Why don't the Slits collapse the wave function?
The discussion centers on the phenomenon of wave function collapse in the context of the double-slit experiment, particularly addressing why the interaction with the slits does not collapse the wave function until a measurement is made. Participants explore the nature of interactions between particles and slits versus measurement devices, delving into concepts of phase coherence and the implications for interference patterns.
  • Some participants question how interaction with the slits does not collapse the wave function, suggesting that bouncing off the sides of the slit could be considered an interaction.
  • Others propose that the critical issue is the path taken by the particle, with superposition playing a role in the observed interference pattern.
  • One participant describes the wave function as a corkscrew representing momentum, indicating that measuring position results in losing the interference pattern.
  • Another viewpoint suggests that the slits do not have internal degrees of freedom, which preserves phase coherence and allows for interference, while measurement devices do affect phase coherence.
  • Some participants argue that the slits serve merely to spatially separate trajectories, and the nature of measurement devices is what distinguishes their interaction with particles.
  • A participant expresses confusion about the terminology used, seeking clarification on their understanding of wave function collapse in relation to the double slit.
  • There is a challenge to the correctness of a participant's understanding of wave function collapse, indicating a lack of consensus on this interpretation.
Participants express differing views on the nature of interactions with the slits versus measurement devices, with no consensus reached on the specifics of wave function collapse in this context. Some agree on the importance of phase coherence, while others challenge interpretations of the double slit’s role.
Participants note the complexity of the concepts involved, including the implications of internal degrees of freedom and phase coherence, which may not be fully resolved within the discussion.
  • #61
Hans de Vries said:
A cube with 40 nm sides can be accelarated to up to 400 nm/s by a single EUV photon. That's ten ...
Not on point,
1) that little cube a slit does not make, you will need much more mass than that even for a singlr slit.
2) You do not get to use ALL the energy of the photon, only what counts for momentum concervation do to the deflection of the photon going through the slit to go off to the right or left. (Rerun the test if you get one going straight ahead) MUCH smaller than your number.
Your better than that, do all the math if your going to do it.
  • #62
RandallB said:
Not on point,
Your response is fast but both points are wrong.
1)
EUV radiation has a wavelength in the order of 10 nm. "Double split"
experiments can be (and have been) performed with a single wire.
This is enough to create two different paths, In this case the wire
can be in the order of 10nm to 20nm thick.
2)
Of course the deflection momentum is less as the total momentum
but certainly not "MUCH" smaller under the proposed dimensions.
Two split interference pattern with 1 wavelength separation:
http://www.calvin.edu/~lmolnar/anim/circ3.gif (10 nm separation)
Two split interference pattern with 2 wavelengths separation:
http://www.calvin.edu/~lmolnar/anim/circ4.gif (20 nm separation)
Regards, Hans
  • #63
ueit said:
In Newtonian physics the speed of gravity was infinite. If you use a limited speed, let's say c, the planetary orbits become unstable.
In GR this "seemingly" infinite speed of gravity was explained by a local mechanism.
I don't think you have a sufficient grip on GR. GR is a local theory which respects c. Under GR, planets DO have stable orbits. GR has absoultely nothing to do with Bell's Theorem. I do not understand what GR has to do with this discussion.
  • #64
All I think ueit is trying to say, is that prior to GR we had a non-local model for explaining gravitational interactions. Then GR came along and gave us a local theory that explained gravitational interactions.
Perhaps he/she is trying to draw analogies between pre-GR gravity to current understanding of QM, and post-GR gravity to some as-of-yet-unknown-paradigm of QM which would be local and realist. The specific details are, of course, different, but perhaps he/she is merely trying to draw an analogy.
But I must say I'm not entirely sure if that is exactly what ueit is trying to say.
  • #65
That's exactly what I want to say, thanks!
  • #66
OK, historical point noted.
However, that is exactly why Bell's Theorem is so amazing. We now know that a local realistic theory (like GR: which respects c and has definite values for the gravitational tensors at all times) cannot reproduce the results of QM. This is a very surprising result, and I think it is counterintuitive. That is why it is also so controversial.
  • #67
Great then instead of computer generated diagrams --
What go you expect the details of the real experiment are going to be?
What Hz or energy of a photon do you propose send through the slit?
What angle of deflection will you wait to see a single one of these photons deflect?
What Momentum must go into the slit to account for the change of momentum in the deflected photon?
THEN how far will the slit assembly move based on:
Size of complete slit assembly: That is COMPLETE dimensions and mass including the target cross hairs or index used to make the slit location measurements from, AND the mounting points and any friction to be accounted for from whatever holds the slit assembly in place?
What will you be using as the measuring system to make the two location measurements of that slit index both before and after each potential test photon passes though?
And what effects will this measuring system have on the total slit system?
I presumably that measuring system will involve a stream photons, smaller with higher energy than the larger lower energy photon we are testing.
I assume we will have a large number of location measurements to record before we get a pair with a proper deflected photon.
How do you account for any momentum imparted to the slit from the measuring system including any scattering (oops more random deflections) of the higher energy photons used to make these measurements? Can we say about how many of these higher energy photons will be needed to make each measurement?
I know details, details….
But as I said before; not in my wildest dreams do I expect this kind of test to every be done.
  • #68
Since the first post I talked about EUV photons which have a wavelength
of about 10nm.
Again, from the very first post you could deduct a split separation in
the order of the wavelength of the photon which means a wide range
of angles. It doesn't matter at all what the exact distribution is as long
as the angle of deflection isn't extreemly small as you wrongly suggested.
it can move arbitrary far depending on the time you have.
Imagine it as a scattering experiment then, with the nanoslits scattering
one way and the EUV photon the other way. If the nanoslits move
several times their own size per second, as I showed, then you don't
need much time to get a good resolution on a detector screen designed
to detect "nanoslits" impacts.
No higher energy photons needed at all...Regards, Hans.
  • #69
Hans de Vries said:
as long as the angle of deflection isn't extreemly small as you wrongly suggested.
Never made such a suggestion - and you are still completely missing the point, as if you didn't understand what or how the HUP works, and have not thought it through COMPLETLY. But have your way, start a new thread when you or one of yours actually runs such an experiment some day in the future, I’ll unsubscribe here, this thread is long enough as it is.
  • #70
No, we don't know that. You forget that such a theory does not allow "free will", there is no statistical independence between detector orientations and the particle source. I know, you will say that no such theory was put forward but this is not so surprising given the number of physicists working on LHV theories.
I wonder if a better understanding of the measurement process (describing all experimental setup in terms of particles/fields and not macroscopic instruments) couldn't reveal the mechanism involved in EPR.
  • #71
Aren't you confusing Local and Global realism? "Local", in local realistic theories, means on the scale of the particle interactions, not on the scale of the lab; that last requires an additional assumption, as was pointed out years ago, at the time the original Aspect experiment was discussed.
  • #72
Yes, you did. You said literally "MUCH smaller than your number" with the
word "MUCH" in capitals.
No I'm absolutely not missing the point. There is nothing here which
is in conflict with HUP. There is no limit in how exact you can measure
the momentum in QM as long as you do it over a large enough traject.
It should not be a matter of prevailing or conceding here. Much of this
has also to do with your discussion style. As long as you throw things
at me like "you are completely missing the point", then expect me to
respond.
Regards, Hans.
  • #73
Hans de Vries said:
Yes, you did. You said literally "MUCH smaller than your number" with the word "MUCH" in capitals.
How could that have anything to do with deflection angle as you never gave that detail.
It should not be a matter of prevailing or conceding here. Much of this has also to do with your discussion style. As long as you throw things at me like "you are completely missing the point", then expect me to respond.
Sorry fair point,
But don't expect me to continue, as you don't work through a complete detailed example your plan to do such a test, and others a lot smarter than me have already said it is an impossible test.
IMO there is no point in arguing over it; and it’s fine to imagine someone will be able to do it some day if you like.
I’m well convinced that they are correct that it cannot be done and no one will, and don’t need my imagination stimulated on the point thank you.
  • #74
AFAIK "local" means that every interaction propagates with a limited speed (c). The range of EM interaction is infinite so I don't see how the scale makes any difference.
Why is this even relevant to my point (that is, in a deterministic theory the detector orientation is a result of the deterministic law and therefore cannot be assumed to be random)?
Bell's theorem assumes randomness therefore is irrelevant when discussing deterministic theories (fallacy of circular reasoning).
I agree however that a deterministic theory has to account for EPR experiments but this is not a problem as no theory to date explains them.
  • #75
Bell's Theorem does not assume randomness. It states that a result at one location is not affected by the choice of measurement at another. There is absolutely no requirement that the selection of spin measurement angles be random either, another common myth.
As to your second point: QM is a theory which explains the observed results perfectly, as they are exactly as predicted: cos^2.
  • #76
In a deterministic universe there is no choice. If you want to verify a LHV theory you have to study how the "choice" is determined at each location by the deterministic law. The two measurement "choices" are the result of this law applied to their common past. You cannot assume that the two detectors are independent as long as they share a common past.
As an analogy, think about the orbit of Hyperion (or a stray comet, or whatever). It is chaotic, for all practical purposes it looks random. If you are staying on its surface with an accelerometer you would be able to determine the "instantaneous" position of the Sun, according to Newton's law. How do you explain that? Did Hyperion's wave function collapsed when you took your measurement, or it's just the deterministic local GR acting on this complex system?
QM doesn't explain anything, just computes the probability of the final result. It doesn't state the reason we have the correlations, just that they occur.
  • #77
I don't think you understand what a fundamental theory is. QM is a fundamental theory, so naturally there is no explanation of why h has the value it has. Nor why the other physical elements work as they do; nor would any suchg explanation be expected. This is why QM is an actual theory, where as your "strict determinism" is not a theory at all.
If you postulate strict determinism, it is incumbent on you to offer a complete and consistent theory which can be competitive to QM (i.e. at least the same scope and predicability). For example: if there is strict determinism, then why cannot all attributes of a particle be measured to unlimited accuracy (in violation of the HUP) ? This glaring inconsistency undermines your approach. Bell's whole point was that:
QM + (assumptions of locality & realism) was inconsistent with QM alone.
So how can you say:
QM + (assumptions of locality & strict determinism) is consistent with QM alone.
...without first demonstrating this to be true?
My point is - if your strict determinism were true - that every single particle in the universe must contain "DNA" which allows it to know how to act for every single interaction it will ever have in the future. And it must have enough of this DNA so that in experiments on different particles - but just some, those we call entangled - that the results of separate experiments yield results according to a statistical distribution as predicted by QM. Whew! By my estimate, that would be essentially an infinite amount of information to carry around. And yet there is not the slightest evidence of this DNA to date, as no known internal structure exists for any particles. When you produce some evidence (or even a testable element) to support this hypothesis, we can discuss. Meanwhile, your theory is purely "ad hoc" and of no use.
  • #78
A theory can only be considered fundamental if it can explain any phenomenon in its range. QM cannot predict single events (the value of the spin measured on an arbitrary axis, the time when a decay takes place, etc.) therefore it is only a statistical approximation to a fundamental theory.
The so-called "pure randomness" of QM is nothing but another example of bad logic. It is known that by squaring the amplitude of the wave function, you get a probability but this does not imply that a non-probabilistic description cannot be found. Assuming so, is both irrational and unscientific because it puts an arbitrary boundary to our knowledge. If every theory used the same line of reasoning (there is no explanation, it just is the way it is) we would still be throwing virgins into volcanoes to have good crops or whatever.
If you postulate strict determinism, it is incumbent on you to offer a complete and consistent theory which can be competitive to QM (i.e. at least the same scope and predictability). For example: if there is strict determinism, then why cannot all attributes of a particle be measured to unlimited accuracy (in violation of the HUP) ? This glaring inconsistency undermines your approach.
1. If all that exists are billiard balls, in order to see one of them you have to hit it with another one. This will disturb the system so your knowledge will not allow you to make a prediction.
2. Contrary to your belief we can measure with unlimited accuracy both momentum and position of a particle by simply detecting it at an arbitrary large distance from the source. You cannot use the information to make a prediction but non-predictability is not the same thing as non-determinism.
I see no glaring inconsistency here.
No, his point was:
QM + (assumptions of locality & realism and free choice) was inconsistent with QM alone.
Please read "Speakable and Unspeakable in Quantum Mechanics" by Bell to see him saying that, with his own words.
If you look carefully at the statement above you can see that, in the case of deterministic lhv's QM is superfluous, because "determinism & free choice" is false as required by the law of non-contradiction (determinism != free choice).
The theorem can only apply to non-deterministic lhv theories but I don't care much about them anyway.
So how can you say:
I have nothing to demonstrate. Take out the assumption of free choice and see what remains from Bell's theorem.
I'll not make a fallacy myself though. Just because Bell's theorem does not apply to determinism doesn't mean that determinism is compatible with QM. However, this is a subject to investigate, not to dismiss as impossible.
Where did I speak about DNA? It's the most absurd caricature of determinism I've ever heard of, and I don't see how my analogies with gravity could be interpreted that way.
So, if you want a model of deterministic theory look at GR. The planets do not need to carry a "DNA" telling them how to move in the universe. Each particle in an EPR experiment (including the ones in the detectors, source, experimenters) follows a path in accordance with the forces acting on it.
You can make the first steps to extending Bell's theorem to deterministic theories by proving that the spins of an electron and positron produced by the decay of a positronium "atom" are not correlated to the orientation of a distant magnet (Stern-Gerlach detector).
  • #79
kliide said:
One thing I don't understand is how the screen with the slits do not collapse the wave function until there is a measurement. Wouldn't bouncing off the sides of the slit constitute some sort of interaction?
What is it about the "observer" or measurement device that would interact differently with the photon than how the photon interacts with the slit?
The difference is that the slits merely limit the potential paths of the photon, while an observation captures the path actually taken.
Think of it this way. A photon is created. It is going to travel at velocity c. It could go in a bunch of different directions. Imagine that -- before the photon even begins to travel -- all the possible paths it could take are carved out in space.
Now think of all these potential paths in this frozen instant in time. Think of them acting outside of time, if you will.
You've got one slit. The potential paths through that slit go right through pretty straight.
You've got two slits. The potential paths go through both slits, and interfere with each other on the other side.
Now start time up again, and release the photon. It's going to travel along only one of all the potential paths.
If it follows one of the potential paths that goes through one of the two slits, then that photon is going to follow a path that looks as if it "interfered with itself." In fact, it's not interfering with anything. It's merely following a potential path that already interfered with another, before the photon traveled down that path.
Does that help?
  • #80
Thanks all.
jpr0 rephrased my question perfectly and DrChinese's answer registered on my brain. Dense answered my question with this: "The difference is that the slits merely limit the potential paths of the photon, while an observation captures the path actually taken." Wherein I can see that you're saying that limiting the path of the photon means terminating their paths at the point where they impact the slit rather than pass through.
In retrospect, I don't know why I was asking about the electrons that had impacted the sides of the slits as it had nothing to do with the experiment. I think I was visualizing photons that contained paths that would deflect off the side of the slit and still impact the measurement device. I originally believed that the intent of the experiment was to say that even these photons maintained wave characteristics once impacting the slit and would only lose their wave characteristic when "measured". I couldn't figure how a measurement would differ from coming into contact with any other type of subatomic particle. Poorly formed question. Great answers, anyhow.
DrChinese's explanation that the slits simply terminate the paths of the photons that impact them makes sense to me.
Anyhow, thanks all.
  • #81
DrChinese said:
In the path integral view, you consider all possible ways that the photon could arrive there. Those possibilities give rise to interference, and a pattern results.
In sum: The interference pattern represents the subset of photons that went through the slits. In effect, the detection mechanism is designed to be a fertile target for the source photons and the rest of the apparatus is not. That is the only distinction..
DrChinese’s explanation makes no sense to me. He starts with the single photon and end up with subset of some set of the incident photons. We consider here a single particle phenomenon. The incident photon/electron etc. are described by the coherent wave packet. And his answer to your original question is bla,bla,bla. In addition, his answer violates unitarity which is maintained in the discussed experiments.
ZapperZ said:
The "slit" in the idealized case is simply an illustration of separate paths for the photon, electron, neutron, buckyball, etc. As I've said, that isn't the real issue. Now, if the slit happens to be a metallic device that can somehow detect things like electric field of an electron or a photon, THEN it is now a detector that can tell you if a photon, electron, or whatever, passed through it. This is now a different set up.
I consider that the only correct answer presented to your question (Why don't the Slits collapse the wave function?), however I do not agree that the reflected and transmitted wavefunctions describe separate paths for the photon, electron, neutron, buckyball, etc. As mentioned by Zz, that isn’t the real issue.
Regards, Dany.
  • #82
Well, that is the path integral explanation. As ZapperZ points out, the general version is one in which there are a number of ways to reduce the set of paths.
When there is one slit, there are still multiple paths being traversed and there is still interference. However, such interference will NOT create the classic interference pattern in that case.
  • #83
My criticism was that you did not explain the difference in the set up. And I don’t see how you maintain unitarity. In addition, in case of one slit we usually are talking about diffraction.
In “Light, particle or wave?” I asked Zz to comment A. Tonomura et al. “Double-biprism electron interferometry”, App. Phys. Lett., 84(17), 3229 (2004) paper. I think, it is obvious that I am very interesting to know your opinion too.
Regards, Dany.
  • #84
exactly.
There are no particles.
There are localized waves
  • #85
DrChinese said:
As for the requirement of 4D spacetime, it is a bit premature to require that there be no additional dimensions. Maybe there are more.
This is a good point.
  • #86
sokrates said:
exactly.
Stupid question.. how does a localized wave travel in a vaccum?
  • #87
Because the wavefunction of the slits is itself collapsed by the environment. If we assume that there are very weak interactions causing the state of the slits to change a bit then the particle moves through them, then this can only be used to detect the "which path information", if the state the slit is in when a aprtcile moves throgh it is orthogonal to the state it would be in if the particle does not move through it. The visibility of the fringes is proportional to the overlap of the two wavefunctions.
If you have a setup with floating slits or floating mirrors and consider the change in the state of the slits/ mirror due to the change in momentum of the particle that moves through it, then one has to take into account that you wouldn't be able to get an interference pattern in the first place if the center of mass position of the slits/mirrors were not determined to within less than a wavelength. By the position-mometum uncertainty relation, this means that the width of the wavefunction in momentum space is much lager than the absorbed momentum.
The center of mass state of a floating mirror of mass M at temperature T is described by a density matrix that has is almost diagonal in the position representation. The off diagonal components are approximately Gaussian with a width of approximately the thermal de Broglie wavelength. This means that we can think of the environment havong measured the center of mass position of the mirror but with an uncertainty of the thermal de Broglie wavelength and that the center of mass of the mirror could be regarded to be in an unknown pure state described by a Gaussian wave function.
In the momentum representation the off diagonal components of the density matrix are then Gaussians with a width of the order of
sqrt[M k T]. So if M is macroscopic, this width is huge compared to the momenta of particles in two slit experiments.
So, we see that explaining interference of particles in two slit experiments requires one to consider the quantum state of the rest of the universe. Decoherence of the many particle wavefunction of objects with which the particles interact explains why these objects are located to well within the wavelength of the particles. The wavefunction of the particle at a fixed position at the screen then has a well determined phase. And this is also related to the fact that the momentum that the slit or mirror may have absorbed is not suficient to gain which path information as the wavefunction of the center of mass of the slits/mirrors is necessarily wider than the absorbed momentum.
  • #88
Going back to the original question:
Lets consider sending one photon at a time. There is a probability that the photon will be absorbed or reflected back by the plate. In either case, the photon does not reach the screen and we will not affect the pattern on it one way or another. If the photon is not absorbed or reflected by the plate, then we can assume that the wave goes through both slits. We couuld make the plate thin enough so that any reflection from the edges of the slit can be ignored. But even if we have a plate of a considerable thickness so that part of the wave is reflected by the edge of the slit, when the photon hits the screen, we will not know if the photon "bounced" against the edge of the slit or went thrugh the middle. We could think of the wave as made up o a bunch of possible trajectories for the photon. Depending on the "Interpretation" we could think that if we didn't make a measurement as to which was the exact path the photon took, then it took all paths. It kind of split itself into a bunch of "gost" photons which went in every possible way (not necessarily straight line). The overlap of the trajectories of all these ghost photons is what makes up the wave. Summing up the contributions of each ghost photon on the screen (considering the phases) gives us the probability that the real photon will be found at a particular spot on it. If the screen is made of photografic material, we can say that when some molecules change and leave a permanent record of the position where the photon landed, we have measured the position and the wave function has collapsed.
But let's go back and look at what happens if we consider a ghost photon that "bounced" against the edge of the slit and eventually contributed to the interference pattern on the screen. In this case, there is no permanent record made on the edge of the slit. If the photon was a little macroscopic ball, it could have left an indentation on the edge of the slit. But a photon (for our purposes) can only do one of two things: "bounce" o get absorbed. I think we should consider that bouncing is not able to leave a permanent record. If the photon was absorbed, then again it will not reach the screen and can be ignored because it does not contribute to the distribution of dots on the screen.
In the case of photons I don't think we can put a detector that will tell you if a photon went through a slit or not without drastically affecting it. What I mean by drastic is that if you put a detector there are only two possible outcomes. 1) the detector absorves the photon or it doesn't. If it does, then this photon is eliminated from consideration as it does not reach the screen. If it doesn't and you do see a photon hitting the screen, then it means that it went through the other slit. In this case the mere presence of the detector eliminates all the possible paths through that slit (This is a detector that does not let any photons go through). So in this case if we send many photons, the interference pattern does not show up. This would be similar to just covering one slit instead of using the detector. So this example using photons is not very good if we want to use a detector. We could perhaps think of a more engineous setup where we convert the photon into two photons of longer wavelength and absorve one but that would change the experiment into something much more complicated than a simple double-slit. If we used finite rest-mass particles, we could do some kind of detection where the particle does go through the slit. Perhaps some of the smallest particles we could use would be electrons, but in this case we can't use slits because the wavelength of an electron is too small and the way to obtain an interference pattern is using a crystal.
So any double-slit experiment using electrons or other particles and putting a detector behind the slit which let's the particle go through is just a thought experiment that may help understanding some of the issues involved but can't be carried out just as presented.
But let's consider one of these thought experiments. We could think of a particle such as an electron still exhibiting behavior similar to the photon. So most of what I said above would apply, except that we could put a detector and still have the particle go through. If the detector clicks, then we know that the particle went through this slit and we now have a permanent record of it which colapses the wave function in the sense that it eliminates the part of the wave that would have gone thrugh the other slit. (no interference)
If the detector does not click and we do see a particle hitting the screen, then we can assume it went through the other slit. In this case the part of the wave that would have gone through the slit that contains the detector dissapears (no interference). So in both cases just the presence of the detector destroys the interference pattern.
If we consider those paths in which the particle "bounces" against the edge of the slit, we should consider that it just bounced, without leaving a permanent record of it. In this case the interference pattern is not destroyed. If it does "smash" something when hitting the wall (edge of the slit) then this would represent a measurement. It would leave a permanent record. We could use some powerful microscope and detect the change on the edge of the slit. Using other mechanism of detection such a looking for a change in momentum which would be imparted on the wall by the bouncing electron, would be kind of tricky and it would in the end give the same result.
I don't think my explanation is complete but it gives an intuitive idea of why the slit may in most cases not act as a detector. (And I think I didn't use big words). I think it happens very often that people with more years of study try to explain simple things using complex concepts when simpler concepts would do. This is very discouraging to the person who is trying to learn as it seems that in order to understand the most simple things you would need to understand the more complex. But you can't understand the more complex if you don't first understand the more simple. Well, that could be the topic for a different thread...
  • #89
alexepascual said:
1) the detector absorves the photon or it doesn't. If it does, then this photon is eliminated from consideration as it does not reach the screen. If it doesn't and you do see a photon hitting the screen, then it means that it went through the other slit. In this case the mere presence of the detector eliminates all the possible paths through that slit (This is a detector that does not let any photons go through). So in this case if we send many photons, the interference pattern does not show up...
There is a way to learn which slit the photon pass through without absorbing it. If you put a polarizer in front (or behind) each slit, and the polarizers are crossed (at 90 degrees apart as to their relative orientation), then the photon passes through. Because of the polarizer, you know which slit it passed through (or could learn later); therefore there is no interference pattern.
  • #90
I can see two situations here. If we send toward the slits a circular polarized photon, then each component of linear polarization would pass through each slit and then re-combine. The interference pattern would still be there.
If we sent a linearly polarized photon with either horizontal or vertical polarization, then we would know which slit it went through. Every photon that lands on the screen would be coming from the slit that corresponds to its initial polarization. In this case I guess the interference pattern would be destroyed. But I also think that 50% of the time the photon would be absorbed by the polarizer film in the slit with crossed polarization. If you use a polarizer that works by reflection, in that case you could absorb the photon after being reflected. So I don't know if this would qualify as a non-absorption detection experiment. It would also be equivalent to putting any obstacle in front of one of the slits. What you are detecting is the photon that doesn't make it through and not the one that does.
Well Dr. Chinese you got me thinking for a while. This is an interesting modification of the double-slit experiment and I had fun thinking about it.
  • · Replies 59 ·
  • · Replies 18 ·
  • · Replies 23 ·
10K
  • · Replies 28 ·
  • · Replies 36 ·
9K
