Why Does Inertia Exist in a Relative Universe?
  • Context: Graduate
  • Thread starter Thread starter jocanon
    Inertia
The discussion centers around the concept of inertia and its existence within a framework of relativity, particularly questioning how inertia can be defined when all motion is relative and there is no fixed point of reference. Participants explore thought experiments and conceptual understandings rather than mathematical formulations.
  • One participant questions how inertia can exist if motion is only defined relative to other objects, suggesting that without a fixed reference point, the concept of motion becomes ambiguous.
  • Another participant asserts that acceleration is not relative and can be measured, implying that there are ways to determine if a frame of reference is accelerating.
  • A participant challenges the idea of measuring acceleration without a separate frame of reference, proposing a scenario with only one object in the universe.
  • Several participants suggest practical methods to determine acceleration, such as using an accelerometer or weighing oneself, but the implications of these methods are debated.
  • Some participants express confusion about reconciling inertia with the theory of relativity, particularly regarding the absence of a fixed frame of reference.
  • There are mentions of different interpretations of inertia, including ideas related to Mach's principle and the influence of distant masses on inertia.
  • One participant emphasizes that not everything is relative, suggesting that some aspects of physics must be absolute to resolve the confusion around inertia.
  • Another participant notes the need to clarify the definition of "inertia," indicating that it may have multiple meanings depending on the context.
Participants express a range of views on the nature of inertia and its relationship to relativity. There is no consensus on how to reconcile the existence of inertia with the idea of relative motion, and multiple competing interpretations are presented throughout the discussion.
Participants highlight the complexity of defining motion and acceleration without a fixed reference point, and the discussion reveals limitations in understanding inertia in the context of relativity. The conversation also reflects varying interpretations of fundamental concepts, which remain unresolved.
jocanon
Inertia -- Why does it exist?
Can someone explain to me in terms of a thought experiement (not equations, please) why it is that inertia exists given that motion is only defined as it relates to another point of reference and given that there is no fixed point of reference but everything is relative? Who's to say something is moving or even accelerating unless defining it relative to another object and then who's to say it's not the other object accelerating and you are standing still...so I don't see how inertia even exists given all these facts.
Acceleration is not relative. One can always measure whether or not a frame of reference is accelerating.
But that is what I don't get, how does one measure whether or not the frame of reference is accelerating if you don't have a separate frame of reference to measure against? For instance, if there was only one object that existed in the universe, how would you measure that it is accelerating, sitting still, or moving, or anything...when there is nothing to compare it to except itself?
Use an accelerometer. For example, stand on a spring scale. It'll show the same reading regardless of your choice of reference frames.
Yes, that makes sense. I mean, I get that it exists, I just don't see how to reconcile it with the theory of relativity. It would reconcile in my mind if we still believed in Newton's concept of ether because then you have a fixed frame of reference.
But the Special Relativity says only inertial(non-accelerating) reference frames are equivalent. You're trying to reconcile a non-existent issue.
so I might be getting my terms wrong, but I know that inertia exists, I also think that modern day physicists believe that there is no fixed frame of reference...so I am still puzzled how these two facts can both be true. Because to say you are accelerating, you would have to compare motion over time as compared to some other point, but if there is no fixed point, than what other point are you comparing against. Then, that other point you are comparing against, how do you say it is not the one accelerating? Maybe there is just a simple concept I am missing here, but it doesn't seem possible to define motion, acceleration, or anything related to position without a frame of reference to define it against. BUT I know that inertia is a true thing, so doesn't that mean that there is a fixed point of rest in the universe, or some way to determine something is moving other than just how it is moving relative to another object? Am I making any sense?
There's an easy way to tell if you are accelerating or not. Hold a ball in your hand and gently release it. If the ball hovers stationary relative to you, you are not accelerating. If the ball starts to move relative to you, you are accelerating.
Or, as said in post #4, try weighing yourself on some scales. If the scales read zero you are not accelerating.
What gives you that weight on the scale, or makes the ball fall? If everything is relative, you cannot say you are accelerating if you say the whole universe is accelerating around you...however, I know this isn't right because the scale WILL tell me I have weight, or the ball WILL fall, so what I am thinking is that there IS a fixed frame of reference in the Universe and Einstein was not right about that point.
Shoosh, jocanon, don't go accusing Einstein of a crime he didn't commit!
As said earlier, relativity doesn't say all frames are equivalent. It only says all INERTIAL frames are equivalent. Go and check in the wiki article on SR, it's in the second sentence!
It's quite simple, really. You can never tell if your velocity is 0, but you can tell if your acceleration is.
You can't find an universal rest frame of reference(this means v=0 only!), but you can find e.g., one that is universaly non-rotating.
lol, i guess my simple mind is just not meant to understand this concept :)
Apperently I am not the only one that has this question. I just did some poking around on Google and found that some people believe inertia is the result of all the "fixed stars" mass interacting with ours while others believe it is an effect at the atomic level.
See: http://en.wikipedia.org/wiki/Mach's_principle
The bottom line is "everything is NOT relative". Some things are relative while others are not. Once you accept that experimental fact, all will be much clearer.
In that frame of reference the floor is exerting a normal force on the person and not on the ball.
In the case of free fall where a capsule is falling in a gravitational field and thus continually changing velocity, direction or both: the ball would float beside the floating person (tidal effects being absent or very small).
We can not measure weight without acceleration (gravitational or some other due to interaction forces)
There can be two reasons for that
1. Acceleration is the cause for mass
2. We just have not found a way to measure it without acceleration
Jocanon, Have you read this?
You would really need to define your word "inertia" before getting a reliable answer to this question. Inertia has at least two distinct meanings, depending on context. Are you referring to Mass, Momentum or what?
(Why are you rejecting the idea of "equations", out of hand - as if you think everything can be explained without them?)
Here are some words about inertia from Feynman
http://www.haveabit.com/feynman/2
  • · Replies 22 ·
  • · Replies 60 ·
  • · Replies 56 ·
