Why does light travel at varying speeds through different materials?
In summary, light travels at varying speeds through different materials due to its interactions with atoms along its path. Even though light is considered to be massless, it is still susceptible to gravity, as explained by the theory of General Relativity. This theory predicts that at the limit of zero mass, the trajectory of light will be twice as bent as predicted by Newtonian physics. This was supported by the famous eclipse experiment in the 1930s.
azzkika
60
Why does light travel at varying speeds through different materials??
why does light travel at different speeds through different materials??
for example, it travels at 38 mph through super cooled sodium.
also, if light is massless, why is it susceptible to gravity?? i don't know the formulae to examine, but i'd think mass is a factor when calculating gravity, and if so would a zero mass mean gravity has no effect, therefore meaning light does have mass??
Science news on Phys.org
Does light speed vary, or does its path and interactions vary?
good counter-question
It might help you to visualize a ray of light traveling through a mess of atoms. If the light is hitting atoms, won't it take longer for it to get through the material, even if it's traveling at a constant speed while it isn't hitting anything?
informative link, thanks.
i'm still puzzled as to why light is susceptible to gravity, yet defined as massless though.
1)You are making a non-relativistic consideration, that is a Newtonian consideration, while things are more complicated (General Relativity).
2) But even within the simple Newtonian physics, you can take a particle of mass m, look at the trajectory it follows in a grav. field, then reduce its mass to m/2 and look that its trajectory is still bent (if you remember, an object's acceleration in a grav. field does NOT depend on its mass); then make the mass go to zero: nothing changes, so at the limit m = 0, your massless particle still have to follow the grav. field. and so bend its trajectory.
3) The prediction of General Relativity is that the amount of bending of the particle's trajectory, at the limit m --> 0, is double than that calculated in the previous way.
4) The famous experiment of star's light deviated from the sun during an eclipse in the 30', showed that the correct prediction was that of Albert Einstein's General Relativity Theory.
1. Why does light travel at different speeds through different materials?
Light travels at different speeds through different materials because of the way that the material affects the electric and magnetic fields of the light waves. These fields interact with the atoms and molecules of the material, causing the light to slow down or speed up depending on the properties of the material.
2. What determines the speed of light in a material?
The speed of light in a material is determined by the material's refractive index, which is a measure of how much the material slows down light compared to its speed in a vacuum. Materials with higher refractive indexes will slow down light more, resulting in a lower speed.
3. How does the density of a material affect the speed of light?
The density of a material can affect the speed of light because it is related to the material's refractive index. Generally, materials with higher densities will have higher refractive indexes, causing light to travel at slower speeds.
4. Why does light travel faster in a vacuum?
In a vacuum, there are no atoms or molecules to interact with the light waves, so there is no slowing down of the electric and magnetic fields. This allows light to travel at its maximum speed, which is approximately 299,792,458 meters per second.
5. Can the speed of light in a material be changed?
Yes, the speed of light in a material can be changed by altering the material's properties, such as its temperature or density. For example, when light passes through a diamond, it travels slower than in air, but if the diamond is heated, the speed of light will increase due to changes in the material's refractive index.
11K
