Adel Makram
- 632
- 15
Why is c invariant for all FORs? Special R took it as a postulate but it did not explain it,,,
The discussion centers around the invariance of the speed of light (c) across all frames of reference (FORs) in the context of special relativity (SR). Participants explore the implications of this invariance, its historical context, and the philosophical questions surrounding its status as a postulate rather than an explained phenomenon.
Participants express a range of views on the nature of c's invariance, with no consensus on a definitive explanation. Some agree on the historical context and implications of the postulate, while others challenge the adequacy of existing explanations and seek deeper understanding.
Participants acknowledge the limitations of current theories in providing a fundamental explanation for the invariance of c, with discussions reflecting varying degrees of certainty and speculation about the underlying principles.
Adel Makram said:Why is c invariant for all FORs? Special R took it as a postulate but it did not explain it,,,
DrGreg said:Before Einstein, Lorentz and others took the view that length contraction and time dilation of objects moving through an aether explained the invariance of the speed of light.
Einstein took the opposite view that the invariance of the speed of light explained length contraction and time dilation. Under that view, there is no explanation for the invariance of the speed of light, that's just a fundamental symmetry of the universe we happen to live in.
Physicists quite like explanations in terms of symmetry.
If A logically implies B and B logically implies A, then you can choose to say "A causes B" or "B causes A".salvestrom said:And the invariance of c is only possible due to time dilation and length contraction.
salvestrom said:Eesh, anyone know a shorthand for that? How about "the phenomenon"?
jtbell said:Lorentz symmetry.
DrGreg said:If A logically implies B and B logically implies A, then you can choose to say "A causes B" or "B causes A".
So I could just as easily say "time dilation and length contraction are only possible due to the invariance of c."
Nugatory said:It's a postulate, so it would be easy (and unhelpful) to say that it doesn't have to be explained. You choose a postulate, you apply some logic, you get some results that are valid assuming the postulate is valid, and you're done.
Mark M said:SR took the invariance of the speed of light as a an assumption, though Einstein did not explain why he singled out light as a special case (Probably because electromagnetism was the only known field at the time).
See post #3 in this thread for a better explanation:
https://www.physicsforums.com/showthread.php?t=445032
