mrspeedybob said:
Why do we assume that the big bang implies a beginning of time?
We don't. The assumptions are
1. The assumptions that define general relativity:
a) Spacetime is a smooth 4-dimensional Lorentizan manifold with a metric.
b) The properties of matter are represented by a stress-energy tensor.
c) The relationship between the metric and the stress-energy tensor is described by Einstein's equation.
2. That spacetime can be "sliced" into 3-dimensional hypersurfaces that we can think of as representing space at different times, and that
a) each slice is homogeneous (in a specific mathematical sense).
b) each slice is isotropic (in a specific mathematical sense).
The first assumption says very roughly that Einstein's equation describes the relationship between the properties of matter (the stress-energy tensor) and how particles must move (the metric). The second assumption tells us to look for a specific kind of solution to Einstein's equation. A solution that's consistent with these assumptions is called a FLRW solution. I'll just quote myself for the next part.
Fredrik said:
The original big bang theory is the claim that the large-scale behavior of the universe is described approximately by a
FLRW solution. In this context, the "big bang" is just a property of those solutions that can be characterized in many different ways, one of them being that the coordinate distance (in the "default" coordinate system used with these solutions) between any two timelike geodesics goes to zero as t (the time time coordinate of the same coordinate system) goes to zero.
Every event in these spacetimes has t>0, so there is no t=0, and therefore no specific event that we can call "the big bang".
In other big bang theories, such as theories involving inflation, the "big bang" is something different, something that happened everywhere in space at some specific time. I haven't studied such theories myself, so I won't try to elaborate. The reason I mention these theories is that they actually describe the big bang as something that "happened" in spacetime, but still not as an explosion, because it happened "everywhere" at roughly the same time. (Probably not at every point of the entire universe, but at least at every point of a much larger region of the universe than the part we can see).
I emphasize again that there's no t=0 in the theory. You seem to be asking how stuff at t=0 implies the stuff at t>0, but there isn't even a t=0 in the theory.
mrspeedybob said:
If the universe expands by a percentage per unit time then it really would have no beginning. X number of years in the past it would have been half it's current size, 2X years in the past it would have been 1/4 it's current size, etc... At no time would it's size have been zero unless it's rate of expansion were, at that instant, infinite.
This isn't the rate of expansion that's predicted by the theory, but you're right about what seems to be the main idea: If it's finite now, it was finite (zero doesn't count as "finite") at all times, i.e. for all t>0. If it's infinite now, it was infinite at all times.
The above (especially the last sentence) might seem to contradict the big bang theory, but it doesn't. I'll quote myself again:
Fredrik said:
Think e.g. of an infinite line with distance markings on it, and imagine the distance between the markings growing with time. The scale is changing, but the total size isn't.
Fredrik said:
The homogeneous and isotropic solutions can be divided into three classes: positive curvature, zero curvature, and negative curvature. The zero curvature case is a lot like that infinite line with a time-dependent scale. The only difference is that a line is 1-dimensional and space is 3-dimensional. The positive curvature case is a lot like a sphere with a time-dependent radius. The only difference is that a sphere is 2-dimensional and space is 3-dimensional.
If my comments about how t>0 for all events in spacetime makes you think "oh, this theory simply fails to tell us something about events with t=0 and t<0", you're making a naive mistake (that everyone makes until they've understood what I'm about to say). We all have an intuition about what sort of properties "time" has, which is based on our experiences, but the theory that actually describes time in a way that's consistent with our intuition (non-relativistic classical mechanics) has been thoroughly disproved by experiments that show us that special relativity makes better predictions about results of experiments than that theory. This means that our intuition is
wrong. There are also experiments that show us that general relativity makes better predictions than special relativity. This proves that our intuition is
even more wrong than we thought at first. If you're assuming that there must have been a time before the events with t>0, you're relying on your intuition, which has been proven wrong over and over again, instead of relying on of the best theories of science, one that has stood up to some amazingly accurate tests, and has never been disproved. (Not about the properties of time anyway. The behavior of matter on small scales is another...uh...matter).
Here's another quote that might help:
marcus said:
You might enjoy these two articles
Lineweaver SciAm article "Misconceptions about the Big Bang"
http://www.mso.anu.edu.au/~charley/papers/LineweaverDavisSciAm.pdf
And "A Tale of Two Big Bangs" at Einstein Online (a research institute's outreach website)
http://www.einstein-online.info/en/spotlights/cosmology/index.html
These articles will help your refine your picture quite a bit. They are both aimed at eliminating common misunderstandings about the standard cosmo model.
I have edited the post to fix the broken link to the first article.
Edit: This quote seems unnecessary now that the man himself has shown up.
(These links are included in marcus's signature).
