Why doesn't order matter in this
  • Thread starter Thread starter aaaa202
    Matter
aaaa202
Say you have two black balls and two white in a jar and you pick 3 at random. When one is picked it is taken out of the jar.
I want to know the probability of getting for instance WWB. That must be:
P(WWB) = 1/2*1/3*1 = 1/6
Now say you want WBW. Then you get:
P(WBW) = 1/2 * 2/3 * 1/2 = 1/6
Amazingly enough the probabilities are independent on the order in which you choose your balls. This result is kind of amazing for me and not really intuitive. So far it stands more or less as a defining property of this kind of combinatorics.
Is it intuitive for you that the order really is independent? What argument would you give for this?
And lastly, perhaps even more interestingly: Can anyone prove that if you general have NA blue elements and NB red elements then the number of ways of getting a blue and b red elements is independent of order. I don't know if it's an established theorem - if so, where can I read more about it?
Just look at those calculations: in the first you have the fractions 2/4, 1/3, and 2/2. In the second, the fractions are 2/4, 2/3, and 1/2. Do you see that, while the fractions are different, the three numerators and three denominators are the same?
Do you see why that is true? Do you see that, because the numerators are the same and the denominators are the same, the products are the same?
I see it yes. Why it's true I'm not sure.
Ivy, can you please help on the intuition for it?
The order does not matter in general case.
Suppose you have b black balls and w white balls. The total amount of balls is n=b+w.
Consider a sequence {B,W,B,B,...,B,W}. The probability that this sequence occurs is:
\frac{b}{n}\frac{w}{n-1}\frac{b-1}{n-2}\frac{b-2}{n-3}...\frac{b-(b-1)}{2}\frac{w-(w-1)}{1}
Note that the numerator of this sequence is b(b-1)...(b-(b-2))(b-(b-1))w(w-1)...(w-(w-2))(w-(w-1)) and the denominator is n(n-1)...(n-(n-2))(n-(n-1)).
You should notice that whenever you want to choose b black balls and w white balls, the numerator and the denominator will be the same. The order of the elements of both products will be different, but you know that scalar multiplication is commutative (i.e. order does not matter).
The fundamental ideas are the we can multiply fractions by multiplying numerators and denominators separately and that multiplication is commutative. That is, we can rearrange the numerators and denominators as we please.
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
