- 24,488
- 15,064
But all Bell experiments are compatible with local relativistic QFT. From your explanation it's very clear that as long as the outcome of the Bell experiments can be explained within local relativistic QFT you must conclude that there are no causal influences betwween the corresponding space-like separated "measurement events" (e.g., the clicks of two far separated photon detectors when you do polarization measurements on entangled two-photon states). Also this is most explicitly seen in the Heisenberg picture, where the states are represented by the time-independent statistical operator, defined by the initial conditions, while what you measure are local observables, i.e., the probabilities for detector clicks at spatially separated detector positions, i.e., precisely what you describe within the formalism above.
So what you prove with the Bell experiments is not "non-locality" but "inseparability", i.e., the correlations due to the preparation in the entangled state and not due to superluminal interactions due to the measurements, i.e., local relativistic QFT is compatible with both "no spooky interactions" (i.e., no violation of Einstein causality) and the correlations described by entanglement which are "stronger" than within any local deterministic HV theory indicated by the violation of Bell's inequality.
