Why does connecting two capacitors waste half the energy?
38 replies · 10K views · last reply
Great post indeed !
I think the 'paradox' arises from the connection of two unequally charged ideal capacitors through ideal wires. That causes division by zero, I = ΔVolts/zeroOhms , so anything goes.
Adding an ideal inductor prevents division by zero. Further, an ideal inductor can dissipate no energy so the energy should all show up in the capacitors afterward.
Ahh if only you had an ideal diode...
It's not unlike the thermo question - a gas is confined to one half of a chamber, the other half is evacuated. What happens if the wall separating the chamber halves is suddenly removed?
With no diode the result is:
Oscilloscope screenshot showing four traces: yellow and green curves step up and then ring with decaying oscillations, while pink and red curves ring similarly around a flat baseline before settling.
Note that the ground reference for the two voltage traces (yellow and green) is at the bottom 1 cm; you can see a ground symbol down there at the far left. The final result is 15 volts on both caps.
Here I have inserted a 10 ohm resistor in series. Now we're overdamped.
Oscilloscope screenshot showing two decaying voltage traces that converge toward zero, with a third trace (pink) near zero, time base 500 ns per division, channels set to 5.00 V per division.
Still 15 volts on both caps at the end.
Here's a picture of the experimental setup:
Photo of a test setup with two blue electrolytic capacitors and a ceramic-cased coil wrapped in orange insulation, with a grey oscilloscope probe and a yellow clamp meter on a workbench.
  • Agilent oscilloscope screenshot of four traces decaying as damped oscillations after a step, with a yellow step rising then ringing and a green trace ringing in opposition, settling flat by the right side.
  • Photo of an experimental setup on a grey work surface: a wound toroidal coil with two blue electrolytic capacitors on top, probe leads attached, and a yellow clamp-on current meter at right.
  • Oscilloscope screenshot of two voltage traces: yellow falls from a high level and green rises from a low level, both settling to a common level, with a small pink spike on channel 3 at the transition.
technician said:
@electrician...this is brilliant! I would love to check your numbers...what is the time scale on the plot?
What do you get without the diode? Do you get an oscillation.
I have no means of reproducing your measurements but I am impressed by this...one of the best things I have seen on PF and in the true spirit of physics...experimental evidence to discus.
Congratulations
You can see the horizontal sweep speed at the top of the image--500 μs/cm for the first image. Later images are 2 ms/cm. Channel 1 and 2 are 5 V/cm, and the current scale is 5 A/cm.
Those are very nice traces. What machine do you use to make them? I'm still on a analog HP180...
I like this. It's interesting to note that if the diode is not used both capacitors eventually reach 15V with each capacitor having the same charge and the energy loss being 50 percent.
If the circuit is switched off before charging/discharging is complete then the energy loss is reduced. The same applies when the capacitors are connected by wires. The energy loss is 50 percent only when charging/discharging is complete.
Interesting that the energy loss is same for the real case of resistance in wires and theoretical one of zero resistance in wires.
There must be a relation between capacitor ratio and energy lost.
That'd be an interesting piece of algebra, and might uncover one of those "little gems of wisdom" a fellow likes to keep in his bag of tricks.
I'd just embarrass myself with clumsy Latex if I tried...
old jim
Yes, this is a good learning exercise. If the circuit is allowed to oscillate (without the diode) then energy is lost mostly through the resistive component of the inductor. So in that sense it is similar to an RC circuit except that it oscillates.
Since no one has volunteered to answer my question in post #30, I will attempt to answer it myself. The question is: With the diode in the circuit will the polarity on the inductor reverse after the peak current is reached?
The answer is yes it will. This may seem non intuitive at first because the direction of current flow through the inductor does not change. During the first quarter cycle energy is being stored in the magnetic field of the inductor with C1 being the source. At the peak of current flow the voltage on C1 and C2 are equal (15 volts) and the voltage on the inductor is zero (voltage and current on the inductor is 90 degrees out of phase). During the second quarter cycle the magnetic field of the inductor is collapsing with the inductor being the source. The energy stored in the inductor reduces the voltage on C1 to it's final 5 volt value and increases the voltage on C2 to it's final 25 volt value. The diode prevents oscillation. The circuit cannot go for more than one half cycle, giving a maximum transfer efficiency. You can see the one half cycle of current in the oscilloscope trace. Note: because of losses, voltages may be slightly less than those stated.
I thought your question was rhetorical. The polarity indication on the inductor is an artifact of the spice program I used to produce the schematic. Spice indicates polarity on inductors simply as a way of declaring the reference direction for inductor voltage when plotting waveforms. It was happenstance that the polarity indication matches the initial polarity in the behavior of the circuit.
Your detailed explanation is right on the money. The person who hasn't seen this type of circuit in action before could persuade his intuition about the inductor's voltage polarity in two ways. Remembering that for an inductor e=L*di/dt, we see that the slope of the inductor current versus time changes sign at the peak of the inductor current, hence the voltage polarity changes at the peak; after the first quarter cycle, as you point out.
Also, because the inductor is connected between the two capacitors, the voltage across the inductor is the difference of the capacitor voltages. The capacitor voltages cross over at 15 volts at the same time as the inductor current reaches its peak, and that's when the inductor voltage polarity changes.
This circuit is a simple demonstration of how "resonant switching" works in switching power supplies.
Thanks for your detailed further explanation of the circuit's operation.
