VASUbhagwat said:
yes, but what happens in a vibration, that makes it produce a sound.Why does our ears interpret that as a sound ?
This is actually explained fairly well by a comparison to the Fourier representation of a function. A Fourier series decomposes a repeating signal into a range of frequencies and can assign more linear values to them. If you google graphs of them, you can see what I mean. Sound is a repeating signal in short intervals. It changes because of interferences from other sources.
When you hit a note on a keyboard, you are hitting a bar. You can think of that note as one of the bars in a transformed signal. Our ears interpret the bars as a sound rather than bothering with all the waves. More specifically, you can think of them as interpretting the bars within the range of frequencies that we can hear. Each bar is assigned a sound, and the more complex the signal, the more overlapping sounds we can hear at once... which produces the difference from striking a single key on a piano and multiple keys at once. In fact, some of the signals are stronger than others as well, which can explain why similar frequencies will sound different at different amplitudes (volume).
Of course, it's just a metaphor. Your ears don't ACTUALLY perform transformations on the signals you hear, but they do simplify them a lot in order to interpret them. That's just because our brains register things on a different scale than that which is actually happening around us. Stuff that is happening slowly, we can process most of the information for. Stuff that happens very quickly (like the vibration of a sound wave) is mostly interpretted as an approximation so that we can keep up.
Maybe that helped?
PS: This is actually exactly how machines interpret sound. Have you ever seen these bars on a car's stereosystem bouncing with the beat? Lower frequencies are more dominant when the bass is turned up while higher frequencies can be better seen bouncing with the treble or singer.
http://cdn.faveable.com/assets/articles/bring-your-tv-to-life-with-these-great-soundbars-1405609982.jpg
