MHB Why Does Checking if 2 Divides z1 Matter in Rational Solutions for X^2+Y^2=n?
  • Thread starter Thread starter evinda
The discussion focuses on the conditions under which the equation X^2 + Y^2 = n has rational solutions, particularly when n ≡ 3 (mod 4). It emphasizes that checking if z1 is even or odd is crucial, as both cases lead to contradictions regarding the modulo 4 properties of the resulting equations. If z1 is even, it results in x1^2 + y1^2 ≡ 0 (mod 4), while if z1 is odd, it leads to x1^2 + y1^2 ≡ 3 (mod 4), both contradicting the initial conditions. The choice of modulo to check depends on the specific problem, illustrating a common technique in number theory to eliminate possibilities. Understanding these modular conditions is essential for proving the absence of rational solutions in such equations.
evinda
MHB
Hi! (Smile)
I am looking at the following exercise:
In general, the equation $X^2+Y^2=n$, when $n \equiv 3 \pmod 4$, has no rational solution.
According to my notes:
Let $x=\frac{a}{b}, y=\frac{c}{d}, a,b,c,d \in \mathbb{Z}, b \cdot d \neq 0, (a,b)=1, (c,d)=1$, solution of $X^2+Y^2=n$.
$$\frac{a^2}{b^2}+\frac{c^2}{d^2}=n \Rightarrow (ad)^2+(bc)^2=n(bd)^2$$
That means, that the equation $X^2+Y^2=n Z^2$ has an integer solution $(x_1, y_1, z_1)=(ad, bc, bd)$.
Without loss of generality, we suppose that $gcd(x_1,y_1,z_1)=1$.
If $2 \mid z_1 \Rightarrow x_1^2+y_1^2 \equiv 0 \pmod 4 \Rightarrow (2 \mid x_1 \wedge 2 \mid y_1) \Rightarrow 2 \mid (x_1,y_1,z_1)=1, \text{ Contradiction}$
Therefore, $z_1=2k+1, z_1^2 \equiv 1 \pmod 4$
$$\Rightarrow n z_1^2 \equiv n \cdot 1 \pmod 4 \equiv 3 \pmod 4$$
$$\Rightarrow x_1^2+y_1^2 \equiv 3 \pmod 4, \text{ Contradiction.}$$
Why do we check if $2 \mid z_1$ ? (Sweating)
Mathematics news on Phys.org
$z_1$ can either be odd or even. If even, $z_1 = 0 \pmod{2}$ and hence $z_1^2 = 0 \pmod{4}$ and $x_1^2 + y_1^2 = 0 \pmod{4}$ leading to a contradiction as above.
If $z_1$ is odd, i.e., $z_1 = 1 \pmod{2}$ then $z_1^2 = 1 \pmod{4}$ in which case $x_1^2 + y_1^2 = 3 \pmod{4}$ which also leads to a contradiction.
It's a standard method in number theory to check case-by-case modulo something and eliminate the possibilities. That's what they have done above.
Ok.. but how can I know which modulo I should take?
For example, at this exercise: Show that $x^2+y^2=3$ has no rational solution, why do we check if $3 \mid x_1$ and not if $2 \mid x_1$ ? (Thinking)
That completely depends on the problem you're doing. It's more or less a "trick" of number theory of some sort.
In the example $X^2 + Y^2 = 3Z^2$ (where $\text{gcd}(X, Y, Z) = 1$), considering modulo $3$ provides an obvious way to "chuck out" $Z$ from the modulo argument, giving $X^2 + Y^2 = 0 \pmod{3}$. However, this is possible if and only if $X^2 = Y^2 = 0 \pmod{3}$ (why?) in which case $X = Y = 0 \pmod{3}$. But then $X^2 + Y^2 = 0\pmod{9}$, thus $3 | Z^2 \Rightarrow 3|Z$. But then $\text{gcd}(X, Y, Z)=3 \neq 1$, contrary to our assumption.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
