Murtuza Tipu
- 47
- 2
Why is it hard to get the air through the balloon when you first fill the balloon ? But after inflating it z bit it becomes easier to further inflate ?
Inflating a balloon is initially difficult due to the non-linear elasticity of the rubber, which causes plastic deformation that requires higher pressure. As the balloon is inflated, the rubber becomes thinner, making subsequent inflations easier. The tensile force of the rubber increases with the balloon's dimensions, resulting in a balance between inward and outward forces. Ideally, the internal pressure should decrease as the balloon inflates, but the non-linear tension of the rubber allows for easier inflation after the initial stretch.
PREREQUISITESStudents and professionals in materials science, physics enthusiasts, and anyone interested in the mechanics of inflatable structures.
The rubber is not linearly elastic. Initially there is some plastic deformation of the thick rubber, which requires more pressure. When you deflate it, and inflate for a second time, it is easy from the start because the rubber is thinner already.Murtuza Tipu said:Why is it hard to get the air through the balloon when you first fill the balloon ? But after inflating it z bit it becomes easier to further inflate ?
