Why Does the Area Under a Diffraction Curve Equal This Value?
  • Level: Undergrad
  • Thread starter Thread starter albertrichardf
    Area Curve Diffraction
albertrichardf
Hi,
consider the following curve:
[tex]f(\theta) = \frac {I_0sin^2(n\theta/2)}{sin^2(\theta/2)}[/tex]
When the area over a cycle from ##0## to ##2π## is evaluated it gives ##(2πnI_0)##. This is exactly ##\frac {I_{max} + I_{min}}{2}## , since
##I_{min}## is ##0##. Is this a coincidence, or is there a reason behind the area under the curve is the same as this value?
Thank you for your answers.
Does this mean that ##I_{max} = 4\pi n I_0## all the time? If so, then that would be all the coincidence needed.
## I_{max}=n^2 I_o ##. The maximum occurs periodically when both the numerator and denominator equal (i.e. approach) zero. This is in the limit ## \frac{\theta}{2} \rightarrow m \pi ##. I don't know if you have the integral evaluated correctly for a single cycle. I would need to try to look that one up. I don't even know that it has a simple closed form. ## \\ ## Usually the letter ## \phi ## is used instead of ## \theta ## in this diffraction theory integral for ##N ## slits, where the phase ## \phi=\frac{2 \pi d \sin{\theta}}{\lambda} ##, and the ## N ## is designated with a capital letter.
