Why doesn't the makeSix function change the value of the variable?
9 replies · 3K views · last reply
Mogarrr
I'm reading the online tutorial "How to Think Like a Computer Scientist", which is a Python tutorial. There is an exercise, which I'm trying to figure out.
What happens if you call a function and you don't do anything with the result (i.e., you don't assign it to a variable or use it as part of a larger expression)?
My intuition is that nothing happens. To show this, I typed the following in the command line...
def nada(something):
nil = something
As predicted, when I call the function nada, nothing happens. Is this what the author meant by doing nothing with the result?
Experimenting with functions, I also discovered something that disturbs me about Python. I made a function...
def makeSix(number):
number = 6
Now I would think that the makeSix function will change the value of a variable to 6. For instance, I typed this:
x = 9
makeSix(x)
print x
Which is frustrating, since I would think that the value of the variable would change to 6.
What's going on?
What they mean, I believe, is a function that actually returns a value but you don't do anything with the returned value.
Here's an example in C, which I'm more familiar with than Python.
Code:
#include <stdio.h>
int fun(int arg)
   return arg * 2;
int main(void)
   int val = 3;
   fun(val);  // Here I call fun() but don't do anything with the returned value
   printf("val is %d", val);
   return 0;
number = 6
x = 9
makeSix(x)
print x
What's going on?
This is a matter of the parameter passing strategy adopted by the language. It appears that you are expecting call-by-reference semantics and getting call-by-value semantics.
http://en.wikipedia.org/wiki/Evaluation_strategy
There are many functions that don't return any value, yet they are called to do something. If they do something, they apparently change the state of the system - so you can't say "nothing happens".
The first post in this thread consists of two questions:
1. What happens when you call a function that returns a value, but don't do anything with the returned value? (I.e., don't store the value or print it or whatever.)
2. If a function changes the value of a passed parameter, does this affect the value of the actual argument?
For the first question, the OP says
However, the OP's example function doesn't return a value, so I don't believe he/she is really answering the question.
jbriggs444's post is in reponse to question #2. In call-by-value semantics, which are the default in C and probably Python, a function is given essentially a copy of the parameter, so any changes that the function makes don't affect the original parameter. Other languages, such as Fortran, use call-by-reference semantics, so a function can change the value of the actual argument. C, C++, and some other languages derived from C are able to simulate call-by-reference by using pointers to the arguments.
I am not a Python guru, but read the following code:
Code:
# SNIPPET 1
x = 9
def make_six():
  x = 6
make_six()
# here x == 9
Code:
# SNIPPET 2
x = 9
def make_six(x):
  x = 6
make_six()
# here x == 9
Code:
# SNIPPET 3
x = 9
def make_six(x):
  x = 6
x = make_six(x)
# here x == None
Code:
# SNIPPET 4
x = 9
def make_six(x):
  x = 6
  return x
x = make_six(x)
# here x == 6
Code:
# SNIPPET 5
x = 9
# the only one that actually messes with your original variable and makes it == 6
def make_six():
  global x
  x = 6
make_six()
# here x == 6
Comments:
SNIPPET 1: make_six initializes a local variable x and sets it to 6. Returns None.
SNIPPET 2: make_six has a parameter x, it sets the local variable x (that stored the value passed as an argument) to 6 and returns None.
SNIPPET 3: we assign the return value from the function to x. As it returns None, x becomes None.
SNIPPET 4: now our function gets the value x, overwrite it with 6 and returns it. (So, with an assignment, x becomes 6).
SNIPPET 5: finally, what you wanted: it reaches another scope, grab the reference to x, shove an integer with the value 6 in it and dies. No need for an assignment or parameter.
PLEASE, do note that make_six is ridiculous as you could just assign 6 to whatever you wanted in the first place.
Didn't see this one. Well, a lot can happen without an assignment.
Code:
import sys
def program_killer():
   sys.exit(0)
program_killer()
x = 4
x will never become four. x will never be defined. x will never be more than an instruction not to be followed by the interpreter. Poor x.
SO NO! Something happened. Indeed, as I said, a LOT can happen.
To do nothing with the result (that in Python is, unless specified otherwise, None) means not to hold it in a variable, list, tuple, (any other container), or pass it as an argument to something.
Code:
def get_none():
  pass
# does something with the result
print(get_none())
# does something too
woah_this_will_store_none = get_none()
# THIS IS DOING NOTHING WITH THE RESULT
get_none()
Thanks for the help guys.
I'm curious, in a post how did you display code inside the white box?
Like this:
[NOPARSE]
Code:
... some code ...
[/NOPARSE]
Code:
... some code ...
Code:
def give_thanks()
  print 'thanks'
give_thanks()
exit()
