Why does a thyristor keep conducting after removing the gate current?
brent1369
i have seen several videos of thyristors but they never really explain the fundamentals
they just say that cause there is a current flowing in there it keeps being on
but why does a transistor then turn off when you remove gate voltage
Have you learned about "SCR Latchup" yet? Are you familiar with this view of the thyristor equivalent circuit? :smile:
https://www.electronics-notes.com/images/thyristor-scr-equivalent-circuit-01.svg
Two-transistor equivalent circuit of a thyristor, with transistor TR1 (PNP) and TR2 (NPN) cross-coupled; labelled Anode at the top, Gate on the left and Cathode at the bottom.
https://en.wikipedia.org/wiki/Latch-up
  • Two-transistor equivalent circuit of a thyristor, with transistor TR1 and transistor TR2 cross-coupled, labelled Anode at the top, Gate on the left and Cathode at the bottom.
I understand it when you divide it in 2 transistors but not when its 1 whole thyristor
Cause you can't remove contact with highest P and highest N of th 2
and also lowest N and lowest P of th 1
Sorry, I can't parse that. A thyristor is just a PNPN structure, which is basically the same as the two transistors connected in the stacked format that I showed previously.
https://www.theengineeringprojects.com/wp-content/uploads/2019/11/what-is-thyristor.jpg
Thanks for the heads up :smile:
Gosh, in the 50 odd years of doing electronics, the thyristor is probably one of my least understood
component. Not having had any real need to use them, has lead to some ignorance of them.Dave
