Why Is My Fluid Mechanics Solution Incorrect?
32 replies · 5K views · last reply
Hi iSimon,
I really don't know how to answer you. The original diagram of the system was very ambiguous, and we took our best shot at trying to figure out what it was indicating. But, if we guessed wrong, then we were solving the wrong problem. The region of the figure that is most confusing is the left hand side where the water just seems to end at a slanted plane. I don't know whether this is a solid boundary, or what.
From your rendering of your teacher's explanation, it isn't clear to me what she is saying.
What i am confident about is that our solution to the problem as we interpreted it is correct. If it were not correct, we wouldn't have satisfied the check that the force on the curved surface is perpendicular to the axis.
I would be glad to help you some more if we could get some clarification on the figure.
Chet
Here is the main idea on how to solve.
Handwritten fluid mechanics sketch of a curved cylindrical gate on an inclined surface with labelled radius R, angle 30 degrees, and a horizontal force equation Fx = ρg hc A with trigonometric expressions.
If we transpose nodes of the cylinder to the right side we will receive figure which will be composed from 2 identical elipses on top and bottom and two identical rectangulars in middle.
Hand-drawn sketch of a vertical stack of two rectangles with rounded semicircular-looking caps at the top and bottom, forming a rounded profile like a capsule cross-section.
And the thing is to add Areas of separate parts multiplied by center of gravity. Sum them up and receive force which will act on horizontal axis in the right direction. But I am a bit lost in trygonometry to find proper values to calculate areas of elipse and rectangulars. Maybe This time I;ve managed to think better, I spoke to my teacher and she says its good solution but I need to calculate it.
