Why is Force of Bubble Given by 2(2πR)σs?
2 replies · 1K views · last reply
werson tan
why the force of bubble is given by the formula of 2(2 pi R ) σs ? why not (2 pi R ) σs + (2 pi R+ ΔR) σs ? Since the radius of th outer circumfernece and inner circumference are the different ?
  • Textbook figure 2-21: a liquid film stretched on a U-shaped wire with a movable wire of length b, showing the displacement Δx and the applied force F; beside it is Table 2-4 of surface tension values for fluids in air.
  • Textbook figure 2-22 showing free-body diagrams: (a) half a droplet, with surface tension arrows around the circumference and the pressure force on the cut area; (b) half a bubble, with the film's inner and outer surfaces labelled 2(2πR)σs and (πR²)ΔP bubble.
Because for most purposes the difference is too small to worry about. The thickness of the bubble wall is usually far smaller than the radius of the bubble.
i have one more question here . I was also told that the pressure at the concave side of the bubbles is higher ... why is it so ? is it because of the circumference of the pressure at the concave side is higher?
