Why is sliding in dirt track racing faster?
Sliding in dirt track racing is often faster due to the unique properties of dirt, which behaves more like a collection of particles rather than a static surface. This allows drivers to utilize a technique where the rear tires slide, effectively changing the vehicle's orientation and enabling sharper turns. Unlike asphalt, where sliding reduces grip and increases lap times, dirt surfaces can be "swept" clean by sliding, revealing more traction beneath loose material. The changing conditions of dirt tracks throughout a race also require drivers to adapt their strategies, as the optimal racing line can shift dramatically. Overall, the dynamics of sliding on dirt provide advantages that differ significantly from those on asphalt.
ektrules
Why is it often a faster way around a dirt track to slide around turns? The simplistic view that I got from Physics 101 says that the static friction coefficient is always higher than the sliding friction coefficient. So, that view would imply that a vehicle would be able to go around a turn faster if the tires were not sliding. That does seem to be the case with auto racing on asphalt, but not the case with dirt track racing. I'm guessing it has something to do with the fact that dirt is not static surface, but more like a collection of particles, almost like a fluid?
From my perspective, it's because you can step out the back tire, which points your force vector (from the back tire's torque) inward in the turn, helping you to turn sharper than you can if you don't break the back tire loose. There is a balancing point where the back tire (or tires for a car) are out at the best angle to give you the best speed and acceleration through the dirt turn. If you step it out too far, you slow down and go too far into the direction of the inside of the turn. Don't setp it out enough, and you head towards the outside of the turn...
[URL]http://static.etnies.com/site-images/news/article/nick%20wey%20high%20point.jpg[/URL]
http://nyk27.com/wp-content/uploads/2011/01/9A7J0132-548x364.jpg
Also from my experience with videogames (Dirt 2) you want to slide so that the car's nose points in the right direction. Basically you swing around the rear of the car so that you are now pointing in the direction of the new path, then floor it.
Of course you only do this if you are going too fast to make a classical turn.
Think of the dirt or gravel surface as a consumable that needs to be cleaned of loose material first.
ektrules said:
... that view would imply that a vehicle would be able to go around a turn faster if the tires were not sliding. That does seem to be the case with auto racing on asphalt...
There's a lot of sliding on asphalt too
A general way to look at this question is:
Suppose you want to make a turn of x degrees. You have to do two things:
1. Rotate the velocity vector of the bike or car by x degrees.
2. Rotate the bike or car about its center of mass x degrees, so it is pointing in the right direction when you finish the turn.
If you don't slide, the two things are "locked" together by the geometry of the bike or car's steering system. If you slide, they can be indepedent. This gives you more options about the line you can take through the corner.
If you don't slide, the work done by the engine is limited to less than the static friction force, because the sideways component of the friction (which prevents sliding) is at right angles to the direction of travel and is not doing any work. In the limiting case where you at the point of sliding, the engine can not do any work to propel the car, because all the friction force is acting sideways.
If you slide, and the engine is powerful enough, you can apply the full dynamic friction force all the time, and the total amount of work done going round the curve can be bigger than if you don't slide.
A surface that isn't prone to deterioration through abrasion (asphalt) provides higher grip when the surface is clean. Surfaces that are prone to deterioration through abrasion (dirt and gravel) benefit from being "swept" clean by the tires (i.e. sliding) to get to the intact surface beneath the loose material. The act of abrading the surface also enters into this.
Here's a reasonable analogy: try using a medium grit sandpaper on wood, then compare that with using it on steel. The sandpaper has more "grip" on the softer wood - until the sandpaper clogs up with sawdust and no longer abrades the surface. Cleaning the sandpaper restores that grip.
The preparation of the dirt track surface plays a large part in the amount of traction available. A well-prepped track has a fairly high moisture content that goes down into the dirt. If the track isn't watered properly, the water only penetrates a short way into the surface and it doesn't take very long before the top surface is worn off, the track looses its grip and becomes dry-slick. Wet and tacky makes for fast cornering and enough traction to pick up the front tires down the straights.
The amount of work done is limited to the amount of force that can be generated, shown as the resultant of the longitudinal and lateral forces.
http://www.auto-ware.com/setup/fc1.htm
Given that the static friction coefficient is lower than the kinetic friction coefficient, generally less work can be done by the tires when sliding.
http://hyperphysics.phy-astr.gsu.edu/hbase/mechanics/frictire.html#c1
Applying more power from the engine will make the situation worse by increasing the amount of slippage, heating up the tires and further reducing the available grip. That's why you don't see long trails of tire smoke from the winning cars out of the corners on asphalt, only the loosing ones - and drifters.
I wonder if reaction force of the tire throwing dirt back plays any part in this? I heard from flipping through channels and accidentally landing on the redneck channel, that in tractor pulls they can benefit from the jet effect of spinning the tire as fast a possible and hurtling massive amounts of dirt out the back.
There will be an effect but I suspect it is fairly minor. I think if one were to calculate just the momentum change of the dirt needed to absorb the amount of power being displayed by those tractors, considerably more dirt than is on the whole track would be needed!
Yeah, this is the theory I was trying to explain in my question. If the power was not delivered by the wheels, but with a rocket or something, the argument that sliding allows cars to supply more force toward the inside of the turn would make sense. But, I'm talking about normal cars that do work through the friction between the tires and the road. Tires can only handle so much force before it exceeds the static friction force, and then starts sliding. When tires are sliding, the friction between the tires and the road is significantly less, so the tires can't do as much work. This means that you can go through a turn faster when the tires are not sliding.
With all the kinds of racing on asphalt that I know of, sliding is a bad thing, and is known to increase lap times. You only see experienced drivers slide when they make a mistake, or are trying to correct a mistake (coming out of a turn too fast, hitting a patch of debris, etc). Even when racing in the rain, Formula 1 drivers try not to slide around turns.
On dirt track racing, such as sprint car or rally racing, the fastest cars slide through turns all the time. This seems to contradict the above theory. What is different between racing on asphalt and dirt that makes it better to slide on dirt?
(Sweeping debris doesn't really explain it, because drivers slide their cars during the entire race, and sweeping debris does not give drivers any advantage over the other drivers.)
I think that what happens in a video game is not to be considered as evidence in any form. Someone wrote a simulation on the basis of experience and, possibly, theory but that is not a proof. I am ranting about this a bit but simulations are only suitable if the model is totally correct. - good to demonstrate but no use as a proof.
Having run dirt a little in my time..the answer is "dirt is not quicker than asphalt"..no way
its all about tire contact and who can maintain it the longest on any given track.
no way will a half mile track be quicker than an asphalt half mile track...especially if we have significant banking ( over 20 degrees)...
one major factor to be considered is the fact that a professional dirt track event means the track condition will change at least 4 times over the race event. The track will go from slurry wet to hard packed dry condition and this will vary depending upon if the track is watered and smoothed during the event. This will change the set up, tires and handling. Day long events will have track conditions change simply by amount of sunlight present ( ambient temperatures)
another major problem is that the "Groove" or fastest race line will change as the track packs in. The driver has to adjust to this and is constantly looking for the fastest groove during the event...the top of the track will get cluttered with massive quantities of loose dirt thrown by the the tires and force the cars to use the lower groove..
this means you have no consistent race line as you have on asphalt ( the asphalt track groove will also move but not as dramatic as dirt).
Plus it is one messy tough dirty job crawling under a race car at night to work on it...
So you're looking for the process that provides the traction and the reason that sliding is more effective than not sliding, right? I haven't come up with much on the theory behind that - lots of practical advice on how to compensate for changing track conditions though, like Ranger Mike posted!
Sounds like you're leaning towards a non-Newtonian fluid explanation.
Yeah, I was wondering why sliding on dirt is effective on dirt, and not asphalt. I was hypothesizing that the reason might lie in the fact that dirt is a collection of loose particles. Honestly, I'm surprised that a physicist hasn't stopped in here, and posted an explanation :) I figured it would be something simple.
Exactly how the mechanics of gripping on asphalt vs gripping on gravel work are black magic. As is everything to do with tyres.
However the main reason that you don't get cars sliding on asphalt is becuase the radii of the corners are much larger.
Compare the tightest hairpin on a track to even a loose hairpin on a rally stage. The rally stage will be realllly tight. In autocross for example, you get people sliding on tarmac beucase they need to pivot the car on the spot.
EDIT: Dirt track racing, never mind.
I think the reason they slide round coners is bacuse they don't have enough grip to do anything else. It sounds tautological but if they could get tyres to grip like they could on tarmac, you'd see them taking tarmac type lines.
Speeds on loose tracks are much lower than on hard 'sticky' tracks. That much is obvious.
The so-called slip angle is much higher on loose tracks. To 'steer' round a bend on a loose track, you would need to be going absurdly slowly because you can't produce enough lateral force by just changing the angle of the front wheel(s) both to reduce speed in the initial direction and give it a lateral velocity. By turning the car / bike into the curve you can increase the lateral force by using the force from the driving wheels as well as the force that the steered wheel produces to push 'sideways' (drift).
The same thing happens, to some extent, for every vehicle going around a corner; the vehicle doesn't naturally actually point in the direction of a tangent to the curve (understeer or oversteer). A normal road car is designed to understeer because your average driver can't cope with the effects of oversteer. All performance cars (or any car with enough poke) are made to oversteer in a controlled way to go round a track as fast as possible (see that silly Top Gear prog with Clarkson in). It's just much more noticeable on a loose track because the angles are more pronounced.
sophiecentaur
may i digress on a few points..please...
Almost true ..but.. real round track cars are intentionally set up with offset castor. If the driver takes his hands off the steering wheel the car will automatically turn left due to the caster offset. In the rear tire set up you run a lot of stagger so the car will naturally steer left..think of a sytrofoam coffee cup on its side, it will automatically roll toward the side the small end is pointing..If you really have the car dialed in for the track then car will almost round the turn on its own because of this set up.
I am not so sure about this. the main reason stock production cars ' push " when going over the limit of normal speed limits while rounding the corner is due to the engine being over the front drive wheels and this causes a weight bias ( usually 55% front end weight) that gets magnified if there is any braking ( weight transfer to the front). It is simply a fact of economical production.
All performance cars (or any car with enough poke) are made to oversteer in a controlled way to go round a track as fast as possible.
Again, not so sure about the design intent. Once your pass the performance point of HP to weight ratio, you can spin the tires at will due to the available horsepower. This is something the average grocery getter does not have, instant power.
By turning the car / bike into the curve you can increase the lateral force by using the force from the driving wheels as well as the force that the steered wheel produces to push 'sideways' (drift).hummm...turn into the corner...I don't think so.. would cause the car to spin out... and I need to do a little DIGGING to find my set up notes on DIRT tracks..sorry for the terrible pun..
when driving dirt , you " steer with your Toe" ..by this i mean you run down the front straight as fast as you can until you see God, then crank the wheel to the out side ( turn right ) and goose the throttle with your toe until you get the car thru the apex and can straighten it out and nail the throttle...
this pic shows a couple of things...dirt ( once the track reaches the hard packed condition) does give you a tractable surface..
dirt track cars have a lot more suspension travel ( compared to asphalt cars) to compensate for the varying condition,
aero down force is huge...
this may be the point where you might want to think about straightening the car out
understeer ... oversteer
These terms just explain which end of a car slides more or slides first when reacing the limits of grip (also referred to as being "tight" or "loose"), or the other definition is when the rear tires have more slip angle than the front (this would be drifting as seen on dirt tracks).
When turning, the rear tires generate a lateral force, which is only possible if the rear tires are also oriented inwards of the direction of travel when in a turn. Because of this, all cars will end up oriented slightly inwards of the direction of travel when in a turn.
Getting back to dirt track racing, from articles I've read the main issue is the low amount of traction compared to pavement, combined with the limitation on how easily tires can deform at the contact patch which is related to how much lateral force can be generated. Theoretically, if a tire could be made with extremely soft and tall sidewalls, it could be possible for a dirt track car to corner normally, but apparently it's not possible to do this, so instead the cars are drifted thorugh the turns instead. Another factor could be that kinetic friction isn't much less than static friction at lower amounts of friction and/or certain types of tires (like bias-ply tires).
rcgldr..
do you mean Toe In?Another factor could be that kinetic friction isn't much less than static friction at lower amounts of friction and/or certain types of tires (like bias-ply tires).can you re-state this in other words because you lost me...
Ranger Mike
If a domestic car goes into oversteer then your average driver just couldn't cope. Reverse Lock?! what the hell's that . . . . crash. This is what happens when eejits in well powered cars put their foot down on a bend with a wet road (rear wheel drive).
The angle of the car axis wrt the direction it is traveling can be into or out of the curve, depending on what the driver is doing with the steering at the time. The optimum angle may well be a bit 'into the curve', though.
My main point is that there is no shortage of ability of a vehicle to get going far too fast for entering the next bend. When it gets to the bend, what is needed is as much force normal to its initial path as possible, to make it go round the corner. With sufficient skill and control, this can come from the rear drive wheels, which have to supply as little tangential force as possible as the vehicle is already going as fast as it can cope. This can be even taken to an extreme, when the car is almost pointing (driving) radially inwards to help keep it on its path. Not good value on tyre rubber, though. 30.000 miles on one set? I think not. This general principle applies in all / most circumstances but, on a very loose track, everything is exaggerated.
The situation with front wheel drive may well be different in detail but still I think the driven wheels are used best when they actually help with the cornering by providing force in the appropriate direction. Did anyone ever design a front / two wheel drive motorbike? That would have been interesting.
sophie..that was great...especially the part about the eejits
anyway.. a good conversation and i get your point..and i think we both can agree driving dirt is not for the timid or for the average eejits
rm
I remember I was that eejit, once in 1968 (ish). I lost it on a wet patch at low speed in a Morris 1000 and just waltzed round and round until I came to rest in a hedge. If I'd had my wits about me I would have just put the wheel the other way and emerged with no scratches.
sophie ,,morris 1000
watch this
may bring back a few fond memories..
glad to know there is another gear head across the pond!
rm
Ranger Mike said:
do you mean Toe In?
No, I mean slip angle. In order for the rear tires to generate lateral force, they need an overall slip angle. This means an entire car will be oriented slightly inwards (radiallly) of it's actual direction (tangental) when it's turning.
clarification... entire car will be oriented slightly inwards of the rear tires actual direction. Perhaps better stated that slip angle at the rear tires is like having the rear tires steer slightly outwards.
http://en.wikipedia.org/wiki/Slip_angle
That sliding friction isn't much less than non-sliding friction when grip factor is low and/or depending on the tire (like a bias ply tire).
In the case of a dirt car, the rear tires generate both lateral (sidways) and longitudinal (forwards) forces relative to the tires orientation when the car is drifting through a turn.
The grip factor seems to be the main issue. Rally cars drift a lot on low grip surfaces (dirt or snow), but not on high grip surfaces like pavement.
Formula 1 race cars are setup with more relative front downforce than rear downforce. They'll oversteer at slower speeds, but at higher speeds the downforce is setup to understeer a bit to avoid spins due to snap oversteer when pulling 4 g's in turns at speeds around 160 mph (like the turn Pouhon at Spa).
Surely the slip angle of the front wheels counts too, towards the direction the can axis points. If the front slip angle is greater than the rear slip angle, the car will be pointing outwards and vice versa.
But this thread is split into two, now. The situation is very different for dirt track, slow speed and for formula 1. I don't think we can come to just a single conclusion.
I love that show.
I hate driving front wheel drive cars in the winter. If you hit a patch of ice, the car just keeps going straight, and there's little you can do about it. In a rear wheel drive car, you can tap the gas a little to slide the rear end around.
Ranger Mike said:
The British say "aluminum" funny :)
Cool, I didn't know about the slip angle phenomenon, and I didn't know there was a field called, "vehicle dynamics." "Pacejka's Magic Formula" looks interesting too. Gotta love magic, lol.
Yeah, the only thing I can think of that seems to explain why sliding on dirt is "faster" is that the static and kinetic friction forces are very close on low-grip surfaces. I think things like dynamic weight distribution and banking might have something to do with it too.
If you could lower a set of driven wheels at the centre of the vehicle which were angled in the direction you wanted, they could be used to push the car inwards, into the curve when needed. But you don't have them so you need to point the car and use the wheels you've got. A vector thrust rocket engine could give the the same result. OMG, I wish I hadn't suggested that. Someone will go out and make one!
  • #31
Yes, I corrected my previous post to explain the car points inwards of the rear tires direction, not the direction of the front tires, or even the direction of the center of mass of the car, unless the car is in an oversteer (drift) condition.
Getting back to the dirt track issue, as previously mentioned, it's better to drift through turns because traction is low. I'm not sure of all the details, other than you get lateral and longitudinal grip when drifting on surfaces with reduced grip.
(Note I was unable to edit / correct my previous posts due to some sort of server error for several hours).
  • #32
This line of reasoning is incorrect based on my understanding of Newtonian physics. There is already a force vector on every tire (rear and front) pointing into the turn when not sliding. That force vector is directly opposite of the momentum (right term?) vector trying to push the car sideways, "up" the track. Static friction > kinetic friction. Therefore, if the tire is sliding, there will be less force pushing the car into the turn, so you'll have to go slower if you want to stay on the track while sliding.
Forgive me for any mistakes in reasoning, or incorrect use of terms. It's been a couple years since I've taken a physics course. Computer science is my field :)
  • #33
Every car is sliding sideways a bit on any corner (that's what the slip angle describes). It's just that the angle is small on normal surfaces. On dirt tracks there is a lot of slip and, without powering round a bend, the cars would have to go round 'unentertaingly' slowly.
Yes there is a force vector from each tyre but the force on the driven wheels is greater than if they were not driven (obviously?). So an extra set of wheels could provide more force in the wanted direction. Let's face it, if you could go round corners without use of the engine then that's just what drivers would do. I don't watch a lot of racing - particlularly not dirt track - but I see that they are always pointing as far into the bend as they can, subject to controlling an actual spin and they are producing a lot of dust and smoke from the back wheels, showing that there is significant drive coming from them.
I would go so far as to say that the ultimate dirt track vehicle would have four wheel drive plus four wheel steering. I have a feeling that very sophisticated control would be necessary to get it right, though.
  • #34
ektrules
maybe if you can look at
this thread Race car physics Dec31-08 11:44 AM posted by Ranger Mike
will help..
one huge factor you did not address is weight transfer which adds downforce on the outside tires.,.this dynamic factor shreds a static scoring of tractive force of the tire
  • #35
This hasn't been discussed as it can only be of secondary importance and doesn't apply at all with motorbikes.
  • #36
the original post asked a question about auto racing...did he not?
regarding the importance of dynamic weight transfer, i submit the following
huge weight transfer to the outside tires
  • #37
i think the major misconception is that dirt is loose and not a good surface for traction...this is a photo of a sprint coming out of the turn and nailing the throttle...
how is this possible...lots of weight transfer thur the suspension..dynamic and tuneable
  • #38
  • #39
Why would an extra set of wheels help when friction is not determined by surface area?
From what I've read, the "slip angle" phenomenon is not about sliding or "slipping." It's about the deformation of the tire; no sliding involved.
Again, all work to move the car both laterally and longitudinally is done by the friction between the tires and the surface. If there is sliding, then less work can be done because sliding friction is less than static friction.
Man, I've been thinking about this too much :)
I think I'm starting to get the picture of how this works though. What I thought was simple, is actually a very complex maximization problem. Without sliding, the friction vector of the rear tires will be pointed quite a bit more forward than toward the inside of the turn. Although kinetic friction is quite a bit less than static friction, it may be possible to get a vector with a larger component in the direction of the inside of the turn by sliding the rear and providing power to the wheels, even thought the total friction between the rear wheels and the surface will be less (because kinetic friction is less). Add in banking, dynamic weight distribution, and aerodynamic, then you have a very complex maximization problem.
The only reason I can think of that explains why sliding on asphalt is often "slow," and sliding on dirt is often "fast" is because there is less difference between the sliding and kinetic friction coefficients on dirt surfaces.
  • #40
Your almost there...I think I'm starting to get the picture of how this works though. What I thought was simple, is actually a very complex maximization problem.
how ture..ifin it were easy there would be many Jimmie Johnson champions Without sliding, the friction vector of the rear tires will be pointed quite a bit more forward than toward the inside of the turn. Although kinetic friction is quite a bit less than static friction, it may be possible to get a vector with a larger component in the direction of the inside of the turn by sliding the rear and providing power to the wheels, even thought the total friction between the rear wheels and the surface will be less (because kinetic friction is less).
we will come back to this a little later , if ok with you
Add in banking, dynamic weight distribution, should be dynamic weight transfer, and aerodynamic, then you have a very complex maximization problem. yes
lets review just what happens when we turn left( or right)..
for a given set of tires, on an asphalt track, and typical passenger car suspension, everything is ok until one of two situations occur..
the driver nails the throttle in the turn and thus causes loss of traction ( spins the tires too fast) and the momentum of the vehicle, suffering loss of rear tires sticking to the track, spins out...not to likely with todays grocery getter..or
the car enters the corner at too high a rate of speed and the front tires can not provide enough force to steer the front of the car around the corner and literally shred as the tires experience wheel lock and snow plow toward the out side of the turn...( its pushing , or suffering under steer).
Nothing is going to change the direction of the car without the use of the front wheels. To the degree the front wheels can negotiate a turn successfully depends upon many things, Static tables showing Tire coefficient of friction vs slip angle, coefficient of friction vs vertical tire load, coefficient , coefficient of friction vs percent of slip, tire force vs vertical tire load..don't mean a thing if you ca not handle the transfer of sprung weight to the right front tire in the turn.
this applies to dirt track as well as asphalt..the reason we have smaller suspension travel on asphalt cars is because the track is consistent and there are a lot less variables to contend with..those photos I posted of the 1500 pound, 800 h.p. dirt l cars coming off the turn show huge suspension droop, weight jacking, vast body roll..all to negate the varying effects of the changing dirt track.
gotta get some beer..did this help?
  • #41
Ok, interesting. You're implying that the front-right tire has the most important job of turning the car on a left-hand turn. Makes sense.
  • #42
you got it!
there arr many other factors but it all comes down to being able to turn the car in, while controlling the diagonal weight transfer from left rear to right front, keeping the body roll to minimum, arriving at the apex of the turn with enough traction ( proper weight on drive wheels) and being able to hook up the tires with the car pointed at the correct path to your next turn point..(drives do not drive ROUND the track they " diamond" the track for the shortest line..but that is another discussion..
bottom line is to control the sprung weight properly with the correct springs and shocks(dampers), anti roll bar, aero package..etc..
  • #43
This recently came up in another forum and got me thinking about it again.
Through further discussion, I've come to the conclusion that it is the shearing of the dirt particles against each other that accounts for the force generated by the tire. When the track is tacky (moist) the amount of force generated when essentially tearing a dirt particle away from its neighboring particles will be more than when the track is dry and the material loose. As seen in tractor pulls, it appears that the faster the tires are spinning, the more material is being sheared and the more force is being generated. If each particle can be considered to represent a unit of force generated, spinning the tire at a higher rate shears more particles in a given time span and as a result should generate more force. That seems to match well with what is happening.
The shearing action takes place in the dirt layer, not in the tire so the heat generated by the shearing action is absorbed by the dirt rather than the tire. From what I understand, dirt tires typically don't wear quickly and can last several seasons in some classes (spec tires) because of the lack of heat in the tires.
However, as the track packs hard and dries out the generation of force switches to essentially the same as what happens on asphalt, with gripping/adhesion and interlocking of the rubber and track surface being the main mechanism. The shear force increases in the hard-packed dry surface to the point that the rubber of the tire shears first. Because of that, it is fairly easy to overheat the tires because the shearing action that accompanies sliding now is occurring at the tire surface rather than the track surface. In this scenario, spinning the tires results in a loss of traction as the tire heats up and the rubber at the face tears away with less and less force just like on asphalt when the spinning tires go up in smoke. Not spinning the tires but instead relying on "gripping" gives the most traction under these conditions.
So sliding in dirt track racing is faster because more work is being done by the tires when the tires are spinning, because more particles are being sheared from the track surface; I think it likely that the higher speed that the particles are being sheared also increases the force per particle, doubling up the effect much like the increase in force experienced because of aero drag as a car is moving through the air at higher speeds.
This also appears to work just fine to explain what we see with dirt bikes.
A bit of an aside: sliding on asphalt might also work better than "gripping" were it not for the characteristics of the tire compounds now being used. I do remember seeing pictures of drag racing in the '60s with the fastest cars spinning the tires for most of the quarter mile, indicating to me that sliding/spinning allowed the car to generate more force and therefore more acceleration - and that vastly different tire compounds were being used then! Seems to me that there was a lot more sliding on the road racing tracks as well at the time.
If a tire on asphalt didn't have the heat build-up and subsequent loss of rubber integrity, it's possible that spinning the tires on asphalt would also show a higher force being generated. I think there might be something to that as the traction peak with asphalt is reached with a slip angle or slip percentage, one that might coincide with the rate of heat build-up at the tire surface, effectively making all cornering or accelerating in the kinetic friction range rather than being static friction as most discussions assume. More things to investigate!
Thoughts?
  • #44
Here's an article that appears to confirm the friction model:
http://www.circletrack.com/chassistech/ctrp_0810_dirt_racing_tire_prep/viewall.html
  • #45
It strikes me that speedway racing is done for 'effect' and for entertainment not for the highest speeds. The fastest way to get round a track would surely be using a 'normal' road surface and racing tyres - else would they not have all roads made of grit?
  • #46
Racing's racing, and people will race just about anything anywhere. So far I've raced on asphalt, dirt, and ice; hard to say which one is more fun but they all have their good points.
The fact that other people like to watch us tear round in circles doesn't bother us in the slightest, in fact it allows us to subsidize our habit by charging them an entertainment fee!
  • #47
In asphalt racing the coefficient of friction is greater than on dirt. To maintain static friction on dirt and actually be able to turn your car you would have to slow down so much that it would actually be a disadvantage to you. Those who hold it straight have problems and end up in the outside wall unless they significantly slow down. This is why you hear drivers say the car is too tight, or it needs to be loosened up.
That being said, if you had a very high banked race track, you could possibly hold the car straight and be faster than sliding, but there aren't really any tracks with that sort of banking. Also, you're going to have to sling your car more on a flatter track or a track with tighter corners than on a high-banked track.
  • #48
The original question "Why is sliding in dirt track racing faster"? Is actually a false statement. It is not faster to slide through the corners with a dirt car. However it is a compromise for a car that will not turn because the rearend is locked and has no differential. I have been building dirt late models for 25 years and have over 200 wins with various drivers. All of these cars suffer from understeer on corner entry. Therefore most drivers have to pitch the car sideways on entry or turn with 3 wheel brakes etc. At that point they have actually put the rear tires into a slide in order to negotiate the corner. If the drivers do not turn the cars in this manner they will understeer so bad on corner exit the driver will have to lift off the gas to negotiate the corner exit. Recently we have been able to develop setups that allow for neutral steer on corner entry all the way to the apex. The drivers never have to drift the cars through the corner and they are much faster than the old setups. As others discover these developments it will be the end of dirt cars sliding through the corners. Then the discussion can go back to slip angles etc.
  • #49
ektrules said:
If the power was not delivered by the wheels, but with a rocket or something...
As you point out in your first post, the tires are accelerating a lot of dirt backwards, so they are a bit like a rocket. This doesn't happen on asphalt. You would have to do some math to see if the momentum change of the expulsed dirt is significant compared to the momentum change of the bike.
  • #50
A.T., reread my last post; I think that the amount of force needed to shear a dirt particle from the surface would be much higher than the force from the momentum change imparted by accelerating the particle after shearing. Just my thoughts.
