Saw said:
I’ve just read the Wikipedia page on Mass, dealing with that subject and, as many times before, the issue still looks confusing to me.
You're not alone. I've been trying to make sense of this for a long time. The more I learn, the more confused I am. If I'm understanding you correctly, then I agree with you that the distinction between passive gravitational mass (m
p) and inertial mass (m
i) seems pointless. They seem to be
truly one and the same thing. And current experimental evidence supports it, to a high degree of accuracy. However, the same cannot be said for the equivalence, or more precisely, the equivalence of proportionality between active gravitational mass (m
a) and passive gravitational mass (m
p) / inertial mass (m
i). The best accuracy to support this equivalency is the Kreuzer experiment of 1966 (1 part in 5x10
5).
Saw said:
As to "active gravitational mass", what is the question? Whether it is the same thing that reacts with inertia in a collision? Well, to me that amounts to asking: is gravity caused by the presence of matter, which is supposed to be out of question...
m
a is the magnitude of force that is produced by a quantity of matter. The question of the equivalency of m
a to m
p/m
i also involves another postulate of the EP. Phrased in my own words: The generation of, and the response to gravity are the same regardless of the composition of the masses involved. A violation of this principle is sometimes called "composition dependent gravity". And a test of it is also a test of the WEP. So, if I have 1kg (m
i/m
p) of Cu and 1kg (m
i/m
p) of Pb, then the gravitational force (m
a) produced by the Cu should be the same as the gravitational force (m
a) produced by the Pb. Believe it or not, there is very little laboratory test evidence to support this type of equivalency, even though the technology exists which could extend the constraints by many orders of magnitude.
So where is my confusion? It is in the way that the universal law of gravitation is used as a reason to explain the equivalency of m
a. Or, in some cases, the way it is used as a way to test the equivalency. It is usually presented in the following way:
F_1 = \frac{G m^\text{act}_0 m^\text{pass}_1}{r^2}
F_0 = -\frac{G m^\text{act}_1 m^\text{pass}_0}{r^2}
A_1 = \frac{F_1}{m_1} = \frac{G m^\text{act}_0}{r^2}
A_0 = -\frac{F_0}{m_0} = -\frac{G m^\text{act}_1}{r^2}
Notice that if m
0 is of a different composition than m
1, and if m
0 has a different active gravitational mass but the same inertial/passive mass as m
1, then A
0 <> A
1. This would lead to a violation of the third law of motion, the reaction would not equal the action. So obviously an inequality of m
a and m
p / m
i is impossible. Or is it?
Consider the following thought experiment:
I am sitting in a chair on a frictionless surface. You are sitting in a chair across from me on the same frictionless surface. I reach out and pull you toward me. The result is that we both meet at our COM, or barycenter. Now we repeat the experiment, except this time you reach out and pull me toward you. The result is the same. We both meet at our COM. We repeat the experiment again, except this time we both pull simultaneously, me pulling with a slightly greater force than you. The result is exactly the same. We will always meet at our COM.
And, consider this thought experiment:
Two magnets, M1 and M2, are sitting on a frictionless surface with their opposite poles facing each other. Both magnets have the same inertial mass m
i, but M1 produces a stronger magnetic field than M2. Now, will M2 have a higher acceleration than M1? Where will they meet? Of course they will have the same acceleration and they will meet at their COM (which is determined by their m
i).
Now my question is, referring to the previous equations, why shouldn't gravity work the same as the thought experiments? Why should there be a violation of the third law when the two masses do not have equivalent ratios of m
i and m
a? It is the inertial mass m
i and the inertial mass only, that determines the barycenter. The m
a has nothing to do with it.
My thoughts on this are that Newton's universal law of gravitation
assumes that WEP is true. To try and use this equation in a world where WEP is not true, will not work. So contrary to what I have read, I do not believe that this equation can be used as proof that m
a = m
p / m
i. I have some other ideas about this, but I am reluctant to post them here because of forum rules.
