Why Does My Varactor Diode Test Circuit Behave Differently on a Breadboard?
93 replies · 11K views · last reply
With a 9V battery and the NTE618’s I get .8uA of current, or 800nA. Per the data sheet for this device, reverse current at 9V is only 100nA. Recall that the observed reverse current at 4V was 300nA. My ultimate use of the varicaps is for adapting a WWII aircraft radio to electronic tuning. It relies on delivering a very precise voltage to the circuit over a fairly narrow range. My findings are making it difficult to predict the voltage actually delivered at the bias point because of the unexpectedly high reverse current that is causing a significant drop in voltage across the bias resistor, a voltage drop that varies with the supplied voltage.
Referring to the photo in post #27, try twisting all the leads together. This will greatly reduce stray pickup from the environment.
Three additional possibilities I can think of off-hand:
Using the physical setup in the photo of post #27, check the following:
  1. Meter is not Zeroed; does it read zero with the leads shorted?
  2. Stray pickup from the environment; nearby fluorescent or LED lamps often use switching regulators that can be very noisy. Even the old style 4-foot long fluorescent ceiling lamps with a ballast will radiate spikes from the several-hundred volt arc ignition voltage.
  3. There may be ripple or oscillation coming from the power supply you are using. Try putting a 0.1uF disc ceramic capacitor across its output terminals.
You can also put as much of the circuit as possible in an oven that has a window so you can still read the meter. A Microwave oven has better shielding, but a kitchen stove oven has a fair amount. (Don't turn on the oven though. :wink:)
A photo showing complete equipment layout of the setup from post 27 may give us some more clues.
Cheers,
Tom
That is quite a challenge.
What is the radio make and model number ?
What is the frequency range of the LO ?
Are you replacing the LO only, or are you also tuning some other RF circuits ?
It’s the SCR-522 from the P-51 Mustang. The LO range will be 106-126 MHz for civil aviation. I am tuning 3 RF circuits as well, up to the mixer stage. The desired frequency is selected on a microcontroller which then calculates the bias voltage needed to create the requisite capacitance for resonance at that frequency minus the IF. The old ratchet style tuning with crystal oscillators for four channels is missing from my radio, no parts are available, and no other such radios are available in the world. Without the ratchet system it would not be possible to have four preset channels available for the pilot to select, but it can be done with electronic tuning.
It looks to me like it has RF tuning only on RX, but has two separate switched four channel crystal oscillators, one for TX, the other for RX. It should be possible to replace the crystal oscillator(s) with digital synthesizer board(s). The harmonic multipliers that generate the TX carrier, and the LO for RX, can still be used.
There should be no problem using varactors to tune the small RF signals in the RX path, but you can expect problems generating the higher amplitude RF needed to replace the crystal oscillators. For those, you should look at synthesizer ICs that include a current controlled CMOS oscillator inside a PLL.
Yes, I’m using the Si5351 chip for that
…and it works beautifully!
If you can read the AGC voltage with the processor, you can inject a small RF signal into the receiver front end. The processor can do a peak search to optimise the RF tuning, without needing to store three calibrated tables of data. Depending on the time constant of the AGC, which you can switch, the tuning process can take less than a second, whenever you change the channel frequency.
AGC = Automatic Gain Control.
https://en.wikipedia.org/wiki/Automatic_gain_control
The receiver signal strength meter shows the AGC voltage. The AGC voltage controls the gain of the IF amplifier strip. The received carrier voltage is detected at the output from the IF strip and maintains the carrier level at the detector.
If you have the same circuit for the SCR-522 as I do, you will see the meter connections to the second grid of the RF amplifier, in the bottom right-hand corner of the BC-624A receiver block. I think the signal was there called A.V.C. (Automatic Volume Control) and is connected to all IF amplifiers. It is also used to mute the receiver during transmit.
OK, I got it. Let me chew on that a bit. The main problem now is that I am not getting expected results even with the simplest of Varactor circuits.
Are you saying I can send the desired frequency to the receiver’s RF coil at a low level and then do a reverse bias voltage sweep to the varactors to look for a maximum RF voltage at the 288 meter output?
Yes, but I don't know what your 288 meter output is. Maybe a link to the circuit diagram you are using.
I have done it before. You inject a small test carrier as a fake RF signal into the RX front end. It is RF amplified and converted to the IF frequency, amplified along the IF strip, then detected by the audio detector where the slowly changing DC component becomes the AGC voltage. For an AM receiver, the AC component of the detected signal is the audio. By changing the varactor bias and reading the AGC voltage, the processor searches for the best signal peak versus varactor bias voltage.
There seem to be two RF tuned circuits that would benefit from tuning. Then the IF is 12 MHz all the way through, so that does not change. Maybe the local oscillator also needs tuning, but that will depend on how you generate and inject the LO into the mixer.
For normal operation, the AGC must be slower than the low frequency audio, so you can benefit from speeding up the AGC time constant during tuning. You should be able to optimise the RF tuning in less than a second. Once autotune is done, turn off the injected RF and switch back to the normally slow AGC.
The 288 meter output is the meter connections to the second grid of the RF amplifier as you described above.
piepermd said:
How do I change the AGC time constant?
It turns out the AGC is connected to bias G1 of the RF amp, and the 1st and 2nd IF amps. The AGC is the lowest line on the diagram below the IF strip, that goes to the "AVC", terminal 6 on the main receiver connector.
Just to make it interesting, the receiver IF strip amplifies the signal from RF on the right to the AGC and audio detectors in the same stage on the left. The detected AGC is low-pass filtered by resistor, 262-2 and capacitor 211-C before distribution. I believe that LC circuit sets the AGC time constant.
There is an RC filter at each of the three stage bias connections that allows the AGC bias to pass, but prevents the RF or IF output getting back to the RF or IF input via the AGC line, which would cause it to howl like an oscillator. Hopefully the time constant of those attenuators will be short and can be ignored.
The +HT supply, drawn above the AGC line on the diagram, is also bypassed to every stage, but also has a bigger reservoir capacitor to ground, 206-15. The meter connections appear to be part of the +HT circuit.
Yes, I can see what you mean on the schematic. So from exactly where do I send the voltage to the microprocessor to look for a peak when sweeping the bias voltage to the varactors? I still don’t know how to change the time constant, and I don’t know what you mean by the “+HT supply”.
You will need to check the range of the AGC voltage by injecting a big and a small test signal for the selected channel. That safe voltage you give to the processor will be derived from the AGC voltage, since that sets the gain of the strip, needed to overcome any off-tuned RF circuits. As you tune the RF, the AGC will change.
I would disconnect capacitor 211C and replace it with something three orders of magnitude smaller, while watching the AGC line with an oscilloscope. If higher frequency audio modulation appears on the AGC line, then you have shortened the time constant. When you inject a sample RF signal without modulation, the AGC will change quickly to show the gain of the receiver.
You might use a relay to change the TC during tuning. If the voltage was low enough, I would consider a FET of some sort.
+HT is the high tension positive supply, being hundreds of volts. It supplies the positive voltage to the (anode) plates of the vacuum tubes, usually through an RC low pass filter, then through the primary of the tuned coupling transformer. The transformer secondary drives the grid of the next stage. Prepare to be confused, the signal flows right to left in that circuit diagram.
Thank you SO much for your help with this project thus far! I’ll keep you posted…
My receiver has been somewhat modified, using some of the ideas from the BC-624-AM and BC-624-C circuits. I wasn’t sure how much of this had been implemented in my radio but I spent the last two days going over it and it appears to match the mods published for HAM conversion many years ago. Here is a schematic showing the mods. I’m not sure how this might affect using the AVC voltage for tuning.
If you have an S-meter, then you have a voltage and current signal proportional to signal strength. If that can be converted to a low voltage, it can be digitised by the autotuning processor during the peak search.
Can I just use a pair of resistors as a voltage divider to decrease the voltage for input to the microprocessor pin? Do I still need use a relay to switch the capacitor to change the time constant of the AVC circuit?
We need some way to prevent the forum corrupting schematics.
Maybe you could email me the original diagram as an attachment, or provide a link to the web discussion with the diagram.
Now I see the circuit, the 250k S-meter pot, used I assume to adjust FSD of the S-meter, is such a divider chain and the voltage on the wiper contact will be at the lower end of the voltage range. Check out that wiper voltage with an oscilloscope. The S-meter is connected to the VT-207 plate circuit and the +HT supply, which is not good for A-D converters.
I am not yet sure how the AVC on/off switch works, or what sets the time constant. I will look at that in 8 hours when I get back.
Usually the AGC will be automatic when listening to several different transmitters, but when listening to only one, the AGC voltage is set with an RF gain pot, so the detected voice is clear, and the background noise does not rise to fill the quiet gaps in speech.
The top of the 250k S_METER pot is the source of AVC voltage, negative-going with increasing signal strength.
The AVC voltage is tapped off thru the resistor going to the left of that junction. The AVC time constant appears to be 15ms, if i'm reading the blurry values correctly of 1.5Meg and 0.01uF.
The switch above those two components switches the AVC line to ground (OFF) to disable AVC, and to the 15ms RC filter (ON) to enable AVC.
The left half of the dual diode tube, 12H6, is the AM detector, the right half is the Noise Limiter, whose threshold varies with received signal strength.
Hope this helps!
Tom
Outstanding, thank you! I just need to be sure that the maximum voltage at the analog input pin is less than 5V. I imagine the voltage will vary quite a bit depending on the strength of the test signal applied to the the RF coil and this will need to be optimized as well. What I really like about this approach is that so many variables are eliminated, and I would no longer need to use a calculated bias voltage based on a theoretical model of the varactor’s behavior but can use how the circuit responds under real conditions.
Hope this helps!
Tom
It helps, thanks! I didn’t realize the voltage is negative, though. That tends to wreak havoc on a microcontroller input pin. There are some ways around it, but I think it will make the circuitry more complex.
