Pulzz
- 6
- 0
If a compass is placed above a current carrying wire, why does the compass needle align itself in the direction of the magnetic field produced by the wire?
Drakkith said:Because the needle is magnetic? I'm a little confused by your question. Why wouldn't the needle align itself with the magnetic field?
Pulzz said:The magnetic field produced by the current does not have a north or south pole, so what would the compass needle be attracted by?
Drakkith said:A compass only points towards the magnetic poles of a magnet because it orients itself along the magnetic field lines that loop from the north pole to the south pole. A current-carrying wire also has magnetic field lines, but they run in circles around the wire instead of from one 'pole' to the other.
arul_k said:Considering that magnetic field lines are imaginary, why would the compass needle align itself along an imaginary line?
arul_k said:In the case of a bar magnet one could reason that the compass needle is influenced by the forces emanating from the north and south poles of the magnet, but in the case of the wire there are no forces emanating from N/S poles, so why do we obtain this circular field line pattern?
Lines of gravitational force (the Field lines) are just as imaginary - the geometry happens to be a bit less complicated than for the field round a wire. If you drop a stone, it follows those "imaginary lines" of the g field but I doubt that you would have a problem with that. The lines are only a graphical representation of an effect.arul_k said:why would the compass needle align itself along an imaginary line?
The poles are only places where the field is most concentrated (highest). They are an even more 'imaginary' concept than the field lines, themselves. In no way are they points of origin for the lines.arul_k said:forces emanating from the north and south poles of the magnet
sophiecentaur said:Lines of gravitational force (the Field lines) are just as imaginary - the geometry happens to be a bit less complicated than for the field round a wire. If you drop a stone, it follows those "imaginary lines" of the g field but I doubt that you would have a problem with that. The lines are only a graphical representation of an effect..
The "why" question is no more valid here than anywhere else in Science. All we can say for sure is that it's how things have been observed to work
sophiecentaur said:The poles are only places where the field is most concentrated (highest). They are an even more 'imaginary' concept than the field lines, themselves. In no way are they points of origin for the lines.
I think it's more of 'how', not 'why'.arul_k said:The "why" question is the essence of all enquiry. If we accept "how things have been observed to work" as an answer, we would still be in the stone age!
You explained it in post #5.Drakkith said:...
I'm not sure how to explain it. Perhaps someone else here can elaborate on the details.
sophiecentaur said:I don't expect you have read that the polesof a magnet are located at points either. .
If I am in the stone age then I am in good company (listen to the Richard Feynman "Why" talk.
Imo, people who really believe there are proper answers to "why" then they are in cloud cuckoo land. I haven't yet read of one, anywhere in the field of established Science
This is his famous comment on "why?". I am happy that he feels the same way as I do about it. Starting at around 1 minute in. If you actually read the posts in the "why" hits on PF, you will usually find that the responses to the Why question tend not to show a lot of sympathy from the majority of PF posters. When someone demands "why" it is because they want a specific but easy answer. There never is one as one answer leads to another question - ad infinitum. Science is the journey and not the arrival at some celestial city of knowledge. The more of it that you know, the more you realize that about Science.arul_k said:I have heard Feynmans talk, he dosen't object to "why" questions.
Anywhere you care to look for a definition of a "magnetic pole" is is always defined in terms of an approximate region where the "lines of force" are closest together or the field is strongest. That is an open statement and is as far as they go. It isn't the place that a compass will point to; the (imaginary) lines of force follow curves which pass through a region - at one end or the other (or whatever) but they don't point at it. The term is vague and simply describes what a casual observer will experience in a kitchen table-top experiment; nothing more. Why would I need a reference that uses the word "imaginary", to justify the term I used? Would you say that a place 1mm / 1cm / 1m from the place that someone would call the Pole of a magnet would still be the pole?arul_k said:Since you are so well read, I would once again request you to mention the the references that state "magnetic poles are imaginary" and poles of a magnet are located at "points"
Ah, no. All of electricity and magnetism incl. the Maxwell relations, are the result of empirical evidence.arul_k said:The "why" question is the essence of all enquiry. If we accept "how things have been observed to work" as an answer, we would still be in the stone age!
The field from a bar magnet doesn't 'stop' at the faces with N and S painted on them. Those lines carry on through the magnet (as with a solenoid) to form a continuous loop. The Poles are just where the external field is strongest. In the case of a current carrying wire, the lines are continuous loops which do not bunch together to form poles. Any book (or website) on elementary electromagnetic theory will show you that, along with all the relevant diagrams. Don't try to get all your knowledge from asking questions on PF (especially when you argue with the answers). It is easier not to get offended with what's written in a book because you can;t get into an argument with it.arul_k said:In the case of a bar magnet one could reason that the compass needle is influenced by the forces emanating from the north and south poles of the magnet, but in the case of the wire there are no forces emanating from N/S poles, so how is it that we obtain this circular field line pattern?
