Why Does the Chain Rule Work in Calculus?
The discussion revolves around understanding the chain rule in calculus, specifically why it works rather than just how to apply it. The chain rule expresses how the rate of change of one function affects another, illustrated through the relationship between dy/du and du/dx. A visual explanation is provided, suggesting a method of sketching functions and their transformations to grasp the concept better. The importance of comprehending the underlying principles rather than relying solely on formal proofs is emphasized. Overall, the conversation highlights the need for deeper understanding of calculus concepts through visualization and intuitive reasoning.
alech4466
I just learned about chain rule in calculus, but I was wondering why exactly chain rule works. I understand how to use it, just not exactly why it works.
Thanks in advance
Do u have the proof in terms of the epsilon?
I do not. I pretty much have only seen one proof of it in the calculus book, though the proof didn't explain why it works
Tom is running twice as fast as Bob. Sally is running three times as fast as Tom. Hence Sally is running six times as fast as Bob.
http://people.hofstra.edu/stefan_waner/Realworld/proofs/chainruleproof.html"
The abv. is the proof of the chain rule.
Layman(It is different from the proof):
dy/du = How y changes with the change in u
du/dx = How u changes with the change in x
(dy/du)(du/dx)
=(How y changes with the change in u)(How u changes with the change in x)
=How y changes with the change in x
Thanks
[f(g(x)]' = f'[g(x)].g'(x)
Apart from formalities. On a piece of paper, draw rectangular axes. Right top quadrant is going to represent g (example of positive x and positive g(x) ). Sketch a smooth function in that quadrant. Horizontal axis is x, vertical is g(x).
Now turn paper 90° clockwise. The g axis is still the g axis but now it is horizontal. Draw another smooth curve in the now top quadrant – that represents f. The now vertical axis (think of it as a different piece of paper) is the f of the corresponding points of the now horizontal axis. I.e. is f(g).
So, turning the paper back to its original orientation, starting from a point x, if you draw a vertical line to the first curve, and from the meeting point a horizontal line to the second curve, you get to f[g(x)] on the second curve (turning the paper again). Take a point just above x and do the same thing again. You get a thin strip of width dx (think as) and then another thin strip of width g’(x).dx and rotating the paper again you should be able to see that it corresponds to an increase of f (i.e. df or in full d[f(g(x))]) of [f(g(x)]' = f'[g(x)].g'(x).dx
It should be more apparent when you do it than these words sound.
I ought to do a fig. maybe I will. My point is that this ought to be obvious, if it is just a thing you only learn and can demonstrate by a formal procedure it is not understood in my opinion.
Something like this - maybe can be improved.
