Why don't Cooper electrons accelerate infinitely?
  • Context: Undergrad
  • Thread starter Thread starter member 666967
    Accelerate Electrons
The discussion centers around the behavior of Cooper pairs in superconductors, specifically addressing why Cooper electrons do not accelerate infinitely despite the absence of resistance in superconducting currents. Participants explore concepts from quantum mechanics and electrical theory, including the implications of zero resistance and the nature of superconducting currents.
  • Some participants describe Cooper pairs as composite boson particles formed from two coupled electrons, which contribute to superconducting currents that do not dissipate energy.
  • There is a suggestion that with a constant voltage applied, a constant current flows in superconductors, though this is debated regarding the conditions under which this occurs.
  • One participant questions the assumption that Cooper electrons would accelerate infinitely, proposing that the electrical formula ##V=IR## implies zero voltage with zero resistance.
  • Another participant introduces the concept of the Nambu-Goldstone field and its relation to the acceleration of Cooper pairs, indicating that the time derivative must be zero.
  • There is a discussion about the role of external energy sources in accelerating electrons, referencing how colliders operate with powerful electromagnets.
  • Some participants propose that the wave function of Cooper pairs suggests they are not localized and possess long-range coherence, complicating classical interpretations of current motion.
  • The maximal speed of electrons is noted to be the speed of light, with questions raised about the behavior of superconductors under high-speed conditions.
  • There is a debate regarding the Meissner effect and whether it expels electric fields in addition to magnetic fields, with some participants expressing confusion about its representation in textbooks.
  • The nature of electric fields in perfect conductors is discussed, particularly in relation to the initiation of current and the conditions under which electric fields may not be zero.
Participants express multiple competing views regarding the behavior of Cooper pairs and the implications of superconductivity. The discussion remains unresolved, with no consensus on several key points, including the nature of electric fields in superconductors and the conditions for current flow.
Limitations include varying interpretations of quantum mechanics principles, the dependence on specific definitions of resistance and conductivity, and unresolved mathematical steps regarding the behavior of Cooper pairs in superconductors.
member 666967
TL;DR
cooper pairs, composite boson particles (spin number = 0 or 1) from two coupled electrons. The movement of cooper pairs is forming a superconducting current. Superconducting current does not have a dissipation of energy from Resistance as it happens in normal current so Qubit (Quantum bit) circuit could be treated as a system of only conservative forces. Why are not cooper electrons infinitely accelerating?
Hello, I am trying to learn Quantum mechanics and have some questions I cannot answer. cooper pairs, composite boson particles (spin number = 0 or 1) from two coupled electrons. The movement of cooper pairs is forming a superconducting current. Superconducting current does not have a dissipation of energy from Resistance as it happens in normal current so Qubit (Quantum bit) circuit could be treated as a system of only conservative forces. What is a potential for cooper pairs to move into? Why are not cooper electrons infinitely accelerating?
Jirnyak said:
Summary: cooper pairs, composite boson particles (spin number = 0 or 1) from two coupled electrons. The movement of cooper pairs is forming a superconducting current. Superconducting current does not have a dissipation of energy from Resistance as it happens in normal current so Qubit (Quantum bit) circuit could be treated as a system of only conservative forces. Why are not cooper electrons infinitely accelerating?
If you are learning QT then starting with super-conductivity is bold ( and probably unwise). It is an interesting feature of this phenomenon that the equations predict that with a constant voltage applied across the superconductor a constant current flows. We cannot say why - it just happens that way.
Why do you think they would be?
Probably beacuse the electrical formula ##V=IR## suggests this with zero resistance.
No, they predict that with zero voltage applied a constant current flows.
No, it suggests that ##V = 0## with ##R = 0##. See above.
Sorry if I mislead you. Just to make my point about how tricky 'infinite conductivity' is, look at this (great) paper
https://academic.oup.com/ptps/article-abstract/doi/10.1143/PTPS.86.43/1885987
My mistake is not remembering that it is the time derivative of the Nambu-Goldstone field that must be zero and this is equal to -V ( equation 29 ).
To accelerate electrons beyond the total watt power of the source, an outside source of energy is needed. This is how colliders work - they employ ultra powerful electromagnets to do the job.
I think that you could write down the wave-function for the Cooper pair and then apply the acceleration operator. That should give you 0. My understanding is that the wave function of a Cooper pair goes all around the superconducting loop and everywhere has a non-zero current density operator and a zero acceleration operator.
Perhaps one of my colleagues could describe that in more detail or tell me that I am wrong. In any case, superconducting electrons are not little microscopic horses racing around a track and accelerating as they go.
Apply the concept of plane wave solution that you learned in basic QM. What do you think is the "average position" of a particle having such a wavefunction.
The Cooper pair wavefunction is a combination of such plane waves, meaning that these pairs are not localized. They have what we call "long range coherence", which is why they form supercurrents. You will run into huge conceptual problems if you try to apply classical E&M and classical electric current motion to such a scenario.
Zz.
Because the maximal speed of electrons is the speed of light.
But perhaps the right question is this. If we put a superconductor in a synchrotron which accelerates electrons by electric field which lasts for a long time, will the electrons approach the speed of light in the superconductor (as they do in the vacuum)? I don't know the answer, perhaps a superconductor looses its properties at very high electron speeds.
"Photons inside superconductors develop a nonzero effective rest mass; as a result, electromagnetic forces become short-range inside superconductors."
per Wikipedia | Photon | Properties | Experimental checks on photon mass | reference #39 Frank Wilczek, (2010)
Interesting. Does it mean that the Meissner effect expels not only the magnetic field from the superconductor (which every textbook says), but the electric field as well? If so, why is it not mentioned in the textbooks?
I don't know... I've seen the EM force law described as "exponentially damped"
But this is by default because you have a perfect conductor.
Zz.
But if the electric field is always zero, then what gives the electrons the initial velocity needed to have the electric current in the first place? It is only during the stationary current that the electric field is zero in a perfect conductor. When the current changes (which is what this thread is about), then the electric field in a perfect conductor is not zero.
There is no initial velocity the same way that photons have no initial velocity. There are already current flow in all directions. It is just that when a voltage is applied, a particular direction is selected.
Zz.
Are you saying that it is impossible to have an alternating current in a superconductor?
Where did I say that, or even implied that?
AC in superconductivity isn't as simple as DC, because now, the AC resistivity is no longer zero. The electrons that do not participate in becoming a supercurrent may start to influence the electrical properties of the superconductor.
Zz.
  • · Replies 0 ·
