Why do some devices work for a short time after unplugged?
Some devices, like laptops and monitors, can briefly function after being unplugged due to residual charge in capacitors. This phenomenon is often mistaken for self-inductance in transformers, but it's primarily the output capacitors holding their charge. The "On" LED may still light up, indicating that some components are receiving power momentarily. In certain cases, devices may attempt to power up when an unpowered power supply is plugged in, again due to the charge stored in capacitors. Understanding these electrical principles clarifies why devices exhibit this behavior after disconnection from power.
greypilgrim
Hi.
Some laptop or mobile phone chargers still work for a couple of seconds after being unplugged. I've also seen similar behaviour with the standby lights of monitors, TVs and other devices after they are disconnected from power. Is this due to self-inductance in the transformer? If so: If self-inductance is able to maintain a substantial current for several seconds, how can those transformers operate under normal conditions where the direction of current is supposed to change 100 times per second (at 50 Hz)?
Or is this just some capacitors discharging?
This.
Likes davenn
What makes you think anything except the "on" LED is working? (Particularly in devices without capacitors)
For devices that I design, the "On" LED is just powered from the output rail through a resistor.
I have had multiple times when I've plugged an unpowered power supply brick into a device where the device tried to power up. That's just the output capacitors of the brick holding their charge an unexpectedly long time. :smile:
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
