Why Does V1 Equal Zero in My KCL Thevenin Calculation?
  • Thread starter Thread starter Fjolvar
The discussion centers around a problem with finding the Thevenin equivalent circuit using KCL, where V1 equals zero in the second set of equations due to the dependent current source. Participants clarify that the correct expression for the current source should be (V1-8)/2, not 8V/2Ω. The issue arises because the dependent source drains the entire current sourced through a 20Ω resistor, complicating the setup of equations to find unknowns. An alternative approach suggested involves applying a test voltage across the terminals to determine impedance, indicating that the Thevenin equivalent may be a simple resistance. The conversation emphasizes the importance of correctly identifying node voltages and the impact of dependent sources on circuit analysis.
Fjolvar
I tried solving this problem using KCL, but V1 keeps adding up to zero for my second set of equations. I'm not sure what I'm doing wrong. Any help is much appreciated.
1. Homework Statement
I need to find the Thevenin equivalent circuit. I chose to find the Isc and the Voc by using KCL, since I don't see another way.
KCL
[/B]
You can see for equation 2, my V1 equals zero due to the dependent current source relation. Not sure how to get around this.
Right at the start you write is = 8v/2Ω
Why do you say this?
My mistake. That should read (v1-8)/2.
I'm still stuck on the second equation however since v1 equals zero. Am I missing something obvious here?
I don't think that's right either.
Edit: Do you mean "Is = (v1-8)/2" or that term in equation should be (v1-8)/2 ? The latter is correct.
That's for the term in the first KCL equation. But V1 in the second equation equals zero which has me stuck. I can't set up my equations to find any of the unknowns.
I think you mean V2 = 0 not V1.
I mean (-1/20 + 1/20) zeroes out V1 at node 2, since the dependent source is equal to 0.05V1
I see the problem. They cunningly have the current source always draining the entire current sourced through the 20Ω.
An alternative method to determine the impedance at ab is to apply a test voltage across ab and calculate how much current is drawn from that source. I guess that means the Thévenin equivalent will then be a simple resistance.
I'm not quite sure what you mean :/
If V2=0 you can connect node V2 to 0V with a wire. Try that and redraw the left hand side of the circuit.
Connect a 1v supply to the right-hand side of a-b and calculate the current that flows into a-b from that 1v source.
