Why Does a Sealed Chip Bag Expand at High Altitudes?
  • Thread starter Thread starter Jam Smith
    Physics Pressure
The expansion of a sealed potato chip bag at high altitudes is primarily due to the difference in atmospheric pressure. When the bag is sealed at sea level, it contains air at surface pressure. As altitude increases, atmospheric pressure decreases, resulting in higher internal pressure within the bag compared to the external environment. This pressure difference causes the bag to inflate, similar to the behavior observed in weather balloons. The discussion clarifies that the temperature difference is not the primary reason for the bag's expansion.
  • Understanding of atmospheric pressure and its variation with altitude
  • Basic knowledge of gas laws, particularly Boyle's Law
  • Familiarity with the concept of pressure differentials
  • Experience with simple physics experiments demonstrating gas behavior
  • Research the principles of Boyle's Law and its applications in real-world scenarios
  • Explore the effects of altitude on various gases and their behaviors
  • Investigate the physics behind weather balloons and their expansion at different altitudes
  • Learn about atmospheric science and how pressure changes affect weather patterns
This discussion is beneficial for students studying physics, educators teaching atmospheric science, and anyone interested in the practical applications of gas laws and pressure differentials.
Jam Smith
Member advised to use the homework template for posts in the homework sections of PF.
I am not tech savvy. But I like to solve quiz relates math and physics.
I was solving such questions and come across this question.
"On a cloudy day, a sealed packet of potato chips is taken to the top of a mountain. The packet is found to be blown up like a balloon."
What is the reason behind it?
I found two reasons as per my knowledge,
1. The air outside the packet is hotter than the air inside the packet or
2. The air outside is now at a lower pressure than the air inside the packet.
Which one is the right reason? Please guide me in detail.
Atmospheric pressure decreases with altitude. The potato chip bag was sealed at the surface of the earth, so the pressure in the bag is the surface pressure. The pressure at the top of the mountain is less than surface pressure. So the inside pressure is higher than the outside pressure, and the bag inflates like a balloon.
Why would that cause the packet to blow up?
The air inside expands until the pressure inside is the same as that outside.
Some weather balloons explode at height.
Or until the bag becomes taut, thereby maintaining a pressure difference.
There used to be a nice little experiment shown in junior physics classes at my school .
A large glass jar had two tubes through the stopper . The end of one tube inside the jar was fitted with a small uninflated balloon . When the other tube was connected to a low power vacuum pump the balloon slowly inflated .
I was not sure about the concept,
I have read that the air has a certain amount of heat, which it carries with it as it rises. So just assumed about this possiblity.
Chestermiller said:
Atmospheric pressure decreases with altitude...
Thanks for the guidence. This information helped me to find proper reasons of my question.
  • · Replies 29 ·
  • · Replies 16 ·
