Why Does a Wave Reflect with Double Amplitude at a Free End?
  • Context: Undergrad
  • Thread starter Thread starter Rishavutkarsh
    Reflection Waves
The discussion revolves around the behavior of waves reflecting from a free end of a string, specifically addressing why the amplitude doubles and the phase remains unchanged upon reflection. Participants explore theoretical explanations and seek a deeper mathematical understanding of the phenomenon.
  • One participant expresses confusion about the wave reflecting at a free end with double amplitude and no phase change, seeking a detailed explanation.
  • Another participant recalls lessons on traveling waves and discusses scenarios involving mass, friction, and impedance, suggesting that waves may dissipate or reflect based on the conditions of the string's ends.
  • A different participant is comfortable with the 180-degree phase change at a fixed end but finds the behavior at a free end perplexing, particularly regarding the amplitude change.
  • One participant proposes that the wave's reflection at a free end occurs because the energy of the wave causes the end of the rope to rise, creating potential energy that contributes to the reflection.
  • Another participant requests a concrete mathematical proof for the behavior of the wave at the endpoint, indicating a desire for a more rigorous understanding.
  • A suggestion is made to consider boundary conditions at both free and anchored ends to understand the wave behavior mathematically.
  • One participant uses an analogy of trolleys connected by springs to illustrate how a wave propagates and reflects at a free end, noting that the final trolley would be displaced further due to the lack of restraint.
Participants express various viewpoints and uncertainties regarding the reflection of waves at a free end, with no consensus reached on a definitive explanation or mathematical proof.
Participants mention different scenarios involving mass, friction, and impedance, indicating that the discussion may depend on specific assumptions about the physical properties of the string and the conditions of the wave generation.
Rishavutkarsh
Hi everyone, the fact that a wave reflects from a string when it's end is free and the end of the string rises to a height of 2A seems to confuse me a bit. Even though I find it somewhat intuitive I would appreciate a detailed explanation of the same. Thanks in advance.
Science news on Phys.org
Hhhmmm...traveling waves? I seem to recall a lesson about this in one of my power systems class several decades ago...maybe I can "translate" what I remember...hope this rambling helps in some way.
When you have a source of energy that somehow has produced a wave in a string, I presume several scenarios are possible.
First, the string is not massless or friction less and so, with a long enough string or rope the wave will eventually dissipate and not even reach the end of the rope.
With a "short" rope and a free end ("zero impedance"), I thought the wave would disappear (this is what I seem to recall for electrical traveling waves, anyway), but maybe with the whipping at the (non-massless) rope end reflects some of the wave back?...don't know.
With a "short" rope and the other end firmly tied to a post ("infinite impedance"), the wave is supposed to reflect back at 180 degrees out of phase...meaning, if the wave hump is going say along the top of the horizontal and it hits the post, it comes back along the bottom of the horizontal.
With "impedance" values in between zero and infinite, the wave is supposed to reflect some and refract some...for example, say you have a thin string tied to a thick string...a wave coming along the thin string reaching the tie will "see" a change in "impedance"...part of the wave will propagate (refract) to the thick string, excite it and produce a wave there, though smaller...and part of the wave will reflect back through the thin string itself (kind of similar as with the post but much smaller scale).
hope this helps in some way
The fact that the wave reverses with a phase change of 180 degrees is something I am quite comfortable with. But however the second part with a rope at free end the wave reflects without any phase change and the end point rises at double the amplitude is something that seems to confuse me. Thanks for the reply though.
I see. Think about it though...how did you produce the wave in the first place? By raising your end of the rope high up and lowering it; once the wave approaches the other free end, when there isn't enough rope (mass and downward force) to contain the energy of the wave, the wave raises and launches the rope high up in the air placing some potential energy and internal tension into it...now, the rope end is high up in the air similar to the position where your end was when creating the wave and, so, when the end comes back down and the internal tension springs back...a similar wave is created on the same side of the horizontal. ...just a thought.
I've already thought it this way and to be honest it does seem intuitive to me. I actually was looking for a concrete mathematical proof. Nevertheless thank you I appreciate all the help.
If you are trying to understand the "mathematical" reason for "why" the rope reflects the way it does at an endpoint, I suggest starting by writing out the boundary conditions at the endpoint — for both the "free" rope end and the "anchored" end.
It may help to think about a line of trolleys joined by springs. The trolleys are orientated transverse to the line joining them; they can move only at right angles to this line. Now imagine the propagation of a transverse wave when a trolley at one end of the line is displaced. When the transverse disturbance (wave) reaches the other end of the line (assumed 'free' with no springs or trolleys beyond it), what will happen to this final trolley? Not being restrained by further springs, it will be displaced further. Hand-waving, but can be dealt with mathematically.
  • · Replies 16 ·
