Why does 2(sin(a)*cos(a))= sin(2a) ?
  • Level: High School
  • Thread starter Georgepowell
27 replies · 20K views · last reply
Georgepowell
I think it does... have I got that right?
If I have then why does it? is there a simple explanation?
Yes it does.
It's easy to prove from the sum formula, sin (a + b)=sin a cos b + cos a sin b
Of course now you have to prove that!
mgb_phys said:
Yes it does.
Go on...
How would I do that? I don't need a solid proof, just a simple explanation would do...
Thanks
D H said:
Set b=a.
Yeh I got that part, What I wanted was for someone to tell me why
sin(a + b) = sin(a)cos(b) + sin(b)cos(a) ?
One way to derive the sine and cosine of the sum (or difference) of pair of angles is via Euler's identity:
[tex]\exp(i\theta) = \cos\theta + i\sin\theta[/tex]
Setting [itex]\theta=a+b[/itex],
[tex]\aligned<br /> \exp(i(a+b)) &= \exp(ia)\exp(ib) \\<br /> & = (\cos a + i\sin a)(\cos b + i\sin b) \\<br /> &= (\cos a \cos b - \sin a \sin b) + i(\sin a \cos b + \cos a \sin b)) \\<br /> &= \cos(a+b) + i\sin(a+b)<br /> \endaligned[/tex]
Equating real and imaginary parts,
[tex]\aligned<br /> \cos(a+b) &= \cos a \cos b - \sin a \sin b \\<br /> \sin(a+b) &= \sin a \cos b + \cos a \sin b<br /> \endaligned[/tex]
D H said:
[tex]\aligned<br /> &= (\cos a \cos b - \sin a \sin b) + i(\sin a \cos b + \cos a \sin b)) \\<br /> &= \cos(a+b) + i\sin(a+b)<br /> \endaligned[/tex]
Can you go over this step please? Thanks
By using [tex]e^{i\theta}=\cos{\theta} + i\sin{\theta}[/tex]
the LHS becomes
[tex]\cos{a+b} + i\sin{a+b}[/tex].
the LHS becomes
haha, ok... I think this is getting well out of my depth. Unless there is a more simple explanation, I'm outahere.
Anyway - Thanks for all your help everyone.
Assuming that you are using the "circle" definition of sine and cosine: that the coordinates of a point a distance t along the circumference of the unit circle from (1, 0) are (cos(t), sin(t)), then you can use argue that the straight line distance from (1, 0) to (cos(t), sin(t)) and from (cos(s), sin(s)) to (cos(s+t), sin(s+t)) are the same because because they both cut an arc of length t.
[tex]\sqrt{(cos(t)- 1)^2+ sin^2(t)}= \sqrt{(cos(s)-cos(s+t))^2+ (sin(s)- sin(s+t))^2}[/tex]
Squaring both sides and multiplying everything out,
[tex]cos^2(t)- 2cos(t)+ 1+ sin^2(t)= cos^2(t)- 2cos(s)cos(s+t)+ cos^2(s+t)+ sin^2(s)- 2sin(s)sin(s+t)+ sin^2(s+ t)[/tex]
The [itex]cos^2(t)[/itex] and [itex]sin^2(t)[/itex] on each side cancel and [itex]cos^2(s+t)+ sin^2(s+ t)= 1[/itex] which cancels the "1" on the left. That leaves
-2cos(t)= -2 cos(s)cos(s+t)- 2sin(s)sin(s+t) so cos(t)= cos(s)cos(s+t)+ sin(s)sin(s+t).
Let a= s, b= s+t. Then t= b- a and we have cos(b-a)= cos(a)cos(b)+ sin(a)sin(b).
Replacing a by -a and using the fact that cos(-a)= cos(a) while sin(-a)= -sin(a), we have cos(a+ b)= cos(a)cos(b)- sin(a)sin(b).
Use the fact that [itex]sin(x)= cos(\pi/2- x)[/itex] to change to a formula for sin(a+b).
That's the proof that is used in most pre-calculus classes.
Thanks, that's what I wanted. I understand it now.
I don't like memorising formulas without understanding them, and my teachers teach the formulas and not the explanations. Which I don't like.
I suppose I'm not even meant to know this formula yet, but I'm interested.
Hi Georgepowell!
Draw a right-angled triangles PQR and PQS with R = S = 90º and QPR = A + B and QPS = A (so SPR = SQR = B).
Draw the perpendiculars from S to PR and QR.
Then, if PQ = 1, QR = sin(A+B) …
and you can work out the rest! :smile:
tiny-tim said:
Hi Georgepowell!
Is this what you meant?
  • Handwritten geometry sketch of a circle with diameter PQ and points R and S on the upper arc; chords PR, PS, RQ and SQ are drawn, with right-angle marks at R and S, and angles labelled A at P and B near P and Q.
But how do you apply that, say, to A= 50 degrees, B= 60 degrees?
Yes … and now draw the perpendiculars from S to PR and QR
(and note that the first one will be parallel to QR). :smile:
(and the circle isn't needed)
A braindead way to prove any trig identity is to write the identity in terms of complex exponentials and simplify as much as possible until 0=0 is reached. Then the reverse of your steps is the proof of the identity.
For example,
[tex]2 sin(a) cos(a) - sin(2a) = 0[/tex]
[tex]2\left(\frac{e^{i a}-e^{-i a}}{2 i}\right)\left(\frac{e^{i a}+e^{-i a}}{2}\right) - \frac{e^{i 2a}-e^{-i 2a}}{2 i} = 0[/tex]
[tex]\frac{1}{2 i}\left(e^{i a}e^{i a} + e^{i a}e^{-i a} - e^{-i a}e^{i a} - e^{-i a}e^{-i a}\right) - \frac{1}{2 i}\left(e^{i 2a}-e^{-i 2a}\right) = 0[/tex]
[tex]\frac{1}{2 i}\left(e^{i 2a} - e^{-i 2a}\right) - \frac{1}{2 i}\left(e^{i 2a}-e^{-i 2a}\right) = 0[/tex]
[tex]0 = 0[/tex]
Now a proper proof would run these steps in reverse.
For example,
[tex]0 = 0[/tex]
I believe that was what mbg_phys did in the first several responses but GeorgePowell was not familiar with the exponential form of sine and cosine and could not follow.
keep it real
Yeah :cool: … keep it real!
Support CAMREG …
the CAMpaign for REal Geometry! :biggrin:
That's a good simple proof that I understand, but doesn't it only prove it for:
2A + B = 90 ?
**note: In the picture, I changed the letters, but it is the same concept. And the circle was just to help me get the right-angles right**
  • Handwritten geometry diagram of a triangle O-T-Q with points P, S and R, angles labelled A, B and A+B, and the identities sin(A+B) = sin(A)cos(B) + cos(A)sin(B) written beside it.
2A + B = 90 ?
Hi Georgepowell! :smile:
(can't see your new diagram yet)
No, I think that it works for any A + B < 90º …
and even for A + B ≥ 90º provided both A and B < 90º if you put R on the other side of the circle. :wink:
Yeah, the letters don't matter …
it's always best to use whatever letters you find easiest. :smile:
hmm … now you mention it, my own diagram (which you can't see :redface: would have been a lot better if i'd started off with a circle :rolleyes:)​
Err, not really. The other one was a little trickery using Euler's formula, a method which does not generalize to prove all other identities.
support CAMREG!
ooh, i can see your diagram now …
very nice :biggrin:
mmm … if you've nothing better to do,
try proving cos3x = cos3x - 3.cosx.sin2x with a diagram :wink:​
EDIT: Just noticed … the angle PQO in the diagram is wrongly labelled as A (instead of 90º - A - B), … but it doesn't affect the proof. :smile:
That was my trickery (not mine really; pretty standard trickery), not mgb_phys'. mgb_phys simply said to use the angle sum formula for sine.
Please show one trigonometric identity that does not follow from Euler's identity, the definitions sec(x)=1/cos(x), csc(x)=1/sin(x), tan(x)=sin(x)/cos(x), cot(x)=1/tan(x), the exponential identities exp(a+b)=exp(a)*exp(b), exp(i*pi/2)=i, and exp(i*k*pi)=(-1)k for integral k.
Kurret said:
Heres another way (for angles less than 90 degrees)
Hi Kurret! :wink:
Yes, that's nice too! :smile:
It only works in that form for A + B > 90º …
for A + B < 90º, your diagram becomes Georgepowell's :smile: diagram, if we make the top of your rectangle PQ, the bottom left corner T, and the right-angle of the main triangle at S.
just check that both satisfy the same differential equation: namely y'' + 4y = 0, and y'(0) = 2, and y(0) = 0.
Kurret said:
Heres another way (for angles less than 90 degrees):
http://www.geocities.com/kurre999/Trigaddition.bmp
Thanks, I do prefere the geometric proofs :p
That explains why i thought:
Georgepowell said:
Doesn't it only prove it for:
2A + B = 90 ?
I incorrectly presumed it was symmetrical, and so SQO = POQ.
Another misstake in the diagram is in the top left corner i wrote "OS = cos(B)" but it doesn't, OS = cos(A).
Actualy i think it works for all values of A and B, as long as neither of them = 90 exactly...
http://i349.photobucket.com/albums/q390/Georgepowell77/DSC00056-1.jpg
[edit] does it still prove it for A or B = 90? - I'm not sure[edit]
uh … i never noticed that misprint … i was only looking at the top right corner, where you got it right anyway! :biggrin:
yes, it works for A + B > 90º too, but then your diagram turns into :smile: Kurret's
for A + B = 90º, i don't see how to adapt it … but that's just sin2A + cos2A = 1 anyway :biggrin:
hi mathwonk! :smile:
erm … did you wander into the wrong flat after a party? :wink:​
