Why does red food coloring look green when it dries?
  • Context: Undergrad
  • Thread starter Thread starter Happy Scientist
    Food Green
The discussion centers on the optical behavior of red and green food coloring when dried on a glass slide. When dry, red food coloring appears light green due to reflection, but looks red when light passes through it. This phenomenon is attributed to the principles of absorption, transmission, and reflection of light, particularly in relation to the chemical composition of the dyes, which include FD&C RED 40, FD&C YELLOW 5, and FD&C BLUE 1. The conversation also touches on the effects of oxidation and the role of citric acid in potentially altering the color change process.
  • Understanding of light absorption and reflection principles
  • Familiarity with the chemical composition of food colorings
  • Knowledge of optical properties of materials
  • Basic concepts of fluorescence and color theory
  • Research the optical properties of organic compounds in solid and liquid states
  • Explore the effects of citric acid on food coloring stability and oxidation
  • Investigate the principles of fluorescence in chlorophyll and other pigments
  • Learn about the interaction of light with translucent versus opaque materials
This discussion is beneficial for chemists, educators in optics, food scientists, and anyone interested in the science of color and light interaction with materials.
Happy Scientist
While experimenting with an idea for a demonstration in surface tension, I ran across something interesting. I placed a drop of red food coloring on a glass slide, and let it dry. Once dry, the residue was a light green in color, but when held up to let light pass through it, it looked red again. I tried this again, using green food coloring. Once again, the colors reversed. The residue looked red when light reflected from it, but green with transmitted light.
After quite a bit of searching, I came across a few articles talking about something similar with fluorescence in chlorophyll, but I am not sure this is the same thing.
http://plantsinaction.science.uq.edu.au/content/125-chlorophyll-fluorescence
Anyone have any thoughts on this?
Science news on Phys.org
The usual cause of color change of food is oxidation. But I'm not sure if this can explain this complementary effect you described. However, I would try to find out what the colors are made of and how these chemicals react with air / oxygen. Citric acid can slow down oxidation, which means it would be interesting to know, what happens if you add some of it before drying.
That was my first thought too, but if you redissolve it, it goes back to its original color. It also still looks its original color when light shines through it. It is only when light reflects from it that the color changes so dramatically.
For the red, the ingredients are: WATER, PROPYLENE GLYCOL, FD&C REDS 40 AND 3, AND 0.1% PROPYLPARABEN (PRESERVATIVE).
For the green: WATER, PROPYLENE GLYCOL, FD&C YELLOW 5, FD&C BLUE 1, AND PROPYLPARABEN (PRESERVATIVE).
I will take some photos tomorrow in sunlight, and post them.
Actually, I have wondered why all translucent colors don't appear this way.
Consider a red tail light lens cover on a car. It filters the broad spectrum of the filament bulb, passing the red spectrum, so the light from the bulb appears red to us. So doesn't that mean it is reflecting the other colors? So when we look directly at the lens, shouldn't it appear blue-green to us?
It is mostly absorbing the other colors (wavelengths).
So absorbing rather than reflecting? I think that makes sense to me.
Is that essentially the difference between a translucent object and an opaque one? We can't see through an opaque one, as the other light is being reflected? There's maybe other causes/conditions, but is that part of it? Thanks.
There are several processes that may be present in any given situation: transmission, reflection, absorption and scattering. For an opaque coated mirror, it is mostly reflection from the metal coating. For a covering layer of paint, it is mostly absorption and scattering, with some reflection. Depends on the specifics of the material.
There are multiple effects going on here, like pixel said. For this situation, we are mostly concerned with absorption, transmission, and reflection. Since you're probably looking at this under white light scattering doesn't really matter.
In solution, the dye molecules are dispersed and as you are viewing them, the dominant characteristic is absorption and transmission. In this situation, they look the color that they do because they absorb one color and transmit the complement. This is kind of like a resonant electronic excitation. In the solid state the situation is different. There is now a surface with a solid/air interface where reflection can occur, and in general surfaces can very different optical properties from the bulk as well. When you hold the solid up to the light it still behaves normally, because now you are looking at absorption/transmission like you were in the liquid. If you look at the surface at an angle, you are mostly seeing the surface contribution, which for organics often behave how you describe. This is due the the details of the optical dielectric properties of the material and the electronic structure that's typical of organics.
  • · Replies 20 ·
  • · Replies 207 ·
13K
  • · Replies 40 ·
  • · Replies 23 ·
10K
  • · Replies 25 ·
