Why do things accelerate due to gravity at the same rate?
33 replies · 7K views · last reply
Josh S Thompson
If you use Newtons gravity equation; F=M1*M2/d^2. The force is dependent on the mass of two bodies so how could the mass cancel? Also, for example If I had a bowling ball and a ball the mass of the sun and droped them 100 feet above Earth The two balls would not accelerate at the same rate because one ball is so massive that it have much more force.
Things don't accelerate due to gravity at the same rate. What you're referring to, I think, is when people say that dropping a bowling ball and a marble from a building, both will hit the ground at the same time. People say this because the mass of both the bowling ball and the marble are negligible in comparison to the mass of the earth. Essentially, the bowling ball IS accelerating faster, however the difference is so small that it doesn't really matter.
Using Newton's 2nd law and his law of acceleration, we have ## m\vec a=-G \frac{m M}{r^2}\hat r \Rightarrow \vec a=-G \frac{M}{r^2}\hat r ##. So the acceleration of an object due to gravity doesn't depend on the mass of the object, so its the same for all objects.
Actually the reason is that the gravitational and inertial masses of an object are equal. Otherwise we couldn't cancel them above and acceleration would depend on the mass of the object.
This is called weak equivalence principle.
This is not correct. In the absence of air resistance, both the bowling ball and the marble have the exact same acceleration. What's different is that the Earth accelerates at a higher rate under the influence of the bowling ball's gravity than the marble's.
Gotcha. Thanks!
Gotcha. I checked out your explanation in another thread and it was much more thorough than the explanation given to me.
Thank you I agree with this, so essetially you can say if the objects are in the same location they accelerate at the same rate because Earth accelerates to one point. But if the objects are far away there would be a difference in the perceived acceleration i.e.one object hits the ground first.
what do you mean by this ??
I think you're saying that a larger object dropped from a large distance would hit the ground first because the Earth accelerates faster towards it. If we were to set up two different situations where M1 and M2 are dropped from identical distances, then yes, that would be correct.
Read the FAQ:
https://www.physicsforums.com/threads/why-is-acceleration-due-to-gravity-a-constant.511172/
Zz.
If you in the middle of the objects that are far away from each other but the objects are equal distance above Earth it would look like the heavier object accelerates faster and it would hit ground first
Only if you dropped them separately and measured the impact time for each one. If you drop them together then they still hit the ground at the same time.
what you mean, all other things constant the heavier object would hit the ground first if you dropped them together because there is more force between them.
did you not read Drakkith's post in that thread I linked to in post #4 ?
if you did you shouldn't still be asking these same questions over and over
Again ...
negating atmospheric drag ( resistance) 2 objects, regardless of difference in mass, if dropped at the same time, will fall and hit the ground at the same time
They are BOTH being subject to the same gravitational force
Their individual masses are irrelevant
Dave
Again ...
Dave
I'm not trying to read a book bro
Again ...
Dave
Ok this is what I am saying
"The general form of the equation for the force of gravitation is: F = GM1M2/r2 This means that the force, which is the same magnitude for both objects" (Drakkith)
if the force is acting on both objects equally why can't you say the F acting on the Earth from gravity is MA, then set it equal to the force of gravity between two objects
MA=M*m*G/(r^2) = A = m*G/(r^2)
M=mass of earth
A=acceleration of earth
m=mass of an object
r=distance
G=constant
Then the acceleration of Earth would be dependent on the mass of an object
and you could say a heavier object does fall to Earth faster
because we are on Earth and it would be hard to notice Earth moving.
And the Earth would touch the heavier object first
but as your have been told repeatedly ... the mass of the object isn't considered and doesn't need to be
PLEASE READ that post from Drakkith
I did read it and the part where he plugs in the F with MA, I say why can't you say the force acting on the Earth is equal to MA
M=mass of earth
m=mass of an object
r=distance
G=constant
M*m*G/(r^2) = force acting on earth
MA = definition of a force
MA=M*m*G/(r^2) =
A = m*G/(r^2)
Read that Dave
M=mass of earth
m=mass of an object
r=distance
G=constant
Sure. But here's where we have to be careful with terminology and word choice. When you say that the heavier objects falls to Earth faster, most of us interpret that to mean that the acceleration of the object under the force of Earth's gravity is more for M1 (heavier mass) than for M2 (lighter mass), which is NOT true. Both objects experience the same acceleration towards the Earth from Earth's gravity.
Now, if you want to account for the slight acceleration of the Earth towards the objects, then for clarity's sake we need to use an inertial coordinate system to compare everything to and not the accelerating frame of the Earth.
It is equal to MA. For a 200 kg mass placed just above the surface of the Earth, the force exerted on the Earth by the mass is 1962 Newtons and the acceleration would be 3.29 x 10-22 m/s2. So 1962 N = (5.97 x 1024 kg) * (3.29 x 10-22 m/s2). F=MA.
The bowling ball feels a greater Force from the Gravitational Mass of the Earth
than the marble as calculated with Newton's Universal Law of Gravitation.
But it also has more Inertial Mass, the tendency to resist a change in motion.
The two effects balance so that the bowling ball accelerates at exactly the same
rate as the marble.
I believe the argument that they accelerate slightly differently due to
their much smaller mass than that of the Earth is invalid.
Newton's Universal Law + Newton's 2nd Law F=ma show their
accelerations to be identical and independent of their mass.
as calculated with Newton's Law of Gravitation.
rate as the marble.
While this is a perfectly acceptable qualitative explanation to give a conceptual understanding, note that to be able to say "... the two effects balance..." requires a quantitative explanation. There is no way to know that they EXACTLY "balance" each other such that the acceleration remains the same until one proves it via mathematics.
Zz.
It depends on whether you're considering the acceleration relative to the surface of the earth, or relative to a fixed point in space. These are the same thing if the Earth doesn't move, which will be the case if the gravitational force is small enough that its effect on the Earth is negligible.
Being a bit of a pedant I don't reckon this is completely true. With the absence of air resistance the marble is ever so slightly attracted to the bowling ball and the bowling ball is accelerating at an even slower rate towards the marble.
The three body problem springs to mind, inconvenient but true.http://www.askamathematician.com/2011/10/q-what-is-the-three-body-problem/
wow... thank you to all of your ideas everyone. I understand it now. :):smile:
Of course. I was ignoring the attraction the two balls had to each other because it doesn't change how fast the two accelerate towards the Earth or vice versa.
It does the marble takes a longer slightly more arced (geodesic) path towards the Earth than the bowling ball.
If we're going to get this detailed then we might as well bring back air resistance. The point was that the mass of the object does not affect the acceleration of the object under gravity.
Of course it does, let's go back to the O.P which mentions a ball with the mass of the Sun and a bowling ball.
They don't have the same acceleration nor does the marble and the bowling ball which was introduced in a later post.
Air resistance was not introduced by the O.P.
Some of these effects are negligible but what is the point of totally ignoring them.
I did mention I was a bit of a pedant but it is o.k to go into some detail if you want to get a clearer picture of what happens.
Yes they do. That's exactly what we've been showing here in this thread.
If you're thinking of geodesics as in General Relativity geodesics, then that is simply beyond the scope of this thread, as we are discussing classical gravity. General relativity would be far beyond the OP's knowledge level.
Er, only that's not a reason is it? It's not a scientific explanation of any fact. It's nothing but a restatement of the fact (that "the acceleration of an object due to gravity doesn't depend on the mass of the object, so its the same for all objects.").
All it does is fix things right with the taught concepts and principles of mechanics? - (that I'm never sure don't contain some circularity or unobservables)
