numbers using the definition of Real numbers in terms of Cauchy sequences. This is a technical point that requires the use of precise definitions.
this question never dies. this is basically why people cannot tell the difference between a good car and a car that says "BMW" on the side, i.e. its not all about the notation. but for some reason they are willing to allow the same car to be called a bmw or a beemer, but a number can't have two names. still the same people who admit that .33333... = 1/3, will not accept the result of multiplying this equation by 3.
I agree with Mathwonk. It is a very narrow view of what a number is. A number is not a unique object, but instead an equivalence class of objects. Under this equivalence relation, the two, 0.99999... and 1 are equivalent, and so considered equal. Maybe similar to the fact that if today is Wednesday, then every day that is ## \pm 7k ## days from today is also a Wednesday, and not just that today , 12/9/2015 is Wednesday, so no other day can be a Wednesday . Equivalence is very close conceptually to equality but it is not quite the exact same thing.
I think a key point is that .999... is by definition a limit, and that limit is equal to 1.
True, it is the limit of a Cauchy sequence, which converges by the fact that the Reals are a complete metric space, and the sequence, as you said, converges to 1.
  • · Replies 27 ·
  • · Replies 26 ·
  • · Replies 105 ·
14K
