Why Does a Boomerang Return?
  • Thread starter Thread starter arevolutionist
The discussion centers on the physics behind why a boomerang returns, emphasizing the roles of aerodynamic lift, gyroscopic action, and torque. Participants highlight that the unequal aerodynamic forces on the blades, due to their differing speeds, contribute to precession, even in balanced boomerangs. The conversation also touches on the design variations of boomerangs, such as cloverleaf and four-blade models, and their ability to return effectively. Key resources, including links to detailed physics explanations, are shared to enhance understanding of the dynamics involved.
  • Understanding of aerodynamic lift principles
  • Basic knowledge of gyroscopic motion and precession
  • Familiarity with torque and its effects on rotating bodies
  • Awareness of the differences in boomerang designs, such as cloverleaf and four-blade shapes
  • Study the physics of gyroscopic motion in detail
  • Research aerodynamic principles related to wing design and lift generation
  • Explore the mathematical modeling of boomerang flight paths
  • Examine various boomerang designs and their performance characteristics
Aerospace engineers, physics students, hobbyists interested in aerodynamics, and anyone looking to understand the mechanics of boomerangs and their flight dynamics.
arevolutionist
What causes a boomerang return?
Not only do boomerangs return, but some shapes will fly in a figure 8 pattern, if you don't catch it on the initial return, it will fly by and circle in the opposite direction and return again.
Yes but what i wonder is whys that the boomerang precess since is a case of balanced gyroscope
Because there's a torque on it. The aerodynamic force exerted on each blade is not equal, since the blades move through the air with different speeds. (While one blade rotates forward, another rotates backward.)
I though it was actually a cloverleaf i.e. 4 lobes.
The point pretty much is that the thing isn't balanced. One arm is longer than the other, so the centre of rotation is offset from the radius of the bend.
But balanced, four-blade boomerangs work too! When I used to be in the entertainment business (teaching in grad school :cool: ), I would make simple boomerangs out of cardboard and wing them around the auditorium.
Well... yeah... but you're kinda weird. :-p
Ignoring gravity, it's a natural tendendcy of anything that's moving through a viscous fluid (air, or water, or whatever) to either move in a circle (or a straight line, which is , really, a degenerate circle.)
A boomerang is essentially a wing - something that generates a lot of acceleration while going through the air so that it curves more.
The Wiki article covers the physics pretty nicely.
The wiki doenst talk too much on the physics of it
Intuitivile you may consider than when it is spinned around its center of gravity there's more mass on one side of the boomerang than in the other but this is false by definition of center of gravity
On the other hand i had a boomerang which was regular not with wind shape and still worked
So my question is if precession only happens only on unbalance gyros how comes it appears in a boomerang that is a balanced one being the COG and axe in the same point
I answered that in post #5--there's a torque on the boomerang! (By "unbalanced" gyro I assume you mean a gyro with an unbalanced torque acting on it--that's what causes precession.)
You have WAY too many things relying on your faulty "intuition" here.
Please read the link given by Danger in this thread. Scroll ALL THE WAY DOWN to the bottom of the page where are is a series of very extensive "intiutive" explanation about the dynamics of a boomerang. If you want a quantitative explanation and derivation, then you either need to sit down and work out the physics of the system, or pick up physics papers/books, and then tell us where you got stuck.
http://pass.maths.org.uk/issue7/features/boomerangs/2pdf/index-gifd.html/op.pdf
Zz.
but that center of rotation will coincide with the center of mass
Any object spinned unless forced to do otherwise will have the center of rotation in the center of mass
Therefore the force of gravity, second force in the couple is exerted exactly on the spinning axe with which there's no arm for the couple
Then why does it precess?
A posible answer would be that the superior wing gets faster air than the bottom one but this doesn't work with a boomerang that has no wing shape like the one i just build of hard paper which works as well
i think the reason why the boomerang precesses is the tendence of masses to spin on preferred axes
if you spin a hollow ball rimmed with plastiline on the shape of a boomerang and spin it on the short axe it will end up spinning on the long axe, just like a football there the second force for the couple
The fact that it was designed without any real knowledge of aerodynamics, or mechanics is really quite amazing.
