Why does a boiled egg rotates while a raw egg doesn't?
  • Thread starter Thread starter PedroHB
    Egg
A boiled egg rotates smoothly because it is a rigid body, with solid internals that move uniformly with the shell. In contrast, a raw egg does not rotate effectively due to its liquid contents, which slosh around and fail to keep pace with the shell. This internal movement creates a delay in the overall velocity of the raw egg. The difference in behavior between the two types of eggs highlights the importance of internal structure in rotational dynamics. Understanding these principles can clarify why certain objects behave differently when set in motion.
PedroHB
Is a boiled egg a rigid body?
Why does a rigid body, like a pawn, rotate?
Thank you!
Boiled, due to the fact that the internals are solid. In a raw egg, the yolk and white will be 'sloshing' around, trying to catch up to the shell, therefore slowing down the total velocity.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
