Why does the same current flow through resistors in series?
The discussion revolves around the behavior of electric current in a series circuit with resistors, specifically why the same current flows through all resistors despite their presence. Participants explore concepts related to resistance, potential difference, and the analogy of electric circuits to mechanical systems.
  • Some participants question the role of resistors, asking what they do to the charge if they do not slow it down or decrease potential energy.
  • Others suggest that the concept of current as a constant flow may not align with mechanical models of particles, proposing that electrical phenomena should be understood through different analogies.
  • It is noted that the average velocity of charge carriers remains constant in a homogeneous resistor, and that resistors affect the entire circuit by reducing the overall current, not just the speed of charge through the resistor.
  • Some participants emphasize that while potential difference changes across resistors according to Ohm's Law, no charge is created or lost in the process.
  • There are discussions about how inserting additional resistors affects the potential energy distribution in the circuit and how the current reaches a new steady state after changes are made.
  • The analogy of a garden hose is used to illustrate how a change in one part of the circuit can affect the flow throughout the entire system.
  • Participants express uncertainty about how resistors can influence the entire circuit simultaneously, with some suggesting that this is analogous to how a faucet affects water flow in a pipe.
  • There is mention of a 'settling in' time for circuits when first connected, indicating that simple circuit rules apply only after electric fields are established.
Participants do not reach a consensus on the exact mechanisms by which resistors affect current flow in the entire circuit. Multiple competing views and analogies are presented, indicating ongoing debate and exploration of the topic.
Some participants highlight the limitations of using mechanical analogies to describe electrical phenomena, suggesting that the behavior of electric circuits may not be fully captured by such models. There is also mention of the time-dependent nature of current changes in circuits, which may not be immediately apparent.
Andrea Perry
This is something I have been trying to figure out lately, but I can't seem to wrap my head around it.
So, according to a definition in my Physics textbook, while the electrical potential difference established between two terminals encourages the movement of charge, it is resistance that discourages it.
If current is the rate of the flow of charge over a given amount of time, and it is the same through all resistors, then what exactly are the resistors doing to the charge if they're not slowing it down (decreasing the potential energy?)?
If you are thinking of an "energy of motion", don't you mean "kinetic energy"?
If you try to use a model of current as particles under action of a net constant force, the particles would accelerate. They wouldn't have a constant velocity. So a very basic question is why the idea of current, as a constant flow is a good model in the first place. I don't think you can wrap your mind around the phenomena of electric current by thinking of simple mechanical models.
Electrical phenomena are often presented by analogy to hydraulic phenomena. Perhaps you could try that route.
This was discussed many times on this forums. Maybe you can look it up.
The idea is that the charge is not entering the resistor (or any portion of circuit) with a larger velocity and leave with a lover velocity.
The average velocity of a charge carrier is the same everywhere in a homogeneous resistor.
At this level is better to think of the effect of the resistor in terms of current and voltage and forget the microscopic picture.
The resistor "discouragement" of charge movement translate into reducing the current through the circuit. The whole circuit, not just through the resistor. And this means that less charge flows through any cross section in a given time. It does not mean something about the speed of this charge.
The current is the same everywhere simply because otherwise there will be accumulation of charge in some portions of circuit and this will create extra fields which will very quickly will take care to equalize the flow.
That's exactly what each resistor is doing when a current flows thru it: the potential difference before and after the resistor drops a bit according to Ohm's Law, V = IR.
There is no additional charge created by passage thru a resistor, nor is any charge lost. The potential difference, i.e. the voltage, however does change.
Speed determines kinetic energy, not potential energy.
This may be confusing. It sounds like there is a potential difference before and another one after the resistor. Difference between what?
Actually the potential is lower at one end than at the other end. And the difference between the potentials at the two ends is given by Ohm's law.
This seems to make more sense; however, how is it possible that the resistor affects the entire circuit at once?
It's not clear what you mean here.
To clarify, potential differences are measured with respect to ground, which is taken to be V = 0. It's analogous to mechanical potential energy, PE = mgh, which is measured w.r.t. some convenient datum.
If you squeeze the garden hose at some point, won't the debit of water decrease everywhere, including at the end of the hose?
Te water circuit is not a very good analogy, but it may give some image.
What actually happens is that inserting an extra resistor in series with an existing one, the potential energy that initially was used only to push charge through one resistor will be divided between the two resistors (not equally, in general).
The "at once" does not make much sense here. For any change in circuit, there is some time before a new steady state is reached. For example, when you close the switch, the current increases from zero to some value (given by ohm's law). All the discussion is about what happens after this transitory regime.
When we say that the current is the same for the entire circuit, we mean in this steady state. If in a circuit with one resistor and a current I1 we cut the wire and introduce a second one, it will again take some time (very-very short) to reach the new steady state, with a current I2. This I2 is less than I1.
Andrea Perry said:
What I meant is: How is it that a resistor discourages movement of charge throughout the entire circuit, instead of just through the resistor?
The charge is still moving thru the network. It's just that the potential difference, i.e. the voltage, decreases a little bit every time the current flows thru a resistor.
Terms like "discourages movement" are pretty imprecise when describing the behavior of electricity and electric circuits.
That's like asking how does a tap/faucet effect the flow of water in the entire pipe?
This is similar to the "how does a resistor know what to do in its circuit?" question. The fact is that, at switch on, the rules about how circuits work do not apply in the simple way that we learn for starters. There is always a 'settling in' time, after a circuit is first connected up. Charges flow and electric fields are set up, the effects traveling around a circuit at near the speed of light. Simple rules like Kirchoff and Ohm's law only apply in their simple form after the EM wave has rippled around the circuit and then everything 'knows' what to do.
  • · Replies 21 ·
  • · Replies 22 ·
  • · Replies 17 ·
